Le Riceburners OFFICIAL Build Thread
#778
I know why do you
Thanks for the tip!
I was also thinking maybe we could crank it without the injector fuse to simply run the pump and get some oil moving
everything was liberally assembly lubed, and since we didn't replace anything in the bottom end bearing wise, i feel like i'd be ok on conventional oil, maybe add some lucas to it idk. well see what the break in stuff sells for
#779
put everything on the cradle engine trans radiator I mean everything make it a complete assembly then pick it up set it on the engine hoist legs roll it under car hook to engine lift points and lift it into the car as a complete assembly bolt up the cradle first then engine to mounts done
#780
ok what do you think is the right method for getting oil everywhere?
i went and got some royal purple with a quart of RP break in oil. as of now i'm planning to pour a quart or two into the oil filter, and the rest through the fill spot, then crank for a few seconds before starting
#781
#785
I have the Heat exchanger plumped radiator hoses on wire harness is on its a complete assembly lift and bolt but make sure you bolt the cradle in first
#789
it dose not work as well as you think it wont reach the rods lash adjusters cams and so on
I know why do you
assembly lube is just for that you need to pump the oil into the engine so it gets on all of the bearings and cam journals and lash adjusters and the tensioner gets filled also if you would have asked I could have told you how to make a primer setup
I know why do you
#790
What shop near you does dyno? And do they have any experience tuning LSJ? What was their reasoning for not running meth or e85? I'm gonna guess that they don't know how to tune for it...
#799
way too much nonsense in this thread regarding breakin, you can run a break in oil if you want to, but your only running the break in oil during the 30 minute warmup after you first start the fresh motor, your not driving on it. You can run conventional oil as well, usually recommended that it be a straight 30 non detergent oil. But the important thing is you run it for 30 minutes and just let it warm up, then turn it off and drain that oil out. That will contain the bulk of your assembly lubricant (be it moly based or not).
As far as priming goes, your not gonna be able to prime the motor just by cranking the motor via the starter, there isnt enough RPM's to get oil to actually flow up through to the head. But you are welcome to do so if you feel its a little more added security. You will have to start the car to actually get oil pressure though.
