i want to run nitrous!
Old 04-11-2012, 12:26 AM
Micro's Avatar
Yes....
GMS3 does not affect cruise control, nor does any tune really.
GM stage 3 does affect cruise control (a little). You can only engage cruise control at 35 mph or higher with GM Stage 3 (you could do it at lower speeds with non stage 3). You can't cancel cruise control with gentle touch of the clutch pedal on GM Stage 3 (but you can on non stage 3). But, who really uses cruise control below 35 mph anyway.
Old 04-11-2012, 12:29 AM
Pyros777's Avatar
^ I need to test this. lol
Old 04-11-2012, 03:14 AM
Vander Nars's Avatar
I want some nos now but i dont know of my motor can handle a 50 shot with it having 96k miles
Old 04-11-2012, 07:16 AM
Administrator
Administrator
Staged07SS's Avatar
Hmm, I always thought that's how it was stock as well. I never tested it, and wouldn't think a tune would affect the cruise control of a car.
I'm pretty sure GM claims you can't engage cruise control below 40mph in my manual. I'll have to check.
I never worry about that though, because like you said, who uses cruise at that low of a speed.
I would never think to disengage cruise control with the clutch pedal.... I either use the button on the steering wheel, or brake if I have to.
Old 04-11-2012, 07:33 AM
BlueBalt1113's Avatar
im going to be running 75 shot in a month on my 2.2 and then once i get cammed and get my custom made manifold that is gasket matched and the ls4 tb ill be running a 100 shot to 125 dry shot with a saftey switch that ill turn on once in second gear and it will only spray at WOT
Old 04-11-2012, 07:36 AM
Is ur 2.2 built?
Old 04-11-2012, 08:07 AM
will be once cammed going with a stage 3 cam 78lb valve spring retainer set, sleeves pistons rods you name it
Old 04-11-2012, 08:31 AM
Spanky's Monkey's Avatar
75 shot on a stock 2.2 is all good. had my rpm switch set for 2700rpm as the tq stall on the auto is 2500rpm. made for some really tight launches at the track.
Old 04-11-2012, 02:41 PM
mrbelvedere's Avatar
i dont see why it wouldent
why buy sleeves when you can get a better and cheaper soulution from zzp
Old 04-11-2012, 02:50 PM
Well I was talking to James(ccss3) and he told me that I shouldnt push my car to much with its mileage when i asked him about meth setup, so i figured nos was just as hard on the engine. Im running the gm stage 2 with a custom tune and some bolt ons but I want more power so we talked and im gonna drop down to a 2.8 with 60s. but i still wanna get a lil more power out of it, I figured a 35 or 50 with get me where I want a lil over 300hp. First thing I got to do is get a compression test tho make sure everything is healthy tho.
Old 04-11-2012, 03:51 PM
  #36
euthanasia's Avatar
How is Meth hard on your car?
Old 04-11-2012, 03:56 PM
  #37
a compression test wont tell you **** you need to do a leak down and if you thing your gonna hit 300 whp on a 2.8 and meth then you need to get out of lala land and step into the real world if the engine is setup correctly with a tune a 50 shot wont hurt **** ask ebristol how many miles are on his and not to mention i know a guy with 140k on the clock and they leaked his engine it leaked 5% they just switched it to e and a 2.8 and he beats the **** out of it
Old 04-11-2012, 03:57 PM
  #38
exactly i would like to know that one
Old 04-11-2012, 04:30 PM
  #39
TStone's Avatar
It turns **** blue!
Old 04-11-2012, 05:14 PM
  #40
sick CCSS's Avatar
if meth is hard on stuff, i wonder how my meth/nitrous set up will be hahaha, jk. meths isnt hard on the engine, actually very benificial its helps keep you from pre detonation and cooler temps.
Old 04-11-2012, 05:29 PM
  #41
I never said 2.8 and meth would make 300 hp i said 2.8 and a 35 to 50 shot should make a lil over 300 with a good tune, u should get ur head out ur ass and take the time to read my post before u reply
Old 04-11-2012, 05:34 PM
  #42
To be honest i dont know james said i prolly shouldnt use meth due to my miles, he never said that it would be too hard on the engine im just assuming that would be the problem
Old 04-11-2012, 09:20 PM
  #43
james is high
Old 04-12-2012, 05:29 AM
  #44
cause i have a buddy that does alot of custom work that is real good and cheaper since i saved his life
Old 04-12-2012, 09:30 AM
  #45
thats cool enjoy the fact that sleeves weaken the block
Old 04-12-2012, 10:04 AM
  #46
how does sleeving a block weaken it???
Old 04-12-2012, 10:18 AM
  #47
ZZPerformance - ZZP Girdled Block #ZZ-GB-ECT
read the additional information section
Old 04-13-2012, 04:10 AM
  #48
o see you are misunderstanding me and thats my fault on explanation my buddy is going to be pinpointing the weak part of the oem block and redoing them **** dalton sleeves their junk
Old 04-13-2012, 09:04 AM
  #49
the only way to fix the weak spot is to do what zzp did but do it without cylinder distorting
Sl0wbaltSS
11-21-2018 11:11 PM
Zharrington_2010LNF
02-08-2016 01:43 PM
tomj77
10-04-2015 11:39 AM
dieGone
10-01-2015 06:27 PM
Extremespeed
09-29-2015 04:34 AM
Quick Reply: i want to run nitrous!
