Le Riceburners OFFICIAL Build Thread
Old 03-21-2014, 10:14 AM
  #751
BlackielawlessSS's Avatar
Yes use break in oil! There is a reason they make it.
Old 03-21-2014, 10:16 AM
  #752
Originally Posted by 574
Pour two of your quarts right in the oil filter hole it'll get to the bearings better
Thanks for the tip!
I was also thinking maybe we could crank it without the injector fuse to simply run the pump and get some oil moving
everything was liberally assembly lubed, and since we didn't replace anything in the bottom end bearing wise, i feel like i'd be ok on conventional oil, maybe add some lucas to it idk. well see what the break in stuff sells for
Old 03-21-2014, 10:19 AM
  #753
I would not run lucas. Just grab some break in oil. Napa is what I would use. I would also spin the motor with out running it, you want everything totally lubed.
Old 03-21-2014, 10:52 AM
  #754
so! there's a possibility that we won't have a lift available tonight or even tomorrow the guys in the shop are hella busy so we'll see. if nothing else there's still plenty we can do today to get prepared for when he have an hour or two to use the lift
Old 03-21-2014, 10:57 AM
  #755
Administrator
Administrator
Staged07SS's Avatar
Haha good deal! :Twothumbs
Ahh, my whole winter (perhaps life) has led to this point.
The only doubt that i have about starting is perhaps that cam position sensor that your how to showed being shown wrong in the book. I think we wound up going by the book but i forsee us having to change it.
You should have followed my picture in my thread. The way I have it shown is correct.
If you set it like the book it will set the cps code and give u a hard start.
Old 03-21-2014, 10:58 AM
  #756
InfraRedline's Avatar
By all means, uplug the injector harness and coil harness and crank it over a few times for a few seconds. Especially since everything was apart.
Old 03-21-2014, 11:01 AM
  #757
Administrator
Administrator
Staged07SS's Avatar
Take it out, and do it right.
Line up the balancer with the mark on the front cover.
TDC #1/#4 compression.
Set sensor wheel as shown in my photo.
bada bing
Old 03-21-2014, 11:06 AM
  #758
Thanks for tha picture!^ That clears up a lot for me. I just love building my car in my head.
Old 03-21-2014, 11:15 AM
  #759
Administrator
Administrator
Staged07SS's Avatar
Pictures are worth a thousand words.
I'm a visual learner, so seeing it done always helps me put it together in my head.
Old 03-21-2014, 11:35 AM
  #760
yeah guess i'll do that and i know its at tdc cyl 1 when the mark on the balancer is on the mark at like 7:00 on the front cover right
Old 03-21-2014, 11:38 AM
  #761
Administrator
Administrator
Staged07SS's Avatar
Cyl 1 & 4 will both be at TDC when the balancer and the cams are lined at 10 oclock for exhaust and 2 oclock for intake.
Old 03-21-2014, 11:42 AM
  #762
Ok, they are so we should be good.
To be truthful, two of my buddys did all the timing stuff one night while i was at school so minus seeing the cam gears like that i didn't see the rest of the process, and i doubt they did your slack removal trick.
another thing, now that i've been relooking at your how to, i am not positive if we used the flange sealant on the rear cam caps....
Old 03-21-2014, 11:52 AM
  #763
Got Bewst?
Bluelightning's Avatar
I never have. Never leaked
Old 03-21-2014, 11:53 AM
  #764
Administrator
Administrator
Staged07SS's Avatar
I would double check that rice, or you may seap oil out of the caps.
Old 03-21-2014, 12:01 PM
  #765
yeah that's what i'm assuming lol, i'll see if ryan remembers i guess
Old 03-21-2014, 12:53 PM
  #766
I am to. I can't just read a book and then go do it. I need pictures to visualize it.
Old 03-21-2014, 01:05 PM
  #767
Wonder if we should go ahead and attempt doing this in the garage, on the floor... fml
Old 03-21-2014, 01:09 PM
  #768
A lift is easier, but hell if the weather is decent, do it.
Old 03-21-2014, 01:11 PM
  #769
Supposed to be warm out and we have a heater and the garage floor is pretty nice and clean...
i just need to know approximately how high we need to lift the ******, and idk how were gonna lift the cradle up into it, sounds like a royal pain in the ass but this *****'s gotta get on the road.
Old 03-21-2014, 01:12 PM
  #770
PM Kahless he did a motor swap in his drive way.
Old 03-21-2014, 01:20 PM
  #771
thanks man
Old 03-21-2014, 01:30 PM
  #772
No problem. I can't remember if he posted pics on facebook or not.
Old 03-21-2014, 01:33 PM
  #773
never mind he took it out the top. Just guessing and with my hand measuring in the air, it should be do able. It will be a close fit, but I bet you will have no problems getting it back in. We slapped a 428 cj and c6 tranny in my dads 77 step side f100. We had to deflate the tires and put it on rims to clear or the hood. I know if that is do able you got this.
Old 03-21-2014, 01:54 PM
  #774
Well how long would you have to wait for the lift?
Old 03-21-2014, 01:56 PM
  #775
He was saying next weekend.
Quick Reply: Le Riceburners OFFICIAL Build Thread
