Le Riceburners OFFICIAL Build Thread
Old 08-10-2015, 11:43 PM
  #2826
cars so sick... makes me want a tvs
I bet you could flirt with 400whp going catless and zzp 3" catback with a couple other tweaks (2.6-2.7?)
This get a 3"!
Old 08-11-2015, 02:29 AM
  #2827
SSfamilywagon's Avatar
Lol no way hed make that with stock head/cams
Well don't totally knock that. Area47 made 375 ish on posted head only stock cams, out of fuel. I think it can be done properly set up. I'm actually trying for it that way.
Too much nonsense haha
Tvs on a 2.8/ati damper
LSJion ported head (exhaust side)
Stg2 cams
Balance shaft delete
80# valvesprings
Arp studs
Painted valvecover
Aem320 pump feeding 1000cc inejctors on a return setup
3" intake, ls4 throttle body,
Full zzp 2.5" catted resonated exhaust.
Dual pass option b, zzp stealth
Chrome double windshield wiper blades
E85
Gmpp clutch and axles
Oh and armtuned!
My best mod is staged07ss though
Ahhhh OK. So your set up definitely still had room for improvement. Exhaust size piping is OK but those mufflers are definitely hurting you. But full 3" would just be easier to pick out. More aggressive cams, bigger intake and more fuel that 400 mark would easily be passed.
Old 08-11-2015, 06:26 AM
  #2828
Oh yeah i agree. I was trying to score some bigger injectors for dyno day to throw on my 2.6"
Buut given the findings of how high boost/rpms can kill lifters maybe im best sticking with a safer setup too.
I know going catless and 3" would help... But its a street car and i love how it sounds as is. I like hearing myself and the blower instead of a loud ass exhaust.
So idk. Im sure something will pushbme to oush further eventually but dor now? Im set.
Old 08-11-2015, 07:13 AM
  #2829
Administrator
Administrator
Staged07SS's Avatar
This.
  #2830
armcclure's Avatar
I wouldn't try fixing what isn't broken. 380 is a LOT for a dd stock bottom end.
Old 08-11-2015, 07:16 AM
  #2831
Administrator
Administrator
Staged07SS's Avatar
Hell yeah it is.... It's more than enough.
Half the kiddies on here can't even harness or use that power to their benefit other than saying zomg wow look at my dyno numbers!!!
Old 08-11-2015, 09:49 AM
  #2832
Dipped_Cobalt's Avatar
its not about fixing whats not broken, but its always about more more more with this hobby
Old 08-11-2015, 10:00 AM
  #2833
Cutouts? Haha
Thats all that matters is youre happy
Old 08-11-2015, 10:13 AM
  #2834
Slobodan Milošević
07blackg5's Avatar
So idk. I'm sure Mike will nag the **** out of me to push further eventually, but for now? Im going to keep being a ****. I have a shiny new DD truck, but I'm going to call my balt a DD so people stay off my back.
Fixed
The following 2 users liked this post by 07blackg5:
armcclure (08-11-2015), riceburner (08-12-2015)
Old 08-11-2015, 10:24 AM
  #2835
HAHAHAHAHAHAH
Old 08-11-2015, 10:53 AM
  #2836
yellowsupercharged06's Avatar
ive got the ported head, stg 4 cams, 3.5" intake, 160's that will be in shortly.
idk how long she is guna hold together ... got a track day at the end of Sept. as well, hope she holds up. Its sitting at 320-330 whp right now without that stuff.
Old 08-11-2015, 01:52 PM
  #2837
Viperoni's Avatar
nice numbers!
Also, damm all you people with E85
Old 08-11-2015, 01:53 PM
  #2838
Viperoni's Avatar
nice numbers!
Old 08-11-2015, 03:45 PM
  #2839
Got Bewst?
Bluelightning's Avatar
Originally Posted by Viperoni
nice numbers!
I've read that there's a station that sells E85 somewhere in between Guelph and Cambridge. That's only an hour away from you. Do what I just did, go down with a 55 gallon drum, fill it with E85 and cut it with pump gas and run E47 so it lasts longer with lots of the same benefits.
Old 08-11-2015, 03:55 PM
  #2840
Slobodan Milošević
07blackg5's Avatar
just brew your own corn moonshine in the bathtub. same difference
Old 08-11-2015, 04:11 PM
  #2841
InfraRedline's Avatar
Nice work Rice and Alan! Glad to see its paying off for you man. Gotta be a great feeling after sticking with it through it all. I had a ton of fun when my car was on pretty much that same setup and power level.
Old 08-11-2015, 04:56 PM
  #2842
LNFTX's Avatar
Does the gasoline help the ethanol last longer? My experience with letting e85 sit around wasnt good.
Old 08-11-2015, 05:08 PM
  #2843
Get a good sealing tank and it's fine. You just dont want it open to atmosphere moisture in high humidity areas.
Old 08-11-2015, 05:59 PM
  #2844
LNFTX's Avatar
Ok thanks
Knowing that will make e85 more of an option in the future
Old 08-11-2015, 06:37 PM
  #2845
Haven07's Avatar
I'm highly considering picking up a tank myself. Looked around and a good tank is only a few hundred so it may be worth it...
Any idea how well it keeps? I only burn up 7 gals a week on reg gas so I'm thinking a 30 gal should hold me a month maybe grab a bigger one depending
Old 08-11-2015, 07:11 PM
  #2846
You can get 55 gal drums for free
Old 08-11-2015, 11:18 PM
  #2847
Haven07's Avatar
how and what kind?
Old 08-12-2015, 01:50 AM
  #2848
On craiglist. Pretty sure the plastic ones work fine.
Old 08-12-2015, 08:43 AM
  #2849
Make sure they're HDPE (high density polyethylene plastic, normally a blue drum or white and it should be stamped into the plastic or raised from the mold)
Snail_SS (08-12-2015)
Old 08-12-2015, 08:58 AM
  #2850
Thanks. Gonna get one soon and did not know that.
Quick Reply: Le Riceburners OFFICIAL Build Thread
