Le Riceburners OFFICIAL Build Thread
#2735
it certainly wakes up in 2nd gear haha.
on these lights theres and adjustment 10mm bolt on the top rear of the housings. i'm able to aim them up and down; was never sure how high they need to be where so i just eyeball it haha. lateral rotation is adjustable just cause i personally don't like to seal the projectors on the housing cause every car fits different. as for aiming them in and out... i can push the housings into the car more i guess, again due to shitty fitment lol.
#2738
Humidity doesn't effect the radiators/exchangers performance. Sounds like you guys can improve a tad on your set up. On our 2.9 we maxed around 135 ish 2-4th
Now on the 2.6 going to 8000 2-top of 4th, we see 165-170. The last rpm each gear(7200-8000) really outs some heat in the system as we overspin the blower. I have it pull 2-3 degrees of timing. Starting to look into different pumps and set ups for better cooling now.
#2742
He's on a ~2.65 ring. I thought temps were acceptable for the setup.
I did play with base pressure by ramming a tire plug tool into the adjuster screw because SOMEONE had no tools....
There were a run of aem pumps that had pressure holding problems up top. His was the happiest when I took base to about 52.
#2743
If i recall ... rice has pretty much everything for cooling besides meth. I still have dual pass to throw on the car so i guess my setup is doing alright for what it is.
it looks like the zzp big he is much better than the small font mount. Advise's IATs are like 160* on a 2.3 and ati lmao
#2744
But I def recommend having one, and you should get to it and install it man.
#2747
