instaling DOWNPIPE
grade 8 1/2 inch. when I started the big thread on the bad bolts...zzp changed it to where they shipped with even bigger bolts (it was the second time that they upped the size). find out what size bolts you have. I bought some grade 8 1/2. cause man, if they do break then it will break the gasket more than likely which = exhaust leak until zzp can send you another gasket (not to mention you will still need bolts and then you will probably want to be safe and get grade 8)
So, just bite the bullet and get 1/2 grade 8 and be done with it
