i want to run nitrous!
ok, my mods are basically full bolt ons but ill explain to give you all a better idea. bad mab header, 2.5 catted zzp dp, gmpp cat back, zzp dual pass, opt. B tank, zzp h/e, 1 step colder plug, zzp 1.0 pcm, AIS stage one meth kit. phenolic spacer/throttle body spacer tapped for meth/nitrous. right now im running a 2.7 pulley, i have a 3.0. i want to run nitrous but my question is, dry or wet? iv done research and i get mixed answers. personally i want a dry shot, and only a 30 shot no matter what. what are your opinions? i just dont want to jump into this and blow it up. i know nitrous a great power adder if done correctly and it can be reliable, so thats how i want mine to be.
the MAF isnt what you would need to tune for the nitrous. same for the meth. the MAF just measures how fast the air is moving across it. i dont think it would ne good for the nitrous to go over the MAF anyways, correct me if im wrong.
You can run the shot on the tune you have, but you have to do a wet shot. There is no way to run a dry shot untuned. And you should always tune for nitrous, as it dramatically changed cyl pressures and temperatures.
I personlly would never bother with a dry shot, too much hassle to get the a/f right and still keep it normal when you are off bottle. Wet shot is totally self sufficent once you get the jetting right, you will see the same AFR on or off bottle, or slightly richer on bottle like I run them usually.
For example, on my 350z, I have the car tuned for a constant 11.8 A/F on motor. When I hit the spray, it's adding enough fuel (wet shot) to burn with the extra oxygen from the N20, so my A/F stays a 11.8 after the spray comes on. Or I can push harder N/A, say 12.5, and run the jets a bit richer, so when I spray it drops down to the 11.8 I want on bottle.
You can run up to a 100 shot safely if you tune for it on a stock engine. Any more than that is just pushing the power limits of the stock pistons. I'd suggest staying under 75 and making the power in other places, car will be nasty anyway. With the design of our intercooler systems you will get a nice cooling effect from the nitrous, but a larger shot doesn't increase that, so it's kind of a diminishing return as you go larger.
Let me know if there are any other specific questions I can try to answer for you.
^^^ that helped! thanks man, im ordering my clutch soon, then i will go ahead and order my zex kit from zzp, like i said before, i only want to run a 30 or 35 shot.
this should be all i need to get started right?
ZEX - ZEX Nitrous Kit #
OR, would this be a little better
ZEX Nitrous 82357 ZEX Safe Shot Nitrous Kits
Do you have a way to monitor your AFRs?
I run this wet kit from Dynotune.
Cobalt and Ion Wet Nitrous System
And I use Trifecta's GMS3 PCM as my window switch.
When your baby screams and whines give it the bottle...Nitrous Trifecta GMS3 - Saturn ION RedLine Forums
alrighty, the dyno tune kit looks really nice. as of right now, no i do not have a a/f ratio guage, but i am getting one in the near future since i did buy a DP with an extra 02 bung.
I just purchased the GMR Stage 3 nitrous jumper wires.
I will refer to your write up when I install them
so would i be able to talk to vince, get a gm stage 3 pcm with ac unlocked, get it set up for my #50 injectors and my 3.0 pulley/meth, injen intake, bad mab header, 2.5" high flow catted DP, gmpp cat back, and my cooling mods? if i did this, could i still use my cruise control?
GMS3 does not affect cruise control, nor does any tune really.
ok, i thought you had to like hold the cruise button or something for it to activate the nitrous mode? lol idk haha. dont worry, im getting there, i wanna get my cluth in the buy the set up! im excited!
