Iat2 temps
Iat2 temps
Hey everyone, just wondering what are your iat2 temps!
When I WOT, it goes over 180 and my regular driving sits around 150. My pump wasnt working so I smacked it with a hammer and its back to life. So its working for now, but the temps are still the same as yesterdays.
What you I do to lower my temps to a normal, safe temperature. I have a zzp #3 heat exchanger, injen 2.5" coi, 2.9" tvs
Thanks a lot!
Thanks a lot!
get a zzp phenolic spacer
Cobalt & Ion ---> ZZ Performance
and put this on the fron and back of the lower intake manifold
Design Engineering DEI 010393 - DEI Reflect-A-GOLD Heat Barriers - Overview - SummitRacing.com
Window Licker
I apologize for the threadjack, but lol, I saw 190* doing 2 highway pulls, what the hell is going on? the first pull i let off at around 110 mph, and then the second one around 120 mph. I just replaced my ic pump maybe a month ago or so, so that isnt the problem. I wanted to do a few good pulls on the tvs but as soon as i saw 190 i was like holy **** i think thats enough for the day. I have the ottp h/e. Why were my temps so high after 2 pulls?
I think I'll get another pump tonight from zzp. It doesn't seem to work correctly. Might as well get the Option B and dual pass at the same time. Seems a bit complicated to install tho
Homemade option b, zzp s3, dual pass, zzp phenolic spacer, and meth that comes on at 8psi. I have never seen over 120ish after back to back pulls on my 2.7.
Definitely get a working pump and then get all the cooling mods you can afford
