Installing Euthanasia Ported & Built Head. TONS OF PICS
Old 04-04-2013, 05:51 PM
  #176
armcclure's Avatar
JP might if we ask pretty please
Old 04-09-2013, 08:42 PM
  #177
ebristol's Avatar
Bump.
Old 04-09-2013, 10:51 PM
  #178
armcclure's Avatar
In light of recent events, I'm making an early head swap to my rather large head done by josh then heading back to the dyno. Stock cams though; my s2's are now in Taylor's car.
Old 04-09-2013, 11:18 PM
  #179
Powell Race Parts's Avatar
^^^ thats a relief lol you will be good.
Old 04-09-2013, 11:19 PM
  #180
South Central *********
JapEatr's Avatar
Very good
Btw OPs car is a beast at the moment
Old 04-10-2013, 11:34 AM
  #181
Rent me! per hour
Area47's Avatar
did my goodies make it in there?
Old 04-10-2013, 11:52 AM
  #182
JapEatr's Avatar
yeah.
Old 04-10-2013, 11:54 AM
  #183
Rent me! per hour
Area47's Avatar
open loop fueling.
Old 04-10-2013, 11:57 AM
  #184
Hockeyman's Avatar
she is running like a beast like Vaughn said. Only problem is with cold start warm ups. It is dumping fuel and misfiring until coolant temps reach 100-110. AFR is pegged at 10.0.1-10.5.1 during this time. When we get some time we will play around with that more.
Old 04-10-2013, 12:02 PM
  #185
JapEatr's Avatar
looks like we need the open loop settings extended until warmup is complete
  #186
jonathan923's Avatar
thats awesome! do want vids!
Old 04-10-2013, 12:27 PM
  #187
Hockeyman's Avatar
Originally Posted by ebristol
There is a lot of arguing in this thread about revving this engine to 7800 but has anyone determined it is beneficial to rev out that far with S2 cams and a ported head with the M62? Al's Cam'd/ported head made peak HP before 7,000 rpms.
Saab head. I know.
I will be on the dyno sometime in April, will report results.
Old 04-10-2013, 05:08 PM
  #188
ebristol's Avatar
Do it! Do it!
Old 04-10-2013, 06:55 PM
  #189
Do it! Do it!
Eric knows. He asks questions but knows the answer. Good move Arm your target is closer.
Old 04-10-2013, 07:48 PM
  #190
armcclure's Avatar
Yes I was not impressed at all with the zzp cams compared to their cost. They sounded cool. That was about it.
Old 04-10-2013, 09:49 PM
  #191
say what?
and here I take flak on here about how I am wrong for not embracing them? Me who installed them with the right head, the right header the right tune, TVS, got 323 whp on pump gas, made customer deliriously happy and said "I am so happy customer likes them but for me they are a non starter,
built in traction control no torque? Maybe good for 1320""
wow. this is a turn of events.
lol
actually their cost is modest for what they are, and they dialed in 100% ZZP did their homework.
Old 04-10-2013, 09:52 PM
  #192
JapEatr's Avatar
Old 04-11-2013, 12:25 AM
  #193
Vander Nars's Avatar
say what?
lol
And this is why I told Mr.B to post his proof that stage 2 cams are worth it, he expects everyone to just take his word but we have other people on this forum with a much bigger background in ecotecs saying they not worth it, i wanna see some before and after dyno sheets. Till then im not even wasting money on something that only half the people seem to like and no one has any proof they are worth the upgrade.
Old 04-11-2013, 05:13 AM
  #194
armcclure's Avatar
Don't take what I sand the wrong way. I did like them. But for what they cost compared to getting a much better cam for much less $$$ directly from comp, I think they're not worth that.
Old 04-11-2013, 05:24 AM
  #195
How is comp cams better when zzp cams are comp cams?
Old 04-11-2013, 07:07 AM
  #196
zzp cams are only comp cams ground to zzp specs.
comp cams could have something completely different released under their own name.
would be the difference.
Old 04-11-2013, 07:18 AM
  #197
armcclure's Avatar
There's a guy at comp named Matt, very smart guy who will tailor a cam set to your specific application. A set of custom grind from them totals around 500. You just have to go through the hassle of getting blanks from ced and sending to them.
The zzp cams are great for what they are. You're paying for a mild cam that just drops right in, no hassle no worries.
I never felt the massive tq loss that jp describes, but my car never spends much time down low. I imagine on a TVS vs a 2.5 m62 it's much more noticeable.
Old 04-11-2013, 07:25 AM
  #198
armcclure's Avatar
Here. Add on note- stock cams made peak power at 5900 for them.
Originally Posted by Hot Rod LSJ article
The new cam set liked 27 degrees of total timing and still generated 11 to 12 inches of idle vacuum (use a vacuum pump if operating power brakes). The peak power point jumped by 700 rpm to 6,600 rpm, where the new cams generated 265.2 hp, a gain of nearly 36 over the stockers. Likewise, torque was up about 11 numbers to 227.1 lb-ft at 3,900 rpm, a 100-rpm increase over the previous peak point. Although the engine was stronger in the midrange and top end, the gains were made at the expense of less power below 3,500 rpm.
Read more: http://www.hotrod.com/techarticles/engine/hrdp_0907_gm_ecotec_bolt_ons/viewall.html#ixzz2Q9XmEUgA
IMO, there is no way the zzp s2 cams come close to a 36hp gain over stock. And this isn't even a custom grind, just their off the shelf ecotec blower grind.
Old 04-11-2013, 07:40 AM
  #199
click
Old 04-11-2013, 07:41 AM
  #200
Administrator
Administrator
Staged07SS's Avatar
All those tests in that hot rod article were done on an engine dyno, so all their numbers were bhp not whp. 36 hp is still way high.... bhp or not.
It was a neat article, but not the most accurate.
Quick Reply: Installing Euthanasia Ported & Built Head. TONS OF PICS
