How do i know if my throw out bearing is broken
i got new 6 pluck clutch with lsj throw out bearing just wondering how to tell if its broken. I bleed the clutch it seemed fine but when i went to the track there was more air in the clutch (or so it felt) and i couldnt shift in. The clutch peddle went limp. And it required a tone of pushing in and out to get prussre to build up. thanks guys
When this happened to me I had just gotten a transmission done under warranty, and only god knows why but the dealership had my clutch assembly off, which they should have never touched... and didn't tighten down the pressure plate bolts down. I took it back 4 times to have them bleed it because it would never hold pressure. Are you positive everything is torqued to spec?
pretty sure
pretty sure they are torqued to spec
anything else
i was thinking master slave but idk alot about transmission help?
also what vac line where you thinking of
anything else
Last edited by Winkdogydog101; 05-03-2010 at 01:11 PM. Reason: Automerged Doublepost
will it looks like its leaking out the brake fluid holder that connects to the car
will it looks like its leaking out the brake fluid holder that connects to the car what is this part
DANRICKARD
10-01-2015 12:08 AM
