just dropped my car off at tune time. and also.....
#79
its a possibility that he has limited boost in all gears to avoid going above 100% IDC, but to do that, your talking about a pretty major drop after 5500rpm, which is where a 2.7 will start to max out the injector.
can you say reverse-Vtech! lol
not to mention your still creating all that extra heat, and not using the boost its being created for.
all this to avoid buying some 60s?
strange logic.
strange logic.
#80
strange logic.
strange logic.
#82
Not really. When you run a injector above 90% IDC it is more likely to fail. This does not mean it will, but the chances are more likely. It is like a playing with a ticking bomb. When the fix is really easy (bigger injectors) to me it seems dumb not to fix the issue.
#88
The Fact the to many WEB tuners rely on IDC from a scanner they got free with there tuning software. Look at MS on the injectors 22.4 is static but HPT will show 100% at 17.8 MS . They don't conincide . I do how ever feel more comfortable with the 42's from http://www.cobaltperformanceparts.com/ Then the GM 42's . IMO . But everyone here on the boards knows how to tune we just guess at it . Here is the bottom line 42lbs x 2 =84 x4 = 336 crank hp The math is still the math. Most I have seen from a eaton 2.0lsj on my dyno is 245 x 15% 281 hp . How are we going to get the extra 55hp the injectors will allow ? Not ment to you personally but if people are running very rich I.E. in the low 10's-High 9's [ alot of you are ] and adding timing to compensate for lack of hp then you might max out the injector.Also it's better to run a little leaner with less timing then rich with more .
You car was to rich and you need to look at the ms on the scan.
11.8 af at the tailpipe [ reads leaner then accual] He will not need 60lbs .
We can and do . What do you think we run in our 10 second vettes/trailblazer SS's ? 42's ?
WTF are you nuts running 32 degrees of timing ? I would go and blaming anything on the injectors if I where you .
You wanna see what happens with a 2.7 and 42's?
There's no way around it, the injector isn't enough for the 2.7" but unless this shop is willing to say they will rebuild your engine if it blows after they tune it then I would go with 60lbers.
Heres what happened to my engine over a year and a half ago.
#91
also, why do the numbers seem so low? i would hope my cobalt would've made 260+ had i put on a 2.7.
are you saying there is no room for more power (with his current mods) with 60lb/hr injectors?
Last edited by chevysalesman614; 11-19-2007 at 03:45 PM. Reason: Automerged Doublepost
#92
HA HA HA HA...
Matt, it's about time you came on here and shut people up.
I'm dissappointed. Someone comes on here and talks about how some freakin' carnival worker told him that Matt can't tune and you go running w/ it like it's the bible.
People need to understand that Matt knows how to tune and it's been proved over and over. There are plenty of TTP tuned SS/SC's running around NE and none of them blew up due to tuner error. I drive three hours to get tuned for a freakin' reason...
#93
HA HA HA HA...
didnt matt tune dtm's car for 60s and a 2.6?(menaing he can tune for 60s if he needs to)
mine never blew up, and i beat the **** out of it actually, so did the guys who stole it
i dont know of any tune time cobalts that blew up for any reason. is there one?
yeah, once i get my monies in order, i'll be going to matt again to get my cobra tuned for a smaller pulley. (but i'm still learning whats safe as far as not grenading my new heaton)
#94
is he seeing the full amount of cfm the 2.7 is capable of, or did you bleed boost up top via the bypass valve?
#95
from what i understand they can't tune the 60s right. i spoke with a guy at a car show i went to in md who was running a portable dyno and he has done some work with matt and just from listening to what he was saying to me it sounds like they just can't tune the 60s right.
There were issues tuning 60's on one particular, turbo swapped, Cobalt because of limitations in HPT. That guy either doesn't know what he is talking about or you weren't listening.
#96
#97
#98
my issue is with the weak numbers, not the safety of the tune.
#100
