Innova CanOBD2 Scan Tool ! Check CEL's and ERASE them now too !
Now you can connect your car to a scan tool to check your CEL codes, and you can erase the check engine codes ! This unique scan tool will work on all vehicles from 96+ with OBD2 to check your codes, tell you if your vehicle will pass emissions inspection, and can erase/turn off your check engine code instantly !
"Helps to identify what’s wrong with your OBDII vehicle by quickly revealing check engine light warnings in cars, trucks, SUVs, domestics and imports. All in one display not only shows the code, but also it’s meaning. Will read for pending as well as active codes and has indication lights for emissions pass, pending or failure. CanOBD2 will also freeze frame code status, erase codes and link to PC for printing and updates!"
Kit includes:
CanOBD2
OBD2 Cable
Software CD
Serial PC Cable
Soft Nylon Case
3 AA Batteries
Pricing is $189.99 with $8 shipping.
Remember, this will work with all vehicles with obd2, trucks, cars, domestics, imports, and it will work with the new standard of OBD2, CANOB2. So one tool will work with your car, your moms car, your dads car, uncles car, best friends, etc ! You get the point !
Kit includes:
CanOBD2
OBD2 Cable
Software CD
Serial PC Cable
Soft Nylon Case
3 AA Batteries
that's gonna be a good tool for all the 2.2L cobalts out there, cause they have CAN on them... 2.0L appearently doesn't though, and not sure about the 2.4L
pretty cool you can also print from it
Moderator Alumni
The LSJ is CAN and Class 2 depending on what your interfacing with. The ODB2 port has the Class 2 and CAN pins...
The PCM in the LSJ is Class 2 for the diagnostic parts that we normally would interface with. The BCM and Radio and XM as all CAN or GMLAN.
Moderator Alumni
Originally Posted by phxSS
^^^^ Sooooo. this tool will work for LSJ? lol
Well I can tell you that I have used two Class 2 devices that both interfaced with the PCM and read codes, engine variables, ect. So I don't have any reason to believe it wouldn't work.
And if modern is selling it I am would put 100% faith that they wouldn't sell me something that wouldn't work just to make a quick buck.
Thats cool but why dont you get an interceptor gauge that you can use like that 24/7 and can get 200 times for info and dont need to hook that ugly box up to your car.
South Central *********
im a tech and wanted a portable scan tool for me
this was the one i was planning on getting until i saw this post but i agree that will work
want a scan gauge too but this works for lots of cars
? about aeroforce
i need to see a bunch of pics
plus i like the stock gauge if i got the scangauge i would use it W/ the stock autometer perhaps on the dash in a cup
? about aeroforce
