Killer Chiller!!!
Old 07-13-2008, 04:32 PM
  #101
lsjwannabe's Avatar
i don't know if i can say yet but the base kit should be around 400
Old 07-13-2008, 04:34 PM
  #102
07LaserBlueSS's Avatar
subscribed for more info! i too am going to go the cooling mods route
Old 07-13-2008, 04:41 PM
  #103
ralliartist's Avatar
yea, pricing is still at a guesstimate right now. should know more soon.
Old 07-13-2008, 04:44 PM
  #104
TxLonghorn#1's Avatar
Just talked to Joe and here are the prices for the two set-ups and how long it would take to install the kit. The prices are "STILL IN THE AIR" and might change....so here you go
"budget" kit = approx. 65 degree IAT's (AROUND $400...pending) 1-2hrs. to set-up
"advanced" kit = approx. 45-50 degree IAT's (AROUND $500) 4-6hrs. to set-up
ALL #'S ARE QUOTES!!!!!!!! SUBJECT TO CHANGE!!! BEWARE!!!!
Old 07-13-2008, 04:45 PM
  #105
The efficiency of superchargers is going to be at a whole new level with these kind of temps. Think about how hard the top end will pull with IAT's this low!
Old 07-13-2008, 04:46 PM
  #106
TX, you got the TEMPS for both kits backwards bud. LOL. Just thought I would point that out.
Prices sound REALLY good for what they will give you in performance.
Old 07-13-2008, 04:48 PM
  #107
ecotecon18s's Avatar
"budget" kit = approx. 45-50 degree IAT's (AROUND $400...pending) 1-2hrs. to set-up
"advanced" kit = approx. 65 degree IAT's (AROUND $500) 4-6hrs. to set-up
this is referring to temperature DROP right??
you might wanna clarify...
Old 07-13-2008, 04:50 PM
  #108
Yea...I had it that way, but then while "multi-tasking" at work doing 12hr. shifts, I got caught off guard, then I looked at what i typed and flipped it around.....my bad! Good catch!
Old 07-13-2008, 04:52 PM
  #109
no, this is referring to ACTUAL IAT's!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 07-13-2008, 04:57 PM
  #110
Bannned
ColeJJones's Avatar
iat2s....
Old 07-13-2008, 04:58 PM
  #111
you know what I meant. lol
Old 07-13-2008, 05:01 PM
  #112
JKincaid's Avatar
Lol, reverse that and you will be close. The GP on the base kit is undetermined, but will probably be somewhere around 479 range, and the advanced will probably be 600ish. We need testing, and we need to see how efficient you’re A/C system is.
Testing should start in a couple of weeks.
Thanks,
Joe
Old 07-13-2008, 05:03 PM
  #113
Thanks Joe, didn't know if you were gonna come back on our forum for a while, so I was just letting everyone know the great news. Great prices too BTW!
Old 07-13-2008, 05:04 PM
  #114
JKincaid's Avatar
Originally Posted by ColeJJones
iat2s....
No that's IC fluid temps.
Old 07-13-2008, 05:06 PM
  #115
ahhh, that's interesting. What are the IAT's then?
Oh, and care to explain the difference between the budget and advanced kits?
Old 07-13-2008, 05:09 PM
  #116
Altiery54's Avatar
ditto. i'm down for the GB
Old 07-13-2008, 05:11 PM
  #117
Yea, I'm definitely in a long time ago. I was sold when I read this on the cobra forums.
Old 07-13-2008, 05:17 PM
  #118
JKincaid's Avatar
That's going to depend on how efficient your intercooler is. Typically if you have 60 degree fluid temps circulating into the IC, than you should see no more than 20-25 degree higher iat-2 at the end of the 1320...We'll see...
Old 07-13-2008, 05:19 PM
  #119
WOW! That's still definitely impressive. Lets hope the laminova cores are pretty efficient. I think they may be.
Old 07-13-2008, 05:21 PM
  #120
Thanks,
Joe
Thanks for clarifying that...long 12 hrs shift going on here!!!
Old 07-13-2008, 05:27 PM
  #121
JKincaid's Avatar
The base kit is a Suction line chiller system, and will be very easy to install. Typical IC fluid temps are around 65 degrees.
The advanced kit is much more involved, and will include a dryer, expansion valve, two tee's, and two different size A/C hoses to install. Temps will be on average about 15 degrees lower than the base kit and will be more sustainable.
Old 07-13-2008, 05:29 PM
  #122
same here, can't wait to get off!!!!!!!!!!! my day off is tonight! yay!
thanks for explanation! Base kit sounds like a good option for lots of people on here, and the advanced kit sounds like what I want. lol
Old 07-13-2008, 05:32 PM
  #123
Bannned
ColeJJones's Avatar
well, we will be more interested im sure when we see the tested product with IAT2 temps and before /after dynos.
Old 07-13-2008, 05:34 PM
  #124
lsjwannabe's Avatar
should not be to long
Old 07-13-2008, 05:37 PM
  #125
Bannned
ColeJJones's Avatar
thats going to be the breaker.
Quick Reply: Killer Chiller!!!
