INTENSE Announces New Dyno Proven Stage Kits!
#126
Originally Posted by dstinsman56
stage 4 price = $689.99 + $299.99 to port blower($200 core charge)
You mean a $500 core charge. The $200 core charge is for the snout....
So does rob's car have the 2.5" pulley and 60lbs/hr injectors? or are they still 42.5lbs/hr?
#127
Originally Posted by Bad GTP
G.M. doesn't normally issue custom tunes for higher altitude. For example, if I want to drive my car up into the mountains, I don't need to go get my PCM reflashed at the dealership. Instead, my PCM detects the decreased barometric pressure and adjusts accordingly. All our PCM's come with a money-back offer good for seven days if you're not 100% satisfied, so feel free to give us a try.
there are quite a few STi and WRX shops here that offer high altitude tuning.... so for me to believe that an intense kit works flawlessly at 7k ft takes a lot of convincing.....
now, if i am being ignorant. or i am incorrect, plz point this out and i would be more than happy to order a kit from Intense. i support you guys 100%. the money back offer helps, but i would rather not go thru the hassle if the tune does not work where i live.
on that note, any of you guys at Intense feel like flying up to colorado (via your expense) and tuning my car for free.... so you can get a baseline on altitude tuning? (j/k) :P
#128
Originally Posted by ReMz
i would LOVE to believe that. but ppl that come here from sea level have some major problems with their cars (assuming they are custom tuned)...... there is less oxygen and a significant hp decrease.
#129
Our Stage 1 kit includes a 3.30" pulley, which is almost identical to stock. So boost is the same as stock. We always try to list our numbers conseravtively. So we only publish 11 psi for two reasons. First, boost is lower at higher altitudes. And second, as you get to know us better you'll come to understand that we like to underpromise and overdeliver.
ah
#130
No one has really answered this question yet. Is there anyways other than shipping off my stock ECU to get around the dealer having to do the CASE procedure? I don't want them touching the ECU once it has been programmed because I really don't trust them. And I don't want them knowing the car is modified either.
#131
WOT
#132
once again im just trying to find out what the downtime will be cause im shipping my parts so i dont have to recalibrate pcm crank sensor. can you over night ship parts? also how do i get stage 5 tune specified in my order.
#135
What the hell is a CASE learn can someone tell me, is it when you unplug the battery for like 10 minutes and the hook it back up or what? Im thinking about getting the stage 3 kit.
#137
would you only reccommend stage 5 for non daily drivers? or will it be fine as long as you dont boost it constently? im looking to get it but alot of people are getting lower stages, was just wondering why? why not go all the way?
#138
#142
What is the possiblity of being able to purchase a "flashed" ECM with whichever stage you prefer, "ala carte"? I mean if one were to have the injectors and pulley already and just wanted to get the ECM.
#143
this case/pcm is kinda getting me..
so if we send you our pcm to be tuned then we will only have to do the "in drive way" procedure when we get it back... and if we get a PCM from you and we send you ours as a core... we will have to take it to GM for them to adjust it?.. just need this clarified
#147
BUT If you get a new PCM from Intense, then it will need to have the crankshaft variation relearn completed so the stored/learned value corrrectly matches the amount of error that exists in YOUR car. Most "trade grade" scan tools can do it. So it doesnt have to be a dealership. Look for shops that say they can do GM SPS (Service Programming) as then they likely have the neccessary experience.
Originally Posted by Joewit
Does 87$ seem like a good price for the case learn thing.
OR
Find someone in your area with HP Tuners as it's scanner mode can do the CASE relearn on any LSJ
WOT
#148
Ordered the Stage 3 kit last friday it came in today. I will put it in tonight and let every one know how good it is. I wont have the pulley on tonight, i'm still trying to find a puller, but the PCM, injectors, and stuff will be in tonight.
#149
quick question: now that you,ve completed the stage kits for the cobalt ss and ion redline, do you plan on making similar products for the 2.2 ecotec cavalier or sunfire with the GM s/c kit ?
