Installing Euthanasia Ported & Built Head. TONS OF PICS
#161
did you measure it? You have an inside mic set I am sure.
Eagle says? Then must be ok.
"Regardless of a connecting rod’s application (stock, performance or racing), prior to rebuilding or engine assembly, all rods must be inspected, measured and reconditioned before installation."
check this out.
http://www.motor.com/magazine/pdfs/012012_07.pdf
check this out.
#163
"Regardless of a connecting rods application (stock, performance or racing), prior to rebuilding or engine assembly, all rods must be inspected, measured and reconditioned before installation."
check this out.
check this out.
Oh ya i have a tool for measuring rod bores.
Im putting new small end bushings in also
#164
check this out.
check this out.
and eagle makes dam good parts just because you think they are junk don't make it so
#168
I said "measure" if its within spec then, Captain Obvious, you dont fck with it,
I said "PS its me, but I would not run anything Eagle in my motor."
thats not your motor. Not TJ's motor, MY motor.
go away, not in the mood.
PS
Tom Molnar knows his s**t
#170
tonites the nite not in the mood for dickweed statements,
PS
PS
