How to swap pulleys?
Aside from the blue bolt for gm. Is there a tenionsor that i can loosen to have slack in the belt or is it a spring loaded tensionor? Would it be ok to swap to he head bolts as long as they are the same lenth and pitch as the blue bolts?
Also taking the blower off is that necissary to change pulleys? Is it hard to take the blower off?
The tensioner is located behind (toward back of engine) of the supercharger.. you use a size 15mm open ended wrench and push down on the little square looking *** on the tensioner.
Yes, you can use any bolts you'd like.
Taking off the supercharger takes all of 10 minutes.. very easy.
Now when I put some bolts back in. Do I use lock tight or lock washers? Or do I need anythin? I know the vibration can cuz screws to unscrew. Do I have to worry about that?
If you leave the SC on the car use a little screwdriver (when installing the new pulley)to line up the holes in the pulley and hub or else you will be fishing around trying to find them for awhile.
Honestly it used to take me 5 minutes to swap a pulleys with the SC on the car, but its easier to just pull the SC if the bolts are too tight to get off or have locktite on them.
One another note ....I miss my SC , I really miss the whine , it's so unique . I really like the TC , but the SC is a lot closer.... performance wise .... than most turbo guys would like to admit hehe.
O ok and never had a problem with them fallin out? Ok what about striping em out? Did gm install your stage 2 kit? If so did they use lock tight?
And what you mean the sc is a lot closer performance wise than the tc guys like to admit? And if I sold mine I'd miss the whine also. You don't pay it mind until its gone lol
I installed the kit so no locktite. Never had any problems stripping them out or anything.
The SC vs TC thing is just an observation lol, i guess i have a tinge of buyers remorse hehe.
The missing the whine till it's gone thing is so true........I never even though about it ......till I wasn't able to hit the gas and hear it .
I know how u feel. I love the whine but ok cool I took everythin in and I should be cool. But yea your sc was prolly faster than the stock tc but once you tune like errybody else you will be way ahead
So you guys suggest tightening the bolts with the belt on?
The reason I ask is because I'm getting ready to install my SC kit and I bought a 3.0 polished pulley. I was installing the pulley onto my SC while it was sitting on the bench. I had to use a combination of another hex socket and screwdriver while using my torque wrench in order to be able to tighten them.
The pulley got a little scratched up. Once I get my car up and running I plan to order a 2.9 pulley and don't want to fugg the pulley up the next time.
I also purchased a pulley boys tension relief tool so that should be a little easier with the belt and all.
