Killer Chiller!!!
Old 07-20-2008, 07:30 PM
  #201
freakta's Avatar
so any updates
Old 07-21-2008, 07:07 AM
  #202
dvscobaltSS's Avatar
not yet they told me they would call me when they are ready to test the advanced kit on my car....but i got sent to az for work for two weeks. i am at the airport right now waiting for my flight so i wont be able to take my car in until i get back
Old 07-21-2008, 10:06 AM
  #203
lsjwannabe's Avatar
should be shipping today
Old 07-21-2008, 10:46 AM
  #204
Littlegoose's Avatar
Can't wait for any new updates.
Old 07-22-2008, 08:48 AM
  #205
freakta's Avatar
ok so how many hours now before its on the car ha ha ha i cant wait ha ha
Old 07-22-2008, 10:10 AM
  #206
lsjwannabe's Avatar
Its going to take a while honestly. It goes on with the intake manifold to.
Old 07-22-2008, 04:26 PM
  #207
freakta's Avatar
ha ha im just a bit impatient
Old 07-22-2008, 04:27 PM
  #208
pjk91's Avatar
Are you going to dyno them separately so that we can see the gain with the new IM and then, gain with the new IM + Killer chiller?
Old 07-22-2008, 04:57 PM
  #209
Josh@ottp's Avatar
yes, they will both be on the car at the same time but will be dynoed seperately.
Old 07-22-2008, 05:45 PM
  #210
lsjwannabe's Avatar
I will do a couple runs with the intake manifold, and then a couple using the killer chiller.
Old 07-22-2008, 06:06 PM
  #211
freakta's Avatar
this is gonna be great
Old 07-22-2008, 08:22 PM
  #212
ralliartist's Avatar
looking forward to the results.
Old 07-22-2008, 08:24 PM
  #213
lsjwannabe's Avatar
Still en route maybe 2 days i should see it.
Old 07-25-2008, 09:45 AM
  #214
TxLonghorn#1's Avatar
so............did you receive it yet?? It's been three days, not two
Old 07-25-2008, 10:03 AM
  #215
lsjwannabe's Avatar
Actually did not end shipping out till the 23rd becuas eof a mix up at ups. It is scheduled to arrive the 28th according to my tracking number.
Old 07-29-2008, 04:03 PM
  #216
Tazmanian_Dvl's Avatar
^^^what he said
Old 07-30-2008, 09:58 AM
  #217
freakta's Avatar
yes bump
Old 07-30-2008, 10:39 AM
  #218
Josh@ottp's Avatar
Guys the car lost 3rd gear, I have the engine and trans out right now. The trans is going to need a heavy overhaul and were going to get it cryoed. This may take 2 weeks depending upon parts availbilty and how busy the cryo shop is. But trust me there will be big numbers very soon
Old 07-30-2008, 09:24 PM
  #219
Josh@ottp's Avatar
Update
I started fitting the KC on the car today. I should have it bolted up with some brackets made by this weekend.
  #220
Rodimus_Prime's Avatar
*facepalm
Old 07-30-2008, 11:37 PM
  #221
i will be back in Albuquerque this weekend and have already ordered the cx h/e. should be on by middle of next week. as soon as it is on i will make a few runs and get a baseline and see if they will be having the other kit ready to test. i will let you guys know more on monday
never mind just checked my email. CX h/e was shipped today and is scheduled to be delivered on friday. so if everthing goes right i will have it installed and ready for the second kit by the weekend. Will just have to wait and see if they have the second kit ready. i will keep you guys updated
Old 07-31-2008, 09:41 AM
  #222
how do you get the AC lines off to do this?
Old 08-04-2008, 01:06 AM
  #223
impulseballer's Avatar
you guys want a killer chiller for less here you go (they are ripping you off)
http://cgi.ebay.com/S-10-Plate-Braze...QQcmdZViewItem
Dimensions L: 7.5" W: 2.9" H: 1.2"
Ports 1/2" or 3/4" Male NPT
Heat Transfer Area/Plate .014 m^2/plate (.14 ft^2/plate)
Thickness of plates .3 mm
Channel Capacities .022L/channel
Design pressure 3.0 Mpa to 4.5 Mpa (435 psi to 650 psi)
Test Pressure 4.5 Mpa to 6.0 Mpa (650 psi to 870 psi)
Design Temperature -195C ~+220C (-319 F - 430 F)
Max Heat Transfer 1-5KW
Flow direction F1-F3 and F2-F4 (see diag above)
Welding Material 99.9% Copper
Corrosion Resistance Will NOT rust under normal usage (regular pH levels)
Manufacture Material 316L Stainless Steel (9% better heat transfer than 304)
Applications Heat pump system, household type central air conditioning,
after heat recycling, refrigeration equipment, industry cold
water machine,cooleroil and so on
insulate it with some black foam and purchase the necessary clamps and connectors and you have the same exact thing. then purchase a gauge for coolant temp if you want.
looks pretty similar right?
Old 08-04-2008, 01:37 AM
  #224
Herndon_High_SS's Avatar
oh damn. Lot cheaper. Now is it as efficent as the Name Brand product?
Old 08-04-2008, 03:12 AM
  #225
name brand product? lol it's probably the same or a different size model made from a different company with their black material on the outside and they logo on it. if you look at the design it's going to be as efficient as you need it to be. if i didn't have bills out the ass to pay etc. i would definitely be the test mule for this etc. but someone who has a little know how and some fabrication skills should def do it. if someone on the island purchases this and the necessary fittings i wouldn't mind helping with the install.
they have some serious ***** to charge almost $600 dollars for this. it's just another case of someone trying to rip off uninformed people.
someone should buy the ebay unit and any necessary fittings and test it out. easy diagram from the killer price chiller website lol
only thing is you going to need to go to a shop etc. for them to salvage ur ac fluid etc. and then put it back in or recharge it when your done with the install. the good thing is you should only have to run the ac for a little while to cool the coolant and shut it off right before running down the track. it should stay cold for a while.
Quick Reply: Killer Chiller!!!
