Laminova Core Removal
corn gas ftw....
1-10 its a 6-7 if you havnt done it before...
disconnect the batery! then, take the belt off, sc off, fuel rail off, intake off the sc, gasket off, alternator off, then intake mani comes off...on the intake mani: take off the end plate, remove laminova cores and when u put em back in make sure they are facing the right way...
You can get the lower intake mani bracket bolt off by removing the IC pump and going from the bottom as well. However the space is kinda tight, so removing the alternator might just be easier. Just another option lol.
lol yeah I will find out how much of a pain it is tonight I installed the ZZP stage 3 kit with the stage 3 heat exchanger so this should be too much more difficult. I hope anyways.
An hour later the surcharges and intake are out and the laminova cores switched it was a lot easier than I thought and pulling the alternate made it a whole lot better.
Yeah now all I have to do is wait for the parts they should be at my house when I get off then I will get everything put back together shouldnt take that long. I have a feeling what is going to take the longest is going to be re-routing the hoses which I will do after the intake is in and before I put the supercharger back on that and Im cleaning out the throttle body and supercharger intlet and well and the intake ports on the head there is a lot of oil build up from before I added the catch can.
Got Bewst?
https://www.cobaltss.net/forums/2-0l...hanger-217578/
i have a how to...
Official Myfakeevo Build Thread
theres more to it then just getting the cores out but you will find your info there
