Le Riceburners OFFICIAL Build Thread
#602
You pull up a thread where a single person showed dyno proof making even 1 hp plugging their silencer holes on their Balt and I'll believe you.
Yes Eaton says plugging the holes can be more efficient. Gains would be minimal at best. ZZP said they tested it and actually lost power. But when asked for proof none were to show.
#603
There was. Many m90 platform people think otherwise. Im not hoping for anything though i believe its only for sound.
I went through THREE transmissions in my 3.1 monte. Have no idea... got the f rid of it at 88000 miles
#605
Got Bewst?
"The two oval slots on the output plate are air leakage ports. Their only purpose is to decrease operational noise from the blower. Arnie, from Eaton Corp., explains their function like this, "When you stomp on the gas, the boost shoots up and the air flow goes supersonic. The air then slams back into the output plate and through the leakage slots, which reduces the hammering of the air into the housing causing less noise. The OEM can not have such loud NVH, thats why we put them in the housing. The 2 small ports are not there to feed air, only to reduce noise." Basically, for the best flow and most efficiency, these ports can be blocked off, making the outlet port (triangle slot) the only port on the outlet plate of the housing. Closing these ports will not increase IAT's; however, it will make the supercharger much louder when in boost. As an example, aftermarket supercharger companies, such as Harrop, Roush and Magnuson do not use these slots in their blowers. It should be re-stated, that you should consult professionals regarding closing these ports; and do not, for any reason, plug them with JB Weld. Improper closure could eventually lead to pieces coming apart and loose debris destroying the rotors and housing. Opening up these ports will only have a negative effect on efficiency. Do not port them."
#610
Pluging the holes is a noise maker mod rice.... You need to step back and really go over your build.
You are going in so many directions thinking you might solve something that hasnt been done or tried before to make power.
#613
If theres one thing ive learned from dealing with the honda community for years, when your car tends to attract the 17-19 year old "mommy and daddy just bought me this for graduating high school" crowd. Rumors and misinformation tend to be rampant and people cant tell whats truth or fiction. Take mrbelvedere for instance lol you could show him direct quotes from eaton regarding supercharger service and design and he will refuse to believe it.
#614
Its already been done and the blowers on. Its simple though, just have the openings wider on the inside of the rotor casing, tapering off into smaller openings on the outside.
Put tape over the inside side of the holes
Fill with quicksteel (used high temp at some crazy high pressure tolerance)
Spread a little extra around the hole for good measure
Let dry, peel off tape,sand, good to go
#615
And yeah guys the rotors are bad but not terrible. It was caused by metal flakes from the injen intake scraping a hole into itself in the fender hole it goes through, and then whatever debris got sucked into that hole.
It sucks because you know it would only he scraping the hole into the intake while driving, so pretty much all the metal shavings had to have been sucked in
Its a strong blower and motor! Yolo!
#620
I saw that blower case in the classifieds, i dont believe for a minute there's any sort of power increase with that goofy looking design. I also find it ironic that he recommended a pulley size change in order to take full advantage of the modification. I wish eaton would release more information about how the roots blower works so that people could understand the reason for that V shaped outlet in relation to the timing of the rotors spinning so they wouldnt fall victim to these people selling these goofy shaped housings. Magnuson already does their own aftermarket blower cases for certain applications and you will notice they all maintain the same V shape outlet (minus the silencer ports) and it is only a tad bit wider.
#621
#622
Dyno results of back to back testing.
If you want to talk **** in the face of proof, **** off.
You apparently don't know me that well, or that before I do or talk about something, I make sure I know what I'm talking about.
If you want to carry on looking like an ignorant ass, suit yourself.
And Adam, that wasn't a shot at you directly. More just saying, you get one shot per rebuild, might as well make sure it's done right.
#623
I recommended a pulley drop to see the most gains because this port brings back lost effeciency, the smaller you go the more % gain.
#624
I did explain it. And for your information, as was stated in the fs thread, both those pulls are the exact same pulley. Not just the same size. The exact same pulley.
#625
But to reiterate, the widest split barely precedes the leading rotor lobe closing point. The steps break up the pulses for smoother airflow. It's not that difficult.
After being done by hand, it was digitized with a cmm, angles and shape made symmetrical, then done on a cnc.
As I said elsewhere, "it's not some back shelf dremel job"
