how to question
if you want to knock out the innards of a cat then your best bet is to take it off and take a large crowbar and stick it inside and hit the top of it with some sort of hammer or mallet.
don't forget to have your car re-tuned also because by not having the stuff in your cat will let your exhaust flow a lot more and therefore you have to counter that by sucking more air in and then you have to counter that by adding more fuel. that's why if you change any one of those 3 then you should compensate with the other 2
