Just bought an aftermarket SS
Old 03-09-2008, 10:39 PM
  #101
heyitsmikey1987's Avatar
Originally Posted by bender
Hi, my name is Michael, and I am new to this forum and to the Cobalts. I have over 6 years experience with turbocharged DSM, and currently own an 11-sec 1997 Eclipse GSX (pump gas and automatic). I was looking for a new daily driver and decided to get a Cobalt SS. When I got to the dealership selling it, I noticed that the car was not stock. Most of the stuff I can see for myself (Magnaflow exhaust, zzp header (or so it looks), zzp downpipe, scan gauge, aem wideband, and a super heavy clutch. Upon closer inspection I noticed solid motor mounts and an engine damper on the passenger side. I had a couple of questions I would like answered to further my knowledge of these cars.
1. Its running 20 lbs of boost, and has an intense racing sticker. Does this mean it has the stage 5 kit or just a smaller pulley?
2. It idles at 950-975 rpms, and has a slight lobe. Is this the stock idle?
3. Are there any issues I should look out for? I have done some reading and have found there are some problems with the electronic steering. Anything else?
I'm sure there will be more in the future, but this is all I can think of now. Sorry if this is in the wrong place, but it looks like this is where most of the knowledgeable people would be.
Thanks,
Mike.
i'm running 20 lbs of boost and my idles like that my car is fine
Old 03-09-2008, 11:28 PM
  #102
bender's Avatar
You car idles under a grand too? What tune do you have?
Old 03-13-2008, 08:37 PM
  #103
bender's Avatar
Well, I did a full pull today through all the gears, and I noticed that it runs higher than 20 lbs of boost on upper end. By extrapolating the number, it looks to be close to 25. Next time I'll check with the digital scan gauge. Also, when I got the car, I noticed that if it idles for too long, it seems to run on 3 cylinders. It runs like this until I clear the DTC's. I wrote them down and heres what they are: 20036, 20140, 20141, 20507. I looked and couldn't find any information on these numbers.
Old 03-21-2008, 03:19 PM
  #104
SS33's Avatar
I got signed up on xceedspeed.com,,, sn = SS33 over there too
Pretty sweet forum
Old 03-21-2008, 04:05 PM
  #105
dstinsman56's Avatar
All dtc's
https://www.cobaltss.net/forums/problems-service-maintenance-69/cobalt-dtc-thread-merged-12015/
Old 03-21-2008, 06:25 PM
  #106
C0baltWithM0ds's Avatar
you should get it dynoed just to see where the car is at
Old 03-21-2008, 06:41 PM
  #107
Rent me! per hour
Area47's Avatar
if you're car idles above 850. someone is trying to mask an issue that they screwed up
Old 03-21-2008, 09:23 PM
  #108
bender's Avatar
Orrrrrrrrrrrrrrrrrr...... it just idles fast.
hahaha.
Either way, no one knows what these codes mean? I put on the Fujita F5 cold air intake, and haven't seen the problem since. I was hoping the extra air would lean the car out. I haven't done too many wot pulls with it since the install, but I'm hoping its better than the 10:1 that it was running before. What is a good air fuel for these cars? I know its different for each car because of air density in the area, different heat exchangers, different amounts of boost, etc, etc, but is 12.5:1 a good number to shoot for at WOT? This will be on 93 octane.
Old 03-21-2008, 09:29 PM
  #109
Rattlesnake Race Shop
USMCFieldMP's Avatar
I'd check those numbers again... those aren't coming up in my Mac Tools DTC handbook.
Old 03-22-2008, 12:11 PM
  #110
bender's Avatar
Well thats off the interceptor gauge. When you compare them to other diagnostics, the 2 = P2, so P20036, P20140, P20141, P20507. Thats if I remember correctly from when I glanced over the gauge pdf.
Old 03-22-2008, 12:16 PM
  #111
Rent me! per hour
Area47's Avatar
hmmm.
do yourself a favor. compression test and leak down test asap.
  #112
WSFrazier's Avatar
From those codes, I can tell ya that car has a cat delete probably. Also, you might wanna raise the idle till you figure out what is wrong with it.
Old 03-22-2008, 12:22 PM
  #113
Rent me! per hour
Area47's Avatar
take the 2 off there
then you have the actual code
Old 03-22-2008, 01:00 PM
  #114
bender's Avatar
Well I know the car has a cat delete, and the idle is high enough. If anything, I want to lower it. As for a compression / leak down test, I just got clobbered with snow last night. I need to wait for it to melt a little bit so I can pull the eclipse out of the garage.
Old 03-22-2008, 01:04 PM
  #115
Omnigear's Avatar
If I got a heat exchanger I would probably go with something custom that I'd fab up. I'm not big on the whole "prefabbed" kits. I use methanol injection in my eclipse, and would rather not have to check the reservoir every week in a daily driver. I have a bigger problem now though. The insurance company that I'm using lied to me and told me a different quote before I bought the car. I just got the insurance the new quote is 2800 a year. What do you guys pay a year?
i use costco insurance
3 cars for
3200 a year max coverage
250 deductable.
if only my wife stops getting ticket
it would be much lower
Old 03-22-2008, 07:02 PM
  #116
bender's Avatar
Yeah.. The big 3 is no longer car companies.. it's government, big oil, and insurance companies.
Old 03-23-2008, 02:08 AM
  #117
rukkee's Avatar
In GM's service information it has a list of all DTC's , it jumps right on past any P19XX and P20XX numbers and jumps from a P18XX right to P21XX in the list. . Here's how it goes in SI.
P1818
Transmission Fluid Pressure (TFP) Valve Position Switch Indicates Drive without Drive Ratio
TCM
P2101
Control Module Throttle Actuator Position Performance
ECM, PCM
Old 03-23-2008, 01:24 PM
  #118
bender's Avatar
Could you just look under appendix P2, then look at codes 0036, 0140, 0141, 0507?
Old 03-23-2008, 01:38 PM
  #119
rukkee's Avatar
Here's the whole list out of GM SI , I didn't edit it at all so it looks a little jumbled . Here's the format below .
DTC
DTC Descriptor
Module That Sets the DTC
Diagnostic Procedure
Diagnostic Trouble Code (DTC) List - Vehicle
This master DTC list includes all applicable DTCs in alphanumeric order with descriptors.
The GMLAN modules on this vehicle also support DTC Symptom information. Refer to DTC Symptom Description for additional information on DTC Symptoms.
B0012
Driver Frontal Deployment Loop Stage 1
SDM
DTC B0012 or B0013
B0013
Driver Frontal Deployment Loop Stage 2
SDM
DTC B0012 or B0013
B0015
Left Front Seat Belt Pretensioner Deployment
SDM
DTC B0015
B0016
Left Roof Rail Deployment Loop
SDM
DTC B0016
B0019
Passenger Frontal Deployment Loop Stage 1
SDM
DTC B0019 or B0020
B0020
Passenger Frontal Deployment Loop Stage 2
SDM
DTC B0019 or B0020
B0022
Right Front Seat Belt Pretensioner Deployment
SDM
DTC B0022
B0023
Right Roof Rail Deployment Loop
SDM
DTC B0023
B0052
Deployment Commanded
SDM
DTC B0052 or B0053
B0053
Deployment Commanded with Loop DTCs present
SDM
DTC B0052 or B0053
B0081
Passenger Presence System
SDM
DTC B0081
B0083
Front End Sensor
SDM
DTC B0083
B0085
Left Front Side Impact Sensor
SDM
DTC B0085 or B0086
B0086
Right Front Side Impact Sensor
SDM
DTC B0085 or B0086
B0158
Outside Air Temperature Sensor
BCM
DTC B0158
HVAC
DTC B0158
B0285
Electric Rear Defrost Circuit Low
BCM
DTC B0285
B0685
Security System Indicator Circuit
BCM, IPC
DTC B0685
B1000
Electronic Control Unit (ECU) Performance
BCM, DRR, IPC, Radio, SDM, VCIM
DTC B1000
B1001
Option Configuration Error
BCM
DTC B1001
DRR, Radio
DTC B1001
SDM
DTC B1001
VCIM
DTC B1001
B1004
Electronic Control Unit Identification Circuit
BCM, DRR, IPC
DTC B1004
B1009
EEPROM Checksum Mismatch
BCM, Radio
DTC B1009
B1019
System Configuration Error
SDM
DTC B1019
B1025
LF Audio Output Circuit
Radio
DTC B1025, B1035, B1045, or B1055
B1035
RF Audio Output Circuit
Radio
B1045
LR Audio Output Circuit
Radio
B1055
RR Audio Output Circuit
Radio
B1325
Device Power 1 Circuit
BCM, IPC, Radio, SDM
DTC B1325
B1370
Device Ignition 1 Circuit
BCM
DTC B1370
SDM
DTC B1370
B1380
Device Ignition ACCESSORY Circuit
BCM
DTC B1380
B1441
Device Ignition OFF, RUN, and CRANK Circuit
BCM
DTC B1441
B1480
Battery Rundown Protection Circuit
BCM
DTC B1480
B1516
Battery Current Sensor Performance
BCM
DTC B1516
B1517
Battery Voltage
BCM
DTC B1517
B2455
Cellular Phone Microphone Circuit Malfunction
OnStarŽ VCIM
DTC B2455
B2470
Cellular Phone Antenna Circuit Malfunction
OnStarŽ VCIM
DTC B2470
B2476
Cellular Phone Select Service Switch Malfunction
OnStarŽ VCIM
DTC B2476
B2482
Cellular Phone Select Switch Range/Performance
OnStarŽ VCIM
DTC B2482
B2483
GPS Sensor Circuit Low
OnStarŽ VCIM
DTC B2483 or B2484
B2484
GPS Sensor Circuit Open
OnStarŽ VCIM
DTC B2483 or B2484
B2530
Front Fog Lamps Control Circuit
BCM
DTC B2530
B2580
Headlamp High Beam Control Circuit
BCM
DTC B2580
B2625
Display Dimming Pulse Width Modulation (PWM) Output Circuit
BCM
DTC B2625
B2645
Ambient Light Sensor Circuit
BCM
DTC B2645
B2705
Gearshift Unlock Circuit
BCM
DTC B2705
B2750
Horn Relay Coil Circuit
BCM
DTC B2750
B2961
Key In Ignition Circuit
BCM
DTC B2961
B3031
Security System Controller In Learn Mode
BCM
DTC B3031
B3055
No Transponder Modulation or No Transponder
BCM
DTC B3055
B3060
Unprogrammed Transponder Identification Code Received
BCM
DTC B3060
B3100
Keyless Entry Data Link Circuit
BCM
DTC B3100
B3109
Keyless Entry Transmitter Low Battery
BCM
DTC B3109
B3127
Left Front Door Only Unlock Circuit Low
BCM
DTC B3127
B3132
All Door Unlock Circuit Low
BCM
DTC B3132
B3137
All Door Lock Circuit Low
BCM
DTC B3137
B3265
Trunk Release Output Circuit
BCM
DTC B3265
B3715
Front Wiper Relay Drive Circuit
BCM
DTC B3715, B3716, B3717, B3718, or B3719
B3716
Front Wiper Relay Drive Circuit Range/Performance
BCM
B3717
Front Wiper Relay Drive Circuit Low
BCM
B3718
Front Wiper Relay Drive Circuit High
BCM
B3719
Front Wiper Relay Drive Circuit Open
BCM
B3794
Cruise Control Function Request Circuit
BCM
DTC B3794
B3903
Stop Lamp Relay Circuit
BCM
DTC B3903
B3935
Transponder Authentication Error
BCM
DTC B3935
B3948
Left Front Turn Signal Circuit
BCM
DTC B3948
B3949
Right Front Turn Signal Circuit
BCM
DTC B3949
B3950
Left Rear Turn Signal Circuit
BCM
DTC B3950
B3951
Right Rear Turn Signal Circuit
BCM
DTC B3951
B3976
Unconfigured Transponder
BCM
DTC B3976
C0000
Vehicle Speed Information Circuit
PSCM
DTC C0000
C0035
LF Wheel Speed Sensor Circuit
EBCM
DTC C0035-C0050
C0040
RF Wheel Speed Sensor Circuit
EBCM
DTC C0035-C0050
C0045
LR Wheel Speed Sensor Circuit
EBCM
DTC C0035-C0050
C0050
RR Wheel Speed Sensor Circuit
EBCM
DTC C0035-C0050
C0110
Pump Motor Circuit
EBCM
DTC C0110
C0116
Pump Motor Relay Circuit
EBCM
DTC C0116
C0121
Valve Relay Circuit
EBCM
DTC C0121
C0161
ABS/TCS Brake Switch Circuit
EBCM
DTC C0161
C0176
System Thermal Error
PSCM
DTC C0176
C0220
Left Front ABS Channel in Release Too Long
EBCM
DTC C0220-C0229
C0221
Right Front ABS Channel in Release Too Long
EBCM
DTC C0220-C0229
C0228
Left Rear ABS Channel in Release Too Long
EBCM
DTC C0220-C0229
C0229
Right Rear ABS Channel in Release Too Long
EBCM
DTC C0220-C0229
C0240
PCM Traction Control Not Allowed
EBCM
DTC C0240
C0242
PCM Indicated TCS Malfunction
EBCM
DTC C0242
C0281
Dynamic Rear Proportioning (DRP) Performance
EBCM
DTC C0281 or C081
C0475
Electric Steering Motor Circuit
PSCM
DTC C0475
C0545
Steering Wheel Torque Input Sensor
PSCM
DTC C0545
C0550
EBCM
DTC C0550
or
DTC C0550
C0552
Improper Shutdown
EBCM
DTC C0552
C0561
System Disabled Information Stored
EBCM
DTC C0561
C0845
PSCM
DTC C0845
C0895
Device Voltage
PSCM
DTC C0895
C0899
Device Voltage Low
EBCM
DTC C0899
C0900
Device Voltage High
EBCM
DTC C0900
P0010
Intake Camshaft Position (CMP) Actuator Solenoid Control Circuit
ECM
DTC P0010, P0011, P0013, or P0014
P0011
Intake Camshaft Position (CMP) System Performance
ECM
P0013
Exhaust Camshaft Position (CMP) Actuator Solenoid Control Circuit
ECM
P0014
Exhaust Camshaft Position (CMP) System Performance
ECM
P0016
Crankshaft Position (CKP) - Intake Camshaft Position (CMP) Correlation
ECM
DTC P0016
P0017
Crankshaft Position (CKP) - Exhaust Camshaft Position (CMP) Correlation
ECM
DTC P0017 for the 2.0L engine
OR
DTC P0017 for the 2.4L engine
P0030
HO2S Heater Control Circuit Sensor 1
ECM, PCM
• DTC P0030 or P0036 for the 2.0L engine
• DTC P0030 or P0036 for the 2.2L (L61) engine
• DTC P0030, P0036, P0053, P0054, P0135, or P0141 for the 2.4L engine
P0033
Supercharger Bypass Valve Solenoid Control Circuit
PCM
DTC P0033
P0036
HO2S Heater Control Circuit Sensor 2
ECM, PCM
P0053
HO2S Heater Resistance Sensor 1
ECM
P0054
HO2S Heater Resistance Sensor 2
ECM
P0068
Throttle Body Airflow Performance
ECM, PCM
• DTC P0068 for the 2.0L engine
• DTC P0068 for the 2.2L (L61) engine
• DTC P0068 or P0121 for the 2.4L engine
P0069
Manifold Absolute Pressure - Barometric Pressure Correlation
PCM
DTC P0069
P0097
Intake Air Temp Low Voltage
PCM
DTC P0097
P0098
Intake Air Temperature (IAT) Sensor 2 Circuit High Voltage
PCM
DTC P0098
P0101
Mass Air Flow (MAF) Sensor Performance
ECM, PCM
• DTC P0101 for the 2.0L engine
• DTC P0101 for the 2.2L (L61) engine
• DTC P0101 or P1101 for the 2.4L engine
P0102
Mass Air Flow (MAF) Sensor Circuit Low Frequency
ECM, PCM
• DTC P0102 for the 2.0L engine
• DTC P0102 for the 2.2L (L61) engine
• DTC P0102 or P0103 for the 2.4L engine
P0103
Mass Air Flow (MAF) Sensor Circuit High Frequency
ECM, PCM
• DTC P0103 for the 2.0L engine
• DTC P0103 for the 2.2L (L61) engine
P0106
Manifold Absolute Pressure (MAP) Sensor Performance
ECM, PCM
• DTC P0106 for the 2.0L engine
• DTC P0106
• DTC P0106 for the 2.4L engine
P0107
Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage
ECM, PCM
• DTC P0107 for the 2.0L engine
• DTC P0107 for the 2.2L (L61) engine
• DTC P0107 or P0108 for the 2.4L engine
P0108
Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage
ECM, PCM
• DTC P0108 for the 2.0L engine
• DTC P0108 for the 2.2L (L61) engine
P0112
Intake Air Temperature (IAT) Sensor 1 Circuit Low Voltage
ECM, PCM
• DTC P0112 for the 2.0L engine
• DTC P0112 for the 2.2L (L61) engine
• DTC P0112 or P0113 for the 2.4L engine
P0113
Intake Air Temperature (IAT) Sensor 1 Circuit High Voltage
ECM, PCM
• DTC P0113 for the 2.0L engine
• DTC P0113 for the 2.2L (L61) engine
P0116
Engine Coolant Temperature (ECT) Sensor Performance.
ECM
DTC P0116 for the 2.2L (L61) engine
or
DTC P0116 for the 2.4L engine
P0117
Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage
ECM, PCM
• DTC P0117 for the 2.0L engine
• DTC P0117 for the 2.2L (L61) engine
• DTC P0117 or P0118 for the 2.4L engine
P0118
Engine Coolant Temperature (ECT) Sensor Circuit High Voltage
ECM, PCM
• DTC P0118 for the 2.0L engine
• DTC P0118 for the 2.2L (L61) engine
P0120
Throttle Position (TP) Sensor 1 Circuit
ECM, PCM
• DTC P0120 for the 2.0L engine
• DTC P0120 for the 2.2L (L61) engine
• DTC P0120, P0122, P0123, P0220, P0222, P0223, or P2135 for the 2.4L engine
P0121
Throttle Position (TP) Sensor 1 Performance
ECM, PCM
• DTC P0121 for the 2.0L engine
• DTC P0121 for the 2.2L (L61) engine
P0122
Throttle Position (TP) Sensor 1 Circuit Low Voltage
ECM, PCM
• DTC P0122 for the 2.0L engine
• DTC P0122 for the 2.2L (L61) engine
P0123
Throttle Position (TP) Sensor 1 Circuit High Voltage
ECM, PCM
• DTC P0123 for the 2.0L engine
• DTC P0123 for the 2.2L (L61) engine
P0125
Engine Coolant Temperature (ECT) Insufficient for Closed Loop Fuel Control
ECM, PCM
• DTC P0125 for the 2.0L engine
• DTC P0125 for the 2.2L (L61) engine
• DTC P0125 or P0128 for the 2.4L engine
P0128
Engine Coolant Temperature (ECT) Below Thermostat Regulating Temperature
ECM, PCM
• DTC P0128 for the 2.0L engine
• DTC P0128 for the 2.2L (L61) engine
P0130
HO2S Circuit Sensor 1
ECM, PCM
DTC P0130 for the 2.0L engine
or
DTC P0130 for the 2.2L (L61) engine
P0131
HO2S Circuit Low Voltage Sensor 1
ECM, PCM
• DTC P0131 for the 2.0L engine
• DTC P0131 for the 2.2L (L61) engine
• DTC P0131, P0132, P0137, P0138, P2A00, or P2A01 for the 2.4L engine
P0132
HO2S Circuit High Voltage Sensor 1
ECM, PCM
• DTC P0132 for the 2.0L engine
• DTC P0132 for the 2.2L (L61) engine
P0133
HO2S Slow Response Sensor 1
ECM, PCM
• DTC P0133 for the 2.0L engine
• DTC P0133 for the 2.2L (L61) engine
• DTC P0133, P0134, P0140, or P1133 for the 2.4L engine
P0134
HO2S Circuit Insufficient Activity Sensor 1
ECM, PCM
• DTC P0134 for the 2.0L engine
• DTC P0134 for the 2.2L (L61) engine
P0135
HO2S Heater Performance Sensor 1
ECM, PCM
• DTC P0135 for the 2.0L engine
• DTC P0135 for the 2.2L (L61) engine
P0136
HO2S Circuit Sensor 2
ECM, PCM
DTC P0136 for the 2.0L engine
or
DTC P0136 for the 2.2L (L61) engine
P0137
HO2S Circuit Low Voltage Sensor 2
ECM, PCM
• DTC P0137 for the 2.0L engine
• DTC P0137 for the 2.2L (L61) engine
P0138
HO2S Circuit High Voltage Sensor 2
ECM, PCM
• DTC P0138 for the 2.0L engine
• DTC P0138 for the 2.2L (L61) engine
P0140
HO2S Circuit Insufficient Activity Sensor 2
ECM, PCM
• DTC P0140 for the 2.0L engine
• DTC P0140 for the 2.2L (L61) engine
P0141
HO2S Heater Performance Sensor 2
ECM, PCM
• DTC P0141 for the 2.0L engine
• DTC P0141 for the 2.2L (L61) engine
P0171
Fuel Trim System Lean
ECM, PCM
• DTC P0171 for the 2.0L engine
• DTC P0171 for the 2.2L (L61) engine
• DTC P0171 or P0172 for the 2.4L engine
P0172
Fuel Trim System Rich
ECM, PCM
• DTC P0172 for the 2.0L engine
• DTC P0172 for the 2.2L (L61) engine
P0201
Injector 1 Control Circuit
ECM, PCM
• DTC P0201, P0202, P0203, or P0204 for the 2.0L engine
• DTC P0201, P0202, P0203, or P0204 for the 2.2L (L61) engine
• DTC P0201, P0202, P0203, or P0204 for the 2.4L engine
P0202
Injector 2 Control Circuit
ECM, PCM
P0203
Injector 3 Control Circuit
ECM, PCM
P0204
Injector 4 Control Circuit
ECM, PCM
P0218
Transmission Fluid Overtemperature
TCM
DTC P0218
P0220
Throttle Position (TP) Sensor 2 Circuit
ECM, PCM
• DTC P0220 for the 2.0L engine
• DTC P0220 for the 2.2L (L61) engine
P0222
Throttle Position (TP) Sensor 2 Circuit Low Voltage
ECM, PCM
• DTC P0222 for the 2.0L engine
• DTC P0222 for the 2.2L (L61) engine
P0223
Throttle Position (TP) Sensor 2 Circuit High Voltage
ECM, PCM
• DTC P0223 for the 2.0L engine
• DTC P0223 for the 2.2L (L61) engine
P0230
Fuel Pump Relay Control Circuit
ECM, PCM
• DTC P0230 for the 2.0L engine
• DTC P0230 for the 2.2L engine
• DTC P0230 for the 2.4L engine
P023A
Charge Air Cooler (CAC) Coolant Pump Relay Control Circuit
PCM
DTC P023A
P0300
Engine Misfire Detected
ECM, PCM
• DTC P0300 for the 2.0L engine
• DTC P0300 for the 2.2L (L61) engine
• DTC P0300 for the 2.4L engine
P0315
Crankshaft Position (CKP) System Variation Not Learned
ECM, PCM
• DTC P0315 for the 2.0L engine
• DTC P0315 for the 2.2L (L61) engine
• DTC P0315 for the 2.4L engine
P0324
Knock Sensor (KS) Module Performance
ECM
DTC P0324, P0325, P0326, P0327, or P0328 for the 2.4L engine
P0325
ECM, PCM
• DTC P0325 for the 2.0L engine
• DTC P0325 for the 2.2L (L61) engine
• DTC P0324, P0325, P0326, P0327, or P0328
P0326
Knock Sensor (KS) Performance
ECM, PCM
• DTC P0326 for the 2.0L engine
• DTC P0326 for the 2.2L (L61) engine
P0327
Knock Sensor (KS) Circuit
ECM, PCM
• DTC P0327 for the 2.0L engine
• DTC P0327 for the 2.2L (L61) engine
P0328
ECM
P0335
Crankshaft Position (CKP) Sensor Circuit
ECM, PCM
• DTC P0335 for the 2.0L engine
• DTC P0335 for the 2.2L (L61) engine
• DTC P0335 for the 2.4L engine
P0336
Crankshaft Position (CKP) Sensor Performance
ECM, PCM
• DTC P0336 for the 2.0L engine
• DTC P0336 for the 2.2L (L61) engine
• DTC P0336 for the 2.4L engine
P0340
Intake Camshaft Position (CMP) Sensor Circuit
ECM, PCM
• DTC P0340 for the 2.0L engine
• DTC P0340 for the 2.2L (L61) engine
• DTC P0340, P0341, P0365, or P0366 for the 2.4L engine
P0341
Camshaft Position (CMP) Sensor Performance
ECM, PCM
• DTC P0341 for the 2.0L engine
• DTC P0341 for the 2.2L (L61) engine
P0351
Ignition Coil 1 Control Circuit
ECM, PCM
DTC P0351-P0354 for the 2.4L engine
OR
DTC P0351-P0354 for the 2.0L engine
P0352
Ignition Coil 2 Control Circuit
ECM, PCM
OR
P0353
Ignition Coil 3 Control Circuit
ECM, PCM
OR
P0354
Ignition Coil 4 Control Circuit
ECM, PCM
OR
P0365
Exhaust Camshaft Position (CMP) Sensor Circuit
ECM
P0366
Exhaust Camshaft Position (CMP) Sensor Performance
ECM
P0411
Secondary Air Injection (AIR) System Incorrect Air Flow Detected
ECM
DTC P0411
P0412
Secondary Air Injection (AIR) Solenoid Control Circuit
ECM
DTC P0412
P0418
Secondary Air Injection (AIR) Pump Control Circuit
ECM
DTC P0418
P0420
Catalyst System Low Efficiency
ECM, PCM
• DTC P0420 for the 2.0L engine
• DTC P0420 for the 2.2L (L61) engine
• DTC P0420 for the 2.4L engine
P0442
Evaporative Emission (EVAP) System Small Leak Detected
ECM, PCM
• DTC P0442 for the 2.0L engine
• DTC P0442 for the 2.2L (L61) engine
• DTC P0442 for the 2.4L engine
P0443
Evaporative Emission (EVAP) Purge Solenoid Control Circuit
ECM, PCM
• DTC P0443 for the 2.0L engine
• DTC P0443 for the 2.2L (L61) engine
• DTC P0443 or P0449 for the 2.4L engine
P0446
Evaporative Emission (EVAP) Vent System Performance
ECM, PCM
• DTC P0446 for the 2.0L engine
• DTC P0446 for the 2.2L (L61) engine
• DTC P0446 for the 2.4L engine
P0449
Evaporative Emission (EVAP) Vent Solenoid Control Circuit
ECM, PCM
• DTC P0449 for the 2.0L engine
• DTC P0449 for the 2.2L (L61) engine
P0451
Fuel Tank Pressure (FTP) Sensor Performance
ECM, PCM
• DTC P0451 for the 2.0L engine
• DTC P0451 for the 2.2L (L61) engine
• DTC P0451, P0452, P0453, or P0454 for the 2.4L engine
P0452
Fuel Tank Pressure (FTP) Sensor Circuit Low Voltage
ECM, PCM
• DTC P0452 for the 2.0L engine
• DTC P0452 for the 2.2L (L61) engine
P0453
Fuel Tank Pressure (FTP) Sensor Circuit High Voltage
ECM, PCM
• DTC P0453 for the 2.0L engine
• DTC P0453 for the 2.2L (L61) engine
P0454
Fuel Tank Pressure (FTP) Sensor Intermittent
ECM, PCM
• DTC P0454 for the 2.0L engine
• DTC P0454 for the 2.2L (L61) engine
P0455
Evaporative Emission (EVAP) System Large Leak Detected
ECM, PCM
• DTC P0455 for the 2.0L engine
• DTC P0455 for the 2.2L (L61) engine
• DTC P0455 for the 2.4L engine
P0461
Fuel Level Sensor Performance
ECM, PCM
DTC P0461
P0462
Fuel Level Sensor Circuit Low Voltage
ECM, PCM
DTC P0462
P0463
Fuel Level Sensor Circuit High Voltage
ECM, PCM
DTC P0463
P0464
Fuel Level Sensor Circuit Intermittent
ECM, PCM
DTC P0464
P0480
Cooling Fan Relay 1 Control Circuit
ECM, PCM
DTC P0480, P0481, or P0482
P0481
Cooling Fan Relay 2 Control Circuit
ECM, PCM
P0482
Cooling Fan Relay 3 Control Circuit
ECM, PCM
P0496
Evaporative Emission (EVAP) System Flow During Non-Purge
ECM, PCM
• DTC P0496 for the 2.0L engine
• DTC P0496 for the 2.2L (L61) engine
• DTC P0496 for the 2.4L engine
P0502
Vehicle Speed Sensor (VSS) Circuit Low Voltage
ECM, PCM
DTC P0502 for the Getrag 5 Speed transmission
or
DTC P0502 for the MU3 transaxle
P0503
Vehicle Speed Sensor (VSS) Circuit Intermittent
ECM, PCM
DTC P0503 for the Getrag 5 Speed transmission
or
DTC P0503 for the MU3 transaxle
P0506
Idle Speed Low
ECM, PCM
• DTC P0506 for the 2.0L engine
• DTC P0506 for the 2.2L (L61) engine
• DTC P0506 or P0507 for the 2.4L engine
P0507
Idle Speed High
ECM, PCM
• DTC P0507 for the 2.0L engine
• DTC P0507 for the 2.2L (L61) engine
P0520
Engine Oil Pressure (EOP) Sensor Circuit
ECM, PCM
DTC P0520
P0532
(A/C) Air Conditioning Pressure Sensor Circuit Low Voltage
ECM, PCM
DTC P0532 or P0533
P0533
(A/C) Air Conditioning Pressure Sensor Circuit High Voltage
ECM, PCM
DTC P0532 or P0533
P0562
System Voltage Low
ECM, PCM
DTC P0562
TCM
DTC P0562
P0563
System Voltage High
ECM, PCM
DTC P0563
TCM
DTC P0563
P0575
Cruise Control Switch Signal Circuit
ECM, PCM
DTC P0575
P0601
Control Module Read Only Memory (ROM)
ECM, PCM
• DTC P0601, P0602, P0603, P0604, P0605, P0606, P0607, P060E, P1600, P1621, P1627, P1681, P1683, or P2610 for the 2.0L engine
• DTC P0601, P0602, P0603, P0604, P0605, P0606, P0607, P060E, P1600, P1621, P1627, P1681, P1683, or P2610 for the 2.2L (L61) engine
• DTC P0601, P0602, P0603, P0604, P0605, P0606, P0607, P060E, P062F, P1600, P1621, P1627, P1681, P1683, or P2610 for the 2.4L engine
Transmission Control Module (TCM) Read Only Memory (ROM)
TCM
DTC P0601, P0602, P0603, or P0604
P0602
Control Module Not Programmed
ECM, PCM
Transmission Control Module (TCM) Not Programmed
TCM
P0603
Control Module Long Term Memory Reset
ECM, PCM
Transmission Control Module (TCM) Long Term Memory Reset
TCM
P0604
Control Module Random Access Memory (RAM)
ECM, PCM
Transmission Control Module (TCM) Random Access Memory (RAM)
TCM
P0606
Control Module Internal Performance
ECM, PCM
P0607
Control Module Performance
ECM, PCM
or
P060D
Control Module Accelerator Pedal Position (APP) System Performance
ECM
DTC P060D for the 2.2L engine
or
DTC P060D for the 2.4L engine
P062F
Control Module Long Term Memory Performance
ECM
Transmission Control Module (TCM) Long Term Memory Performance
TCM
DTC P062F
P0621
Generator L-Terminal Circuit
ECM, PCM
DTC P0621
P0622
Generator F-Terminal Circuit
ECM, PCM
DTC P0622
P0641
5-Volt Reference 1 Circuit
ECM, PCM
• DTC P0641 for the 2.0L engine
• DTC P0641 for the 2.2L (L61) engine
• DTC P0641 or P0651 for the 2.4L engine
P0645
Air Conditioning (A/C) Clutch Relay Control Circuit
ECM, PCM
DTC P0645
P0650
Malfunction Indicator Lamp (MIL) Control Circuit
ECM, PCM
• DTC P0650 for the 2.0L engine
• DTC P0650 for the 2.2L (L61) engine
• DTC P0650 for the 2.4L engine
P0651
5-Volt Reference 2 Circuit
ECM, PCM
• DTC P0651 for the 2.0L engine
• DTC P0651 for the 2.2L (L61) engine
P0685
Engine Controls Ignition Relay Control Circuit
ECM
DTC P0685, P0689, or P0690
P0689
Engine Controls Ignition Relay Feedback Circuit Low Voltage
ECM
P0690
Engine Controls Ignition Relay Feedback Circuit High Voltage
ECM
P0700
Transmission Control Module (TCM) Requested MIL Illumination
ECM
DTC P0700 for the 2.2L (L61) engine
or
DTC P0700 or P1700 for the 2.4L engine
P0705
Transmission Range (TR) Switch Circuit
TCM
DTC P0705
P0711
Transmission Fluid Temperature (TFT) Sensor Performance
TCM
DTC P0711
P0712
Transmission Fluid Temperature (TFT) Sensor Circuit Low Voltage
TCM
DTC P0712
P0713
Transmission Fluid Temperature (TFT) Sensor Circuit High Voltage
TCM
DTC P0713
P0716
Input Speed Sensor Performance
TCM
DTC P0716
P0717
Input Speed Sensor Circuit Low Voltage
TCM
DTC P0717
P0719
Brake Switch Circuit Low Voltage
ECM, PCM
DTC P0719
TCM
DTC P0719
P0722
Output Speed Sensor Circuit Low Voltage
TCM
DTC P0722
P0723
Output Speed Sensor Circuit Intermittent
TCM
DTC P0723
P0724
Brake Switch Circuit High Voltage
ECM, PCM
DTC P0724
TCM
DTC P0724
P0741
Torque Converter Clutch (TCC) System - Stuck Off
TCM
DTC P0741
P0742
Torque Converter Clutch (TCC) System - Stuck On
TCM
DTC P0742
P0751
1-2 Shift Solenoid (SS) Valve Performance - No First or Fourth Gear
TCM
DTC P0751
P0752
1-2 Shift Solenoid (SS) Valve Performance - No Second or Third Gear
TCM
DTC P0752
P0756
2-3 Shift Solenoid (SS) Valve Performance - No First or Second Gear
TCM
DTC P0756
P0757
2-3 Shift Solenoid (SS) Valve Performance - No Third or Fourth Gear
TCM
DTC P0757
P0833
Clutch Pedal Switch 2 Circuit
ECM, PCM
DTC P0833
P0842
Transmission Fluid Pressure (TFP) Sensor Circuit Low Voltage
TCM
DTC P0842
P0843
Transmission Fluid Pressure (TFP) Sensor Circuit High Voltage
TCM
DTC P0843
P0961
Line Pressure Control (PC) Solenoid System Performance
TCM
DTC P0961
P0973
1-2 Shift Solenoid (SS) Control Circuit Low Voltage
TCM
DTC P0973
P0974
1-2 Shift Solenoid (SS) Control Circuit High Voltage
TCM
DTC P0974
P0976
2-3 Shift Solenoid (SS) Control Circuit Low Voltage
TCM
DTC P0976
P0977
2-3 Shift Solenoid (SS) Control Circuit High Voltage
TCM
DTC P0977
P1101
Intake Air Flow System Performance
ECM, PCM
• DTC P1101 for the 2.0L engine
• DTC P1101 for the 2.2L (L61) engine
P1106
Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage
ECM
DTC P1106
P1107
Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage
ECM
DTC P1107
P1111
Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
ECM
DTC P1111
P1112
Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage
ECM
DTC P1112
P1114
Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage
ECM
DTC P1114
P1115
Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage
ECM
DTC P1115
P1133
HO2S Insufficient Switching Sensor 1
ECM, PCM
• DTC P1133 for the 2.0L engine
• DTC P1133 for the 2.2L (L61) engine
P1134
ECM
DTC P1134
P1174
Fuel Trim Cylinder Balance
ECM
DTC P1174
P1182
Supercharger Inlet Pressure Sensor Performance
PCM
DTC P1182
P1183
Supercharger Inlet Pressure Sensor Circuit Low Voltage
PCM
DTC P1183
P1184
Supercharger Inlet Pressure Sensor Circuit High Voltage
PCM
DTC P1184
P1258
Engine Coolant Over Temperature - Fuel Disabled
ECM, PCM
DTC P1258
P1400
Cold Start Emission Reduction Control System
ECM
DTC P1400 for the 2.2L (L61) engine
or
DTC P1400 for the 2.4L engine
P1516
Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance
ECM, PCM
• DTC P1516 for the 2.0L engine
• DTC P1516 for the 2.2L (L61) engine
• DTC P1516, P2101, P2119, or P2176 for the 2.4L engine
P1574
Stop Lamp Switch Circuit
ECM, PCM
DTC P1574
P1621
ECM
P1629
Theft Deterrent Fuel Enable Signal Not Received
ECM, PCM
DTC P1629
P1630
Theft Deterrent Learn Mode Active
ECM, PCM
DTC P1630
P1631
Theft Deterrent Start Enable Signal Not Correct
ECM, PCM
DTC P1631
P1632
Theft Deterrent Fuel Disable Signal Received
ECM, PCM
DTC P1632
P1668
Generator L-Terminal Control Circuit
ECM, PCM
DTC P1668
P1680
PCM
DTC P1680 for the 2.0L engine
P1681
Control Module Throttle Position (TP) System Performance
PCM
P1682
Ignition 1 Switch Circuit 2
ECM, PCM
• DTC P1682 for the 2.0L engine
• DTC P1682 for the 2.2L (L61) engine
• DTC P1682 for the 2.4L engine
P1810
Transmission Fluid Pressure (TFP) Position Switch Circuit
TCM
DTC P1810
P1811
Maximum Adapt and Long Shift
TCM
DTC P1811
P1816
Transmission Fluid Pressure (TFP) Valve Position Switch Indicates Park/Neutral (P/N) with Drive Ratio
TCM
DTC P1816
P1818
TCM
DTC P1818
P2101
ECM, PCM
• DTC P2101 for the 2.0L engine
• DTC P2101 for the 2.2L (L61) engine
P2119
Throttle Closed Position Performance
ECM, PCM
• DTC P2119 for the 2.0L engine
• DTC P2119 for the 2.2L (L61) engine
P2120
Accelerator Pedal Position (APP) Sensor 1 Circuit
ECM, PCM
• DTC P2120 for the 2.0L engine
• DTC P2120 for the 2.2L (L61) engine
• DTC P2120, P2122, P2123, P2125, P2127, P2128, or P2138 for the 2.4L engine
P2122
Accelerator Pedal Position (APP) Sensor 1 Circuit Low Voltage
ECM, PCM
• DTC P2122 for the 2.0L engine
• DTC P2122 for the 2.2L (L61) engine
P2123
Accelerator Pedal Position (APP) Sensor 1 Circuit High Voltage
ECM, PCM
• DTC P2123 for the 2.0L engine
• DTC P2123 for the 2.2L (L61) engine
P2125
Accelerator Pedal Position (APP) Sensor 2 Circuit
ECM, PCM
• DTC P2125 for the 2.0L engine
• DTC P2125 for the 2.2L (L61) engine
P2127
Accelerator Pedal Position (APP) Sensor 2 Circuit Low Voltage
ECM, PCM
• DTC P2127 for the 2.0L engine
• DTC P2127 for the 2.2L (L61) engine
P2128
Accelerator Pedal Position (APP) Sensor 2 Circuit High Voltage
ECM, PCM
• DTC P2128 for the 2.0L engine
• DTC P2128 for the 2.2L (L61) engine
P2135
Throttle Position (TP) Sensor 1-2 Correlation
ECM, PCM
• DTC P2135 for the 2.0L engine
• DTC P2135 for the 2.2L (L61) engine
P2138
Accelerator Pedal Position (APP) Sensor 1-2 Correlation
ECM, PCM
• DTC P2138 for the 2.0L engine
• DTC P2138 for the 2.2L (L61) engine
P2176
Minimum Throttle Position Not Learned
ECM, PCM
• DTC P2176 for the 2.0L engine
• DTC P2176 for the 2.2L (L61) engine
P2227
Barometric Pressure (BARO) Sensor Performance
PCM
DTC P2227
P2228
Barometric Pressure (BARO) Sensor Circuit Low Voltage
PCM
DTC P2228
P2229
Barometric Pressure (BARO) Sensor Circuit High Voltage
PCM
DTC P2229
P2430
Secondary Air Injection (AIR) System Pressure Sensor Circuit
ECM
DTC P2430
P2431
Secondary Air Injection (AIR) System Pressure Sensor Performance
ECM
DTC P2431
P2432
Secondary Air Injection (AIR) System Pressure Sensor Circuit Low Voltage
ECM
DTC P2432
P2433
Secondary Air Injection (AIR) System Pressure Sensor Circuit High Voltage
ECM
DTC P2433
P2440
Secondary Air Injection (AIR) System Shut-Off Valve Stuck Open
ECM
DTC P2440
P2444
Secondary Air Injection (AIR) System Pump Stuck On
ECM
DTC P2444
P2534
Ignition 1 Switch Circuit Low Voltage
ECM
DTC P2534
P2535
Ignition 1 Switch Circuit High Voltage
ECM, PCM
DTC P2535
P2610
Control Module Ignition Off Timer Performance
ECM
or
P2763
Torque Converter Clutch (TCC) Pressure Control (PC) Solenoid Control Circuit High Voltage
TCM
DTC P2763
P2764
Torque Converter Clutch (TCC) Pressure Control (PC) Solenoid Control Circuit Low Voltage
TCM
DTC P2764
P2A00
HO2S Circuit Closed Loop (CL) Performance Sensor 1
ECM
P2A01
ECM
U0001
High Speed CAN Communication Bus
PCM
DTC U0001
U0073
GMLAN Hardware Failure
ABS, BCM, ECM, PCM, TCM
DTC U0073
U0100
Lost Communication with ECM/PCM
ABS, BCM, TCM
DTC U0100-U0299
U0101
Lost Communication with TCM
ABS, BCM, ECM, PCM
DTC U0100-U0299
U0107
Lost Communication with Throttle Actuator Control Module
ECM, PCM
DTC U0100-U0299
U0121
Lost Communication with Antilock Brake System (ABS) Control Module
BCM, ECM, PCM, TCM
DTC U0100-U0299
U1300
Class 2 Data Link Low
PCM
DTC U1300, U1301, or U1305
U1301
Class 2 Data Link High
PCM
U1305
Class 2 Data Link Low or High
PCM
U2100
Controller Area Network (CAN) Bus Communication
BCM, EBCM, ECM, IPC, PCM, PSCM, Radio, SDM, TCM, VCIM
DTC U2100
U2103
Fewer Controllers On Bus Than Programmed
DTC U2103
U2105
Lost Communications with Engine Control System
BCM, EBCM, PSCM, TCM
DTC U2105-U2199
U2106
Lost Communications with Transmission Control System
BCM, EBCM, ECM
DTC U2105-U2199
U2107
Lost Communications with Body Control System
DTC U2105-U2199
U2108
Lost Communications with ABS/TCS Control System
BCM
DTC U2105-U2199
U2109
Lost Communications with Powertrain Multiple Control System
EBCM
DTC U2105-U2199
U2111
Lost Communications with Steering Control System
BCM
DTC U2105-U2199
U2113
Lost Communications with Sensing Diagnostic Module (SDM)
BCM
DTC U2105-U2199
U2116
Lost Communications with Instrument Panel Cluster (IPC)
BCM
DTC U2105-U2199
U2125
Lost Communications with Mobile Communications Control Systems
BCM
DTC U2105-U2199
U2137
Lost Communications with Vehicle Theft Deterrent (VTD)
BCM
DTC U2105-U2199
U2172
Lost Communications with Digital Radio Receiver (DRR)
BCM
DTC U2105-U2199
023
Seat Belt Tension Sensor Circuit Out of Range
PPS
DTC 023
024
PPS Ignition 1 Voltage Performance
PPS
DTC 024
063
PPS Out of Calibration
PPS
DTC 063
064
Communication/ID Performance
PPS
DTC 064
065
PPS
DTC 065
Š 2008 General Motors Corporation. All rights reserved.
Old 03-23-2008, 03:54 PM
  #120
bender's Avatar
Well according to that chart.. it says its the oxygen sensor (P0036, P0140, P0141) and idle speed is high (P0507). I know the car has a wide band. Do these car's have to 02 bungs? He may just have replaced the narrow band with the wideband, and just use the simulator/translator of the WB controller. As for the high idle... I knew that, lol. Does HPTuners have an idle adjustment, or will I have to lean out the lower fuel curves? Are there any air bypass screws that I can adjust on the throttle body to lower it also?
Old 03-23-2008, 04:01 PM
  #121
dyno it
Old 03-23-2008, 07:05 PM
  #122
bender's Avatar
There is a dyno about 45 minutes away from me. It would be nice to use when I'm fine tuning the car.
Old 03-23-2008, 07:20 PM
  #123
SilverSS/SC's Avatar
...you can adjust for idle speed with hpt . There is no manual adjustments to make to the electric TB like the old school days of adjusting the TPS and IAC .
The factory narrow band 02 sensor is right in the collector of the manifold . There another 02 sensor after where the cat would be on the down pipe ...is that where the wide band is ? ~or did he put the wide band in the manifold .
Old 03-23-2008, 07:23 PM
  #124
bender's Avatar
Ok, thats what I was wondering. How do you wire in the wideband to the pro version? Is there just an accessory wire that leads to the pcm, and you just tie it into that?
Old 01-25-2010, 08:33 PM
  #125
08SSTCRD's Avatar
unless you have aftermarket axles, clutch. you will have some serious issues with slicks on the front of that.
there is only about 5 of us that run cams in the lsj engine. that car is not one of them.
dsm link is for the weak.
aem is pushing it.
hks vpro owns all
maf-t is a band aid fix for a dsm
Agreed.
DSM's are not known for quality or reliability. When you combine Chrysler quality control with Mitsubishi engineering, you end up with an abomination known as Diamond Star Motors.
HP Tuners >DSM Link.
Quick Reply: Just bought an aftermarket SS
