How much boost can a stock lsj block cylinder walls handle
Old 12-27-2015 | 05:59 PM
KMO43's Avatar
Originally Posted by mrbelvedere
^your high
So its a good idea to spray corrosive liquid through a turbo????
Old 12-27-2015 | 06:11 PM
Compressor wheels are replaceable
Old 12-27-2015 | 06:25 PM
KMO43's Avatar
From devil's own site
Pre turbo
We don't recommend this location at all, if you do not have the proper equipment, such as, the proper nozzle, nozzle size and high pressure pump. Locating the nozzle here is the most controversial location. The majority of alcohol/water injection users do not use this location. One reason for someone to inject at this location is the water/methanol mixture chemically alters the turbo compressor map. The water/methanol injection will dynamically shift the compressor map of the turbo, so that the compressor map exhibits the characteristics of a larger turbo. This sounds great but, the main issue with pre-turbo nozzle placement is what mixture can damage the compressor blade if the mixture is not properly atomized when passing through the turbo.
In order to inject pre-turbo with out compressor damage you need a high quality low volume nozzle and high enough pressure to get the water as finely misted as possible, and the smaller nozzle which allows for smaller/finer water droplets. We recommend you mount the nozzle as close to the compresser as possible.
Old 12-27-2015 | 06:27 PM
KMO43's Avatar
^your high
Good contribution here Mr B. 👍
Old 12-27-2015 | 07:48 PM
KMO43's Avatar
Old 12-27-2015 | 08:35 PM
I could definitely see that being caused by poor atomization. Water no like compression
Old 12-27-2015 | 08:36 PM
But ive also seen people run unintercooled with meth pre turbo. Obviously nothing lasts forever
Old 12-27-2015 | 09:38 PM
KMO43's Avatar
I have thought about it for myself but only for a 60 to 100cc nozzle
Old 12-28-2015 | 12:52 PM
06blackg85ss's Avatar
gonna run 2 small nozzles pre turbo, like two 2gph. running a 250psi pump. only going to have it kick on above 30psi.
plus I have a really efficient intercooler setup on the car already. at 32psi I get about ambient iat2's as it is. turbo I have isn't really good up that high, so why not extend the map with a little meth for now. if it kills the turbo, so be it, something bigger goes in. Know a lot of ls1 guys running preturbo setups for a while now, even will be running one on my 88mm turbo'd trans am in the spring
Old 12-28-2015 | 04:14 PM
Whats your intercooler setup?
Old 12-28-2015 | 04:42 PM
  #36
zzp lnf one. rest of turbo setup it ottp kit.
works just as well as my old hahn one did.
nice 4" core
Old 12-28-2015 | 05:09 PM
  #37
Have you looked into the end tanks of their intercooler? Was wondering if they use a high density core or not.
Old 12-28-2015 | 05:38 PM
  #38
KMO43's Avatar
What turbo do you have?
Old 12-28-2015 | 07:33 PM
  #39
s256 on there now
and I didn't just kinda threw it in and did some logging to see what my temps looked like
Old 12-28-2015 | 07:36 PM
  #40
KMO43's Avatar
s256 on there now
Ya that isn't the biggest turbo
Old 12-29-2015 | 08:42 AM
  #41
nope, pushing it a little hard right now, so figure a little meth never hurt no one lol.
Old 12-29-2015 | 12:52 PM
  #42
KMO43's Avatar
I'm still not a fan of pre turbo meth and I had great results with post on my k04r but i guess if it wrecks your turbo you have an excuse to upgrade!
Old 12-30-2015 | 07:09 AM
  #43
that's pretty much the plan lol.
going a few steps bigger on the next one.
Old 01-03-2016 | 02:36 PM
  #44
mrbelvedere's Avatar
it has been done many many years and problem free long before you came along to voice your opinion
Pre turbo
that's is their opinion not fact
looks like it was run without a filter
Old 01-03-2016 | 06:40 PM
  #45
Come on MRB lets see some facts then.
Old 01-04-2016 | 10:24 PM
  #46
go do your own home work
Old 01-04-2016 | 11:32 PM
  #47
Lol isnt that exactly what Kevin did? Obviously you know something we dont? Spill the beans, help the community.
Old 01-12-2016 | 03:20 PM
  #48
reading one excerpt from devils own does not count go research cosworth and such
Old 01-13-2016 | 03:21 PM
  #49
Area47's Avatar
Rent me! per hour
32 psi
27.5 degrees of timing
11.3 afr
90k mile stock long block.
TVS car btw.
stop being bitches.
Old 01-13-2016 | 03:29 PM
  #50
Originally Posted by Area47
32 psi
11.3 afr
TVS car btw.
stop being bitches.
Care to comment on meth pre turbo?
Quick Reply: How much boost can a stock lsj block cylinder walls handle
