just dropped my car off at tune time. and also.....
Old 11-18-2007, 03:22 PM
  #76
Shortbus's Avatar
Originally Posted by JMHZ2401
No injector is made to run static.
then i guess my **** should have been blown up.
Old 11-18-2007, 03:26 PM
  #77
ebristol's Avatar
Originally Posted by chevysalesman614
he's probably bleeding off the extra boost, and just using the 2.7 for mid range torque.
Thats a good point.
Old 11-18-2007, 03:30 PM
  #78
WunSick's Avatar
heh i wanna see what happens here, hes gunna need 60s.... subscribed
Old 11-18-2007, 03:33 PM
  #79
an0malous's Avatar
its a possibility that he has limited boost in all gears to avoid going above 100% IDC, but to do that, your talking about a pretty major drop after 5500rpm, which is where a 2.7 will start to max out the injector.
can you say reverse-Vtech! lol
not to mention your still creating all that extra heat, and not using the boost its being created for.
all this to avoid buying some 60s?
strange logic.
Old 11-18-2007, 04:17 PM
  #80
Shortbus's Avatar
strange logic.
Lol why try explaining things on thise site anymore.
Old 11-18-2007, 04:19 PM
  #81
an0malous's Avatar
lol yeah i hear ya.
they are just gonna do whatever they want anyway.
Old 11-18-2007, 04:56 PM
  #82
JMHZ2401's Avatar
Not really. When you run a injector above 90% IDC it is more likely to fail. This does not mean it will, but the chances are more likely. It is like a playing with a ticking bomb. When the fix is really easy (bigger injectors) to me it seems dumb not to fix the issue.
Old 11-18-2007, 05:11 PM
  #83
Shortbus's Avatar
mine were 122% at 5k rpms.....
Old 11-18-2007, 05:40 PM
  #84
FryLoch's Avatar
Yea, that has got to be one hell of a tune to run a 2.7 with 42's. Good Luck man!
Old 11-18-2007, 06:23 PM
  #85
Rent me! per hour
Area47's Avatar
if you saw the real numbers of the 42 lbers, you would understand.
the saying, been there done that. applies to this.
Old 11-18-2007, 06:43 PM
  #86
distillion's Avatar
if this shop knows cobalts.
theyd throw 60s in and tune for them.
a 2.7 on 42s is ridiculous....
Old 11-18-2007, 06:45 PM
  #87
Shortbus's Avatar
its like playing with fire knowing your going to get burned but doing anyway.
Old 11-19-2007, 03:38 PM
  #88
ludicristSS's Avatar
Originally Posted by 95cam86roc
So what exactly did he solve?
The Fact the to many WEB tuners rely on IDC from a scanner they got free with there tuning software. Look at MS on the injectors 22.4 is static but HPT will show 100% at 17.8 MS . They don't conincide . I do how ever feel more comfortable with the 42's from http://www.cobaltperformanceparts.com/ Then the GM 42's . IMO . But everyone here on the boards knows how to tune we just guess at it . Here is the bottom line 42lbs x 2 =84 x4 = 336 crank hp The math is still the math. Most I have seen from a eaton 2.0lsj on my dyno is 245 x 15% 281 hp . How are we going to get the extra 55hp the injectors will allow ? Not ment to you personally but if people are running very rich I.E. in the low 10's-High 9's [ alot of you are ] and adding timing to compensate for lack of hp then you might max out the injector.Also it's better to run a little leaner with less timing then rich with more .
You car was to rich and you need to look at the ms on the scan.
^^ i wouldnt race the car if i were you. in fact, i'd be scared to go over 4,500rpm
post up the sheet, so we can see what your afr is
11.8 af at the tailpipe [ reads leaner then accual] He will not need 60lbs .
lol.
im sorry, no offence, but the fact that they cant tune 60s doesnt instill much confidence in him being able to work a miracle and make 42lb injectors work with a 2.7 pully.
I wish you all the best of luck, because i see blown motors in your future.
We can and do . What do you think we run in our 10 second vettes/trailblazer SS's ? 42's ?
Originally Posted by AlphaJaguar5
You wanna see what happens with a 2.7 and 42's?
There's no way around it, the injector isn't enough for the 2.7" but unless this shop is willing to say they will rebuild your engine if it blows after they tune it then I would go with 60lbers.
Heres what happened to my engine over a year and a half ago.
WTF are you nuts running 32 degrees of timing ? I would go and blaming anything on the injectors if I where you .
  #89
rickay726's Avatar
thank you matt! oh and my IDC is 78-82%
Old 11-19-2007, 03:39 PM
  #90
SSCobalt~SSZ24's Avatar
this is entertaining lol
Old 11-19-2007, 03:45 PM
  #91
chevysalesman614's Avatar
is he seeing the full amount of cfm the 2.7 is capable of, or did you bleed boost up top via the bypass valve?
also, why do the numbers seem so low? i would hope my cobalt would've made 260+ had i put on a 2.7.
are you saying there is no room for more power (with his current mods) with 60lb/hr injectors?
Last edited by chevysalesman614; 11-19-2007 at 03:45 PM. Reason: Automerged Doublepost
Old 11-19-2007, 03:56 PM
  #92
Edubs's Avatar
HA HA HA HA...
Matt, it's about time you came on here and shut people up.
lol.
I'm dissappointed. Someone comes on here and talks about how some freakin' carnival worker told him that Matt can't tune and you go running w/ it like it's the bible.
People need to understand that Matt knows how to tune and it's been proved over and over. There are plenty of TTP tuned SS/SC's running around NE and none of them blew up due to tuner error. I drive three hours to get tuned for a freakin' reason...
Old 11-19-2007, 04:01 PM
  #93
Originally Posted by Edubs
HA HA HA HA...
my issue is with the weak numbers, not the safety of the tune.
didnt matt tune dtm's car for 60s and a 2.6?(menaing he can tune for 60s if he needs to)
mine never blew up, and i beat the **** out of it actually, so did the guys who stole it
i dont know of any tune time cobalts that blew up for any reason. is there one?
yeah, once i get my monies in order, i'll be going to matt again to get my cobra tuned for a smaller pulley. (but i'm still learning whats safe as far as not grenading my new heaton)
Old 11-19-2007, 04:02 PM
  #94
What kind of dyno . Yes he is seeing 18 psi total . His car did good on my mustang dyno . [ it will generally read 10-12% less then a dyno jet .]
  #95
Edubs's Avatar
Originally Posted by rallycobalt06
from what i understand they can't tune the 60s right. i spoke with a guy at a car show i went to in md who was running a portable dyno and he has done some work with matt and just from listening to what he was saying to me it sounds like they just can't tune the 60s right.
Before you go running around telling people what you think you heard...
There were issues tuning 60's on one particular, turbo swapped, Cobalt because of limitations in HPT. That guy either doesn't know what he is talking about or you weren't listening.
  #96
Bring it . I love that mod motor .
Old 11-19-2007, 04:04 PM
  #97
What kind of dyno .
your mustang dyno. u tuned my car. i made 245/214 2.9, 42, a catback, and intake.
have you changed the calibration?? or was it beacuase the dyno had been recently greased when i was there?
Old 11-19-2007, 04:05 PM
  #98
Edubs's Avatar
Dan's (DTM) car was tuned and dyno'd at like 276 or something, but that was on a dynojet that Matt borrowed before he bought his Mustang dyno. At one point, we had my car w/ 60's in it, and it ran and idled better than stock. They were just too freakin' big for my car only making 280whp. BTW, I'm pretty sure mine is the car he's talking about making the 245 on his dyno...
Old 11-19-2007, 04:07 PM
  #99
i plan to, once the funds are scraped together.
Old 11-19-2007, 04:08 PM
  #100
Avrj123's Avatar
Interesting post, and looking forward to getting my car tuned soon with a 2.7 pully and 60lb injectors, but im hoping to get more whp than 237, I see a lot of cars on here with stage 2 and intake making more whp, and thas boosting only like 14-15lbs boost on a good day.
Quick Reply: just dropped my car off at tune time. and also.....
