Just to be safe
Solid mounts and torque dampeners are old news...
They may do the job to a certain extent, but there are better alternatives now.
If you want to get rid of wheelhop go for OTTP rotated mounts. If those are too expensive, get some SS T/C mounts aka GM Wheel Hop Kit mounts.
I wouldn't recommend the T/C mounts if you are running anything more than GM S2/S3 though.
Im only running GMS2 and i dont have the cast atm for the motor mounts. so im gonna get the td for now run it with stocker mounts and save to get some good poly mounts. and put them in with it.
The TD helps quite a bit. I recently took mine off and I have to drive totally different now to avoid hop. It doesn't elminate hop/tramp but it helps quite a bit and it looks trick in the engine bay. Combining it with driver mod on the street and you are fine.
Sweet i just wanna tone down the wheel hop and a buddy of mine said it will actually put more power to the wheels. a little more not a whole lot and reduce the chance of wheel hop
Macgyver2484
09-02-2015 05:44 PM
