Le Riceburners OFFICIAL Build Thread
Old 03-10-2014, 11:41 AM
  #451
IDK, one of my buddys simply noticed my MAP sensor and thought it was only a 1.5 or 2 bar and that those only read up to 15psi, then your pcm doesn't know what to do to compensate above that, which makes people go lean up top. which may be what hockeymans problem was up top with his 305 pull. he started going lean so they shut it down at 7500 revs
Old 03-10-2014, 11:45 AM
  #452
BlackielawlessSS's Avatar
Ok so 2 bar means the two sensor wires inside?
Old 03-10-2014, 11:56 AM
  #453
Administrator
Administrator
Staged07SS's Avatar
Get the car together and running, and go from there.
You might not make 17 psi with a ported head and full exhaust.
LSJ stock 2.5 bar map shouldnt need to be changed for your build.
Old 03-10-2014, 11:59 AM
  #454
Got Bewst?
Bluelightning's Avatar
A TVS set can make mid 20's on the stock sensor. I don't see it being an issue.
Old 03-10-2014, 12:35 PM
  #455
bmxracerchamp12's Avatar
my boost went down a couple psi just from my ported head. the stock lsj map should be plenty
Old 03-10-2014, 12:48 PM
  #456
guess we'll find out. i'll keep the sensor handy just in case, considering i'm gonna be running essentially a 2.6" pulley...
Old 03-10-2014, 01:04 PM
  #457
Got Bewst?
I saw 19 psi on my M62 2.6" on a stock motor. You'll be fine.
Old 03-10-2014, 01:39 PM
  #458
i just want cheap easy power mods all my ideas have been shot down
Old 03-10-2014, 01:42 PM
  #459
Got Bewst?
A new map sensor is going to net you more power?
Old 03-10-2014, 01:44 PM
  #460
Administrator
Administrator
Staged07SS's Avatar
Well cheap doesnt equal wasting money on parts you dont need man
Consult us first before you do something like that again.
Old 03-10-2014, 01:50 PM
  #461
574
574's Avatar
Just keep it simple
Old 03-10-2014, 02:01 PM
  #462
the turbo guys run 3 bars! i thought yes it would due to tuning capabilities
so catch can wise, i did some more research blablabla yeah due to idling and stuff it wouldn't work very well for a street car. so i guess i'm gonna do just a simple catch can that still feeds into the intake tube.
Old 03-10-2014, 02:06 PM
  #463
I just wanna learn lol
Old 03-10-2014, 02:22 PM
  #464
spend the money on a nice setup or get powells
Old 03-10-2014, 05:51 PM
  #465
TStone's Avatar
I was on 29 psi on my TVS set up.... Stock MAP sensor only read like 22.5 or something like that.
Old 03-10-2014, 05:56 PM
  #466
Got Bewst?
Same here as per my avatar haha
Old 03-10-2014, 05:57 PM
  #467
then why not run a 3 bar lol...
Old 03-10-2014, 06:18 PM
  #468
InfraRedline's Avatar
The ECU in the LSJ can not read or compensate any more than the 2.5 bar can read, so a 3 bar will do absolutely nothing more than the 2.5 bar. I'll be on the stock MAP sensor on my turbo setup at 30+ lbs. Do not overcomplicate the setup, I have pretty much your exact setup on my gray car, and ran it with the TVS for years.
Old 03-10-2014, 07:58 PM
  #469
After much reading I agree here. No need to spend money where money doesn't need to be spent Adam.
Old 03-10-2014, 10:51 PM
  #470
okay well hopefully i can sell it to an lnf guy lol... IF I DON'T NEED IT THAT IS!!
Old 03-10-2014, 10:57 PM
  #471
sl0wlsj's Avatar
Haha don't you hate buying **** that you find out you don't even need. I did it for years!
Old 03-10-2014, 11:07 PM
  #472
You think id know better by now of all people
Old 03-10-2014, 11:09 PM
  #473
sl0wlsj's Avatar
Yeah but then that goes back to "well it's better to be safe and buy it ahead of time" than need it and have to wait?
Old 03-11-2014, 07:10 AM
  #474
Administrator
Administrator
Staged07SS's Avatar
You will not need it.
Old 03-11-2014, 09:50 PM
  #475
so i gotta grind down my snout to fit the 2.7 pulley i think... did not know that...
Quick Reply: Le Riceburners OFFICIAL Build Thread
