Le Riceburners OFFICIAL Build Thread
#436
Ok
Car is timed. Front cover on. Ati damper and accessories on.... starting to look more like an lsj...
Manifolds on, new fuel injector isolators, few sensors etc... we wound up leaving the pcv port alone and were just gonna do a dual pass, maybe **** with a single pass later down the road.
Blower went together nicely, 2.7" didnt exactly slide right on, so gonna have to maybe use a pulley tool for it? Idk.
This plug had some play in its spot, i feel like it could cause a boost leak. Opinions? Its the one that goes on top of the manifold
#437
Other plans:
Run a setup (forget the term) that runs a line from back of the valve cover, through a catch can, into the exhaust manifold. This is a common mod for drag racers to run, as it pulls pressure from inside the engine, that we dont want there in the first place. This provides a solution to using the intake to pull the pressure as there will no longer be oil coating the tb, blower and manifold. On blower cars this mod can give a good 5-10 horsepower.
#444
Other plans:
