Installing Euthanasia Ported & Built Head. TONS OF PICS
Old 01-10-2014, 01:03 PM
  #226
InfraRedline's Avatar
My best 1-2 shift ever was on my 12.2 pass, and that was because I had traction and I knew it. I could feel it was gonna be a good run, so I wasn't gonna mess up. 2-3 and 3-4 is retarded I almost feel bad for the car, but I shift fast, not hard.
Old 01-10-2014, 03:38 PM
  #227
DarkChild's Avatar
Mis-shifting happens because you are thinking about shifting into the next gear. Don't think, just do it. I think that my syncro is bad or my clutch is garbage. My 1-2 in the Cobalt is kind of tough and "locks" me out very often. In my Civic's I just rip it into a gear. The less you think about it, the better you get
Old 01-10-2014, 05:53 PM
  #228
I never mis-shift, just not lightning fast on the 1-2 usually. At the track I can get it done. I just never do it on the street.
Old 01-10-2014, 09:54 PM
  #229
DarkChild's Avatar
I don't like putting myself on a high horse either but I'm a really good driver too. I try to treat the Cobalt better than my other car because it is more expensive to fix. I hope that my clutch holds better than it did before
Old 01-13-2014, 10:18 AM
  #230
I try to treat mine really well too, but when it's time for it to sit down and handle some business....well, sorry bout it car
I wasn't trying to say I am the best driver out there either, but I usually do pretty well.
Old 01-13-2014, 06:49 PM
  #231
DarkChild's Avatar
There's a select few on this site that have proven they can drive and you are one of them. Your time slip proves it. I hope to make my time slip prove it too. I just need the slicks. I'm annoyed with these 2.2 60'ers. I bang every gear but I need to launch better. Problem is that the closest track to us is 2 hours away.
Old 01-14-2014, 09:42 AM
  #232
I feel your pain. Our closest track is 3 hours away, and I only get there once a year. The track I want to run at this year, which is way nicer, is 6 hours away.
Old 01-14-2014, 10:41 AM
  #233
mrbelvedere's Avatar
wot box works wonders for shifting and launching
Old 01-14-2014, 11:03 AM
  #234
I have one. Haven't used it in a couple years though. I will be on le turbo setup though. It doesn't help matters when you NLS when roasting the tires off I'll tell ya that haha!
Old 01-15-2014, 10:45 PM
  #235
DarkChild's Avatar
For now I will leave my car the way it sits. If I somehow don't manage a high 12 in the 1/4 then I will see what else I can do. Nitrous? Back on topic though. Sorry OP
Old 01-17-2014, 02:09 PM
  #236
Rent me! per hour
Area47's Avatar
that little box actually saved my clutch.
Old 01-17-2014, 03:47 PM
  #237
wot box is great. only thing that got me under a 14.0 lol
and on a blower car the 2step sounds wild!
Old 01-17-2014, 06:01 PM
  #238
DarkChild's Avatar
I was trying to see if it would build boost like a turbocharged car but it looks like it loses boost. Could that be why it gains traction? I was watching a lot of HatrickStu's videos and he doesn't fight for traction like most of us.
Old 01-17-2014, 06:04 PM
  #239
350hp is enough for mid to low 12s
ULWizSS WotBox 3k - YouTube
its a blower they don't work the same as a snail
Old 01-17-2014, 09:41 PM
  #240
armcclure's Avatar
Right. Your boost level is directly related to rpm on an sc. There is no "spool" other than the fractions of a second it takes to fill the IM with boost.
Old 01-22-2014, 08:18 PM
  #241
DarkChild's Avatar
I understand the concepts and how it works. I just don't see how a limiter can actually net you a better 60'. I know that using one on a turbocharged vehicle does really well. I'd like to see a comparison with a supercharged vehicle with no other modifications done but a wot box.
I won't be at 350 HP. I'd be lucky to see close to 300 WHP with what I've done. I know that my tuner has run a 13.0 @ 111 MPH with 273 WHP and 26xWTRQ.
I've given up with wanting to hit 11's and make this car into a drag car. It costs too much and you get nothing back from it.
I'm hoping that on a set of slicks I will personally be able to get a 1.8 60', I know it possible. If I manage to do that then I will be able to see a solid 12.7ish.
06MetallicBalt
08-17-2021 03:40 PM
deviance
11-24-2015 05:51 PM
dennis69
10-20-2015 04:49 PM
10-13-2015 09:32 PM
SSLOW06
10-01-2015 07:21 PM
Quick Reply: Installing Euthanasia Ported & Built Head. TONS OF PICS
