Le Riceburners OFFICIAL Build Thread
Old 03-21-2014, 02:07 PM
  #776
Piston3's Avatar
I hope it goes exactly opposite of how mine went!
Old 03-21-2014, 02:20 PM
  #777
HMM interesting, we do have a hoist in the garage and the cradles in the car so maybe that's not such a bad idea
on a good note i have a decent dyno shop possibly lined up near me.
they say don't run meth and e85
Old 03-21-2014, 02:27 PM
  #778
mrbelvedere's Avatar
Originally Posted by 574
Pour two of your quarts right in the oil filter hole it'll get to the bearings better
it dose not work as well as you think it wont reach the rods lash adjusters cams and so on
Yes use break in oil! There is a reason they make it.
I know why do you
Thanks for the tip!
I was also thinking maybe we could crank it without the injector fuse to simply run the pump and get some oil moving
everything was liberally assembly lubed, and since we didn't replace anything in the bottom end bearing wise, i feel like i'd be ok on conventional oil, maybe add some lucas to it idk. well see what the break in stuff sells for
assembly lube is just for that you need to pump the oil into the engine so it gets on all of the bearings and cam journals and lash adjusters and the tensioner gets filled also if you would have asked I could have told you how to make a primer setup
Old 03-21-2014, 02:30 PM
  #779
put everything on the cradle engine trans radiator I mean everything make it a complete assembly then pick it up set it on the engine hoist legs roll it under car hook to engine lift points and lift it into the car as a complete assembly bolt up the cradle first then engine to mounts done
Old 03-21-2014, 02:31 PM
  #780
ok what do you think is the right method for getting oil everywhere?
i went and got some royal purple with a quart of RP break in oil. as of now i'm planning to pour a quart or two into the oil filter, and the rest through the fill spot, then crank for a few seconds before starting
Old 03-21-2014, 02:35 PM
  #781
that sounds really promising and effective, thank you for that post! i had not thought of donig it that way
Old 03-21-2014, 02:42 PM
  #782
Piston3's Avatar
I pulled fuel relay cranked for about 20 sec. Hooked it back up and fired right off. This IS coming from a guy on his 4th motor but those weren't my fault.
Old 03-21-2014, 02:49 PM
  #783
lol nice. thanks. did you do yours in the driveway?
Old 03-21-2014, 02:56 PM
  #784
Piston3's Avatar
No. Fully equipped garage with lift. Had the harness completely hooked up too then lowered the car on it
Old 03-21-2014, 03:33 PM
  #785
royal purple is garbage go get some rotella or brad penn I modified a stock oil cooler and use 8.00 drill pump from lowes to pump the oil through the engine send me a text and ill send you a pic of the modded oil cooler I made
I have the Heat exchanger plumped radiator hoses on wire harness is on its a complete assembly lift and bolt but make sure you bolt the cradle in first
Old 03-21-2014, 05:09 PM
  #786
Yup we cant use the lift
And noone is interested in doin this on the floor so guess that means im fucked until next week AT LEAST. Really pissed now.
Old 03-21-2014, 07:37 PM
  #787
Piston3's Avatar
Sharing your anger bro. Can't order the LDK crate motor til next week. Heard we got possible snow coming anyways . Hopefully that's the last of that ****!
Old 03-21-2014, 07:40 PM
  #788
Atleast im not so alone!
I hope it snows until my **** is done LOL that way i wont feel so bad. Gahh i had my hopes up all week though!
Old 03-21-2014, 07:57 PM
  #789
BlackielawlessSS's Avatar
I know why do you
Because they are high in zinc and phosphorus. thus insuring the rings seal up.
Old 03-21-2014, 08:44 PM
  #790
kdub1492's Avatar
What shop near you does dyno? And do they have any experience tuning LSJ? What was their reasoning for not running meth or e85? I'm gonna guess that they don't know how to tune for it...
Old 03-21-2014, 09:14 PM
  #791
Did you see his S/C? I don't think it would have lasted much longer on it.
Old 03-21-2014, 09:39 PM
  #792
Blairwolf's Avatar
He said they recommend not to run meth with E85 not that they recommend not to run either of them. Rice wants to use meth as a cooling mod and run E85 for its octane.
Old 03-21-2014, 09:52 PM
  #793
Piston3's Avatar
That's exactly where I was last week. I was so excited. Then it happened Luckily ZZP is awesome...
  #794
574
574's Avatar
I wouldn't let just anyone tune it Adam. .. Take that fancy enclosed trailer to zzp or Alan
Old 03-21-2014, 10:03 PM
  #795
I agree. Luckly for me I have a great buddy who tunes some bad ass cars.
Old 03-21-2014, 10:37 PM
  #796
I'll tune it
But, no seriously. You're so close to ZZP I'd trailer it to them.
Old 03-21-2014, 11:14 PM
  #797
TStone's Avatar
or get it remote tuned.......
Old 03-21-2014, 11:21 PM
  #798
ThexGovenor's Avatar
What injectors are you running? I might be able to give you a decent base to get you to a tuner.
Old 03-21-2014, 11:34 PM
  #799
Spawne32's Avatar
way too much nonsense in this thread regarding breakin, you can run a break in oil if you want to, but your only running the break in oil during the 30 minute warmup after you first start the fresh motor, your not driving on it. You can run conventional oil as well, usually recommended that it be a straight 30 non detergent oil. But the important thing is you run it for 30 minutes and just let it warm up, then turn it off and drain that oil out. That will contain the bulk of your assembly lubricant (be it moly based or not).
As far as priming goes, your not gonna be able to prime the motor just by cranking the motor via the starter, there isnt enough RPM's to get oil to actually flow up through to the head. But you are welcome to do so if you feel its a little more added security. You will have to start the car to actually get oil pressure though.
Old 03-21-2014, 11:36 PM
  #800
zddp has nothing to do on the ring sealing that is done through heat and positive pressure on the ring pack forces the rings to seat
Quick Reply: Le Riceburners OFFICIAL Build Thread
