Le Riceburners OFFICIAL Build Thread
Old 04-06-2014, 12:02 AM
  #951
Old 04-06-2014, 09:44 AM
  #952
BlackielawlessSS's Avatar
Se ve muy bien Adam. No puedo esperar a que la melodía dyno, y la primera prueba de funcionamiento.
Old 04-06-2014, 10:18 AM
  #953
God dammit billy
Old 04-06-2014, 10:25 AM
  #954
God dammit billy
Inglés Mother ******. ¿Usted habla?
Old 04-06-2014, 10:38 AM
  #955
noorj's Avatar
Oopdayte.
Precliffnotes: still have shitty exhaust leak, need to finish vaccum pump deal
I looked thru some of this thread and didn't find anything, details on vacuum pump?
Old 04-06-2014, 11:27 AM
  #956
Sorry misworded that its a simple pan-evac setup. Gutted the VC, drilled and tapped a big npt fitting on, ran hosing with a 1way check valve and air/oil seperator into a 45° bung post resonator, premuffler.
During idle, however, we were finding that the checkvalve wasnt opening so perhaps we werent getting enough pressure to pull vaccuum. So for now its a simple vc->oil seporator->intake bung
Old 04-06-2014, 11:40 AM
  #957
sandman's Avatar
I see what you did there
Old 04-06-2014, 12:43 PM
  #958
Yeah i saw that too
Old 04-06-2014, 12:46 PM
  #959
Got Bewst?
Bluelightning's Avatar
smh
Old 04-06-2014, 01:03 PM
  #960
At least we tried
Old 04-06-2014, 02:39 PM
  #961
Que?
Old 04-07-2014, 12:22 AM
  #962
Found out the meth pump doesnt work. Luckily i still had my old one so made it happen still. Should be a decent setup, running it from the washer fluid tank. Lets hope it doesnt fail
Change plugs
Ran it almost empty of gas, loaded in the trailer and took it to zee shop
Pulled car out of trailer, took out 60#s, went to put in 80s and guess what. The 60s were ev1 and the 80s are ev6.
So now its at the shop with no injector harness
I swear this has been a battle every single step of the way.
Old 04-07-2014, 12:27 AM
  #963
andrewcarr1993's Avatar
Well if you want to buy new EV1's this guy will buy those EV6 80's
Old 04-07-2014, 12:33 AM
  #964
Why do you have an ev6 harness?
Old 04-07-2014, 12:34 AM
  #965
Becayse my 60s and ev1 harness is called for already
But if you have an ev6 harness i could buy lmk need it asap!!
Old 04-07-2014, 12:36 AM
  #966
2.2/2.4 is EV6 2.0 is EV1
Old 04-07-2014, 12:38 AM
  #967
Zzp wire harnesses show the same style plug that i have on the 80s as ev6
Wait is mexi_loco a 2.0 or 2.4 guy? I got the injectors from him
Edit: hes an lsj so idk lol
Old 04-07-2014, 12:40 AM
  #968
Left: 80#
Right: 60#
Old 04-07-2014, 12:44 AM
  #969
I'd just get the new harness from ZZP, should have it pretty quick.
ZZPerformance - Ecotec Injector Harness #ZZ-EIH
Old 04-07-2014, 12:46 AM
  #970
I found it already but thank you much just gotta see if its cool with the shop for me to have it sent there and 'installed' by them. All for extra of course
Old 04-07-2014, 12:50 AM
  #971
Those 5 clips might be pretty hard for them... Probably charge you $100 or something stupid just to install those.
Old 04-07-2014, 01:04 AM
  #972
Probly
Old 04-07-2014, 01:20 AM
  #973
Le street vids. Don't make me go spanish on you.
Old 04-07-2014, 08:35 AM
  #974
El chupalibre hasta manana stede el bano, putoo
Old 04-07-2014, 08:57 AM
  #975
Usted es un culo estúpido, hijo de puta. No me vengas con esa mierda de que eres en el inodoro. Ah, y felicidades por la nueva novia.
Quick Reply: Le Riceburners OFFICIAL Build Thread
