How much boost can a stock lsj block cylinder walls handle
Old 01-15-2016 | 08:48 AM
  #51
06blackg85ss's Avatar
Originally Posted by Area47
32 psi
27.5 degrees of timing
11.3 afr
90k mile stock long block.
TVS car btw.
stop being bitches.
38psi
24 degrees if timing
86k mile stock long block
tvs w/2.3 pulley
who's the bitch
only lasted 10 pulls lol
Old 01-15-2016 | 05:21 PM
  #52
Area47's Avatar
Rent me! per hour
Care to comment on meth pre turbo?
they still make turbo kits that are a draw through carb setup. this is nothing new and has been proven to work, and work well in past setups, and todays setups.
same people said the same thing about spraying pre blower year ago as well. now people don't think twice about it.
If you're using it as a secondary fuel system, id go after the compressor due to higher methanol content to be used. pre turbo, id run no more than 70/30 on a meth./water mix.
Originally Posted by 06blackg85ss
38psi
tvs w/2.3 pulley
who's the bitch
mine lived just fine.
Old 01-17-2016 | 04:48 AM
  #53
victory_red_SS's Avatar
LSX RWD S/C conversion
32 psi
11.3 afr
TVS car btw.
stop being bitches.
38psi
tvs w/2.3 pulley
who's the bitch
Play nice you two
Old 01-18-2016 | 09:17 AM
  #54
haha all fun and games.
  #55
not my car, not my problem lol
Old 01-30-2016 | 12:24 PM
  #56
rnjmur's Avatar
Originally Posted by mrbelvedere
the stock block was never really rated that I know just peoples educated guesses
what it boils down to is this any stock part left in the engine is a weak point(minus the crank) even with a closed deck the stock sleeves are what will give up and the tune better be spot on as the stock sleeve will not take a lot of detonation and cylinder pressure
I don't know if the block was "officially rated" at that or not but I got that information straight out of the GM Performance build book.
Old 01-30-2016 | 12:43 PM
  #57
Sharkey's Avatar
i never have read an official rating. the gm build book builds the 400-600hp combo with sleeves, and the 250-400hp combo without sleeves. so imho, thats gm performances rating on what the block can take.
Old 01-30-2016 | 07:39 PM
  #58
mrbelvedere's Avatar
and there is a lot of misinformation in that book also
not to mention people have broke the block completely stock so
Old 01-30-2016 | 10:55 PM
  #59
06_ion2's Avatar
I'd be more worried about enough crank case venting than the sleeves.
Old 01-30-2016 | 11:37 PM
  #60
venting is important but the sleeves are weak
Old 02-01-2016 | 04:18 PM
  #61
eh all depends on how porous the block casting is
gm rated the whole engine to only 300hp, but of course we've pushed way more and had em live... like 500+whp on completely stock bottom ends with just cams and valvesprings and they stayed together for thousands of miles.
but I do think that anything north of 450ish whp, especially with a power robber... I mean super charger (j/k) should definitely buy the added insurance of sleeving the block.
I'm just running press in diesel sleeves (well material used for making sleeves for diesel pulling trucks) and at 3000 miles now on the new motor all run at 24psi + last 1800 miles on 35psi on an s256 and so far so good.
Old 02-03-2016 | 04:09 PM
  #62
DBLBoost's Avatar
Well... I can tell you mine blew a huge hole in the #1 piston wall at 445whp with stock sleeves while on a dyno...
Old 02-03-2016 | 04:51 PM
  #63
KMO43's Avatar
I made 481 wheel all year last year no issues still driving it today but detuned for winter
Old 02-03-2016 | 05:34 PM
  #64
user 72239's Avatar
ALL of the boost.
buy a 6266 and dont have a wastegate. DONE
Old 02-03-2016 | 08:01 PM
  #65
blueLNFftw's Avatar
My buddy had a wastegate failure and saw 40psi on a stock block with the s252. Number 4 blew and the sleeve had triangles cut into it. LSJ.
Old 02-03-2016 | 08:07 PM
  #66
KMO43's Avatar
I spiked 34psi for a sec on my 7163 got off it right after
adunk25
01-10-2016 11:21 AM
goaliemo
12-30-2015 04:06 AM
Legion
12-23-2015 03:45 PM
stolz
12-16-2015 01:06 PM
Quick Reply: How much boost can a stock lsj block cylinder walls handle
