Just changed oil to 0w-30
Old 02-01-2010, 01:51 PM
RednBlack's Avatar
good info might convert next oil change
Old 02-01-2010, 02:02 PM
springerdesigner's Avatar
seems unnecessary to change down to a 0 weight oil... from the video posted above, he was using 5W-30 in -26 degree temps and it started fine. Where do u live that you'd need a 0w oil..?
Old 02-01-2010, 02:06 PM
ikeryder13's Avatar
is also for fuel economy
Old 02-01-2010, 02:09 PM
1badBlueberrySC's Avatar
I saw a 5-7% increase in fuel economy when I switched to 0w from 5w-30 Mobil.... I know Terminator2 saw an increase as well!
Old 02-01-2010, 02:12 PM
ok... so better gas mileage and better cold start abilities...
what are the cons? There have to be some...
Originally Posted by Bades
with 0 weight the oil wont stick to the bearings as well as say 5-10weight..... u may have kless drag but u also will have more bearing failures.....
seems kinda problematic...
Old 02-01-2010, 02:16 PM
Administrator
Administrator
Staged07SS's Avatar
subscribed
Old 02-01-2010, 02:19 PM
shroogis's Avatar
I don't know how you'd see any increase in fuel economy with 0w30. It's benefit is in cold start situations.
When the car is at operating temperature, it's a 30 weight, just like 5w30.
Old 02-01-2010, 02:25 PM
CordiaDOHC's Avatar
I honestly bought it because walmart as out of 5w30 but now that Ive tried it im going to be sticking with it till at least summer.
Old 02-01-2010, 02:32 PM
rico's Avatar
click
Old 02-01-2010, 02:35 PM
mandk1229's Avatar
I used it last winter when I lived in Maryland because everyone was out of mobil one 5w30. It is cheaper because it was made for the colder states. I didn't notice a difference in performance or fuel economy. If you want an increase in both of those feilds, stop messing around with 0w30 when you don't even live in a cold enough place to see a difference and switch to royal purple. You definetly can tell a difference with this stuff. I've been using it for about a year now and my car runs great and getting around 27 mpg avg city/hwy
Old 02-01-2010, 02:38 PM
  #36
shroogis's Avatar
Dude, it's a perfectly fine oil!! Even better if you live where it's cold!
I'm just tired of reading malarkey on this forum.
Old 02-01-2010, 02:58 PM
  #37
ikeryder13's Avatar
Well if gm says it's ok to run it and it doesn't hurt anything by them then I don't see a problem with running it
Old 02-01-2010, 03:00 PM
  #38
CordiaDOHC's Avatar
Honestly my car is running better with it over the 5w30 but then again like I said I switched from conventional to synthetic at the same time so part of what im feeling might be that as well. But my cars running well on it. And lately its been mid 20s (f) during the day here in stl. So this its been a bit cold here.
Old 02-01-2010, 03:01 PM
  #39
rico's Avatar
30s here and I hate it ugh lol
Old 02-01-2010, 03:04 PM
  #40
VeNoM0713's Avatar
hmm.. this is interesting. so since i live in buffalo, do you think it would be beneficial to run 0-30 mobil one? what about when summer hits? would it still be safe enough to use during the summer also?
Old 02-01-2010, 03:05 PM
  #41
rico's Avatar
^ GTFO man lol jk sup
  #42
I agree... runs very smooth with it.... although I am thinking of trying out edge next time
Old 02-01-2010, 03:06 PM
  #43
shroogis's Avatar
You don't want to go too thin in the Summer. I would honestly stay with 5w30 in the summer just in case.
I've thought about 5w40 in the summer though since I'm pretty hard on my car.
The less the oil sheers down, the more protection you have. I've heard M1 5w30 can sheer down pretty thin when it gets run super hot.
Old 02-01-2010, 03:35 PM
  #44
383_Stroker's Avatar
We ran mobil 5w30 in a legends car for years.. I'll never run an engine with anything else after watching it survive those conditions.
Legends use a Yamaha FJ 1200 engine which are air cooled, so the oil temps get up near 400* :-O
Anyway, we had one get so hot one time that it warped the head to the point that the cams couldn't turn and it tore the timing chain in two. The mobil didn't break down and kept it all lubricated, and it didn't even mark the cams!
Old 02-01-2010, 04:53 PM
  #45
mandk1229's Avatar
Trust me, it's the synthetic oil!! Breaks down slower, I've had it where after 6k miles it doesn't look like it broke down too much, very little color. Like I said, if you want performance and fuel economy go to royal purple. It's expensive but really really good
Old 02-01-2010, 05:19 PM
  #46
blackbolt89's Avatar
im gonna get Edge next time i do my change. probably won't notice a change in anything but i just want to think with my dipstick for once. lmao.
Old 02-01-2010, 05:35 PM
  #47
Sizzle06's Avatar
I'm on my 5th oil change using the 0w and have had no problems.
Old 02-01-2010, 05:40 PM
  #48
SeanEE89's Avatar
Whats better Mobil 1 or Amsoil?
Old 02-01-2010, 07:02 PM
  #49
red06SC's Avatar
wow 0weight is pretty thin.. id be scared to push it to much like that...
You guys DO realize the first number is the cold rating, right...?
Its STILL a 30 weight oil, and may actually be thicker at temperature than a 5w or 10w.
Take German Castrol, for example, best oil out there IMO. 0w-30, yet its almost a 40 at temperature..
Old 02-01-2010, 07:11 PM
  #50
Bades's Avatar
yes the first number is the viscosity at a set cold temp.... and the 2nd number is the viscosity at operating temp.... the only thing is when that motor goes from hot to cold starts and back and forth the oil drains down in to the oil pan very quickly...thats the key drawback .... plus in most high performance motors bearing tolerances are different and they need the added weight to properly lubricate the bearings while the motor goes from cold to warm.... and in most of our cars the engine never reaches 210*F which is the temp most oils use as the stated operating temp....
brandon04
10-21-2015 07:04 AM
717ssbalt
10-02-2015 04:01 PM
importkiller
09-30-2015 07:18 PM
dennis69
09-28-2015 02:16 PM
roth
09-26-2015 12:16 PM
Quick Reply: Just changed oil to 0w-30
