Installing fender mount meth kit.. Why does it take so long?
I've been reading on AIS website and it says for the trunk mount system it will take approx. 60-90 minutes to install. On the fender mount kit it says 2-3 hours. Why is this? Thanks.
You have to run a line from your trunk, to your engine bay...
Unless you run this line on the outside of your car, its gonna take a little while to drill some holes.
when i installed mine on my bumper i had to take the bumper off to get to the place i was mounting the pump. its a tight fit for the right placement for a drill if you have a front mount h/e. also running all the lines and getting everthing perfect did take about that long. i have a cool mist kit so wiering it up was different because i added a switch to be able to kill the power to the pump if i dont want to use it and also added an indicator light so i know when the pump is pumping
Dude are you kidding me?
The meth is mounted in your trunk.... so there for... you have to run a line from your trunk, to your engin bay...
im hoping you wanna hide this line... i was being sarcastic that you run the line on the outside of teh car (takes short amount of time)
To do it right and run about 10 feet of lines through your car will take a good couple hours...
I'm too JDM for you
Yea dude i realize that now im sorry.. lol
Im playing rock band 2 and totally was into it and just did this horrible math in my head.
i was seeing 20 - 30 min not 2-3 hours for some reason.
when i installed my AIS trunk mount (luckily i have a lift) it took me about 1.5 hours..... i really took my time and read the instruction a few times. i think it tastes longer for the fender mount because your using the windshield washer tank and you have to remove alot more. plus wiring could be alot different.
just buy my meth kit........... https://www.cobaltss.net/forums/parts-66/fs-lots-parts-stuff-150533/
