Hp Tuners pro help
Hp Tuners pro help
I recently bought stage 3 from zzp and supporting mods as well. Ive planned on taking the balt to gm to have it flashed ao i can atleast drive it then a tuner after to get the real potential out of the setup. While doing all this im thinking maybe getting hp tuners will be the wiser route $ wise since im sure ill always be Modding. Only problem is i have no experience whatsoever, so my question is should i consider buying hp tuners pro or not? And ive heard some people on here can actually send you tunes??
Yes people can send you tunes. You can actually have ZZP send them to you. I'd definitely get the HPT and find someone local to you that can either give you a base file or actually tune you. But there are many people on here that are willing to remotely tune you, which is they send you a file, you do a log, send it to them, and so on... Plus, the flash that GM will do will not be for the components in the ZZP S3 kit... So your best bet would be to buy HPT yourself, and find someone local that can tune you or find someone on here that can do it remotely.
Well the main reason for the gm flash was just to get the car mobile until i could actually get it tuned. They told me to bring every part that i install so they can call gm and properly flash it for now. But i really am thinking hard about buying it i just dont know anyone around here that would be able to tune it for me and help me learn. I would feel real uncomfortable unless i knew the person absolutely knew what they were doing sincw i have little knowledge on this topic. I plan on reading and learning myself as much as i can but i figure just having the software myself will be nice and if i ever get to where i can do anything i can help others as well down the road
