Le Riceburners OFFICIAL Build Thread
#956
Sorry misworded that its a simple pan-evac setup. Gutted the VC, drilled and tapped a big npt fitting on, ran hosing with a 1way check valve and air/oil seperator into a 45° bung post resonator, premuffler.
During idle, however, we were finding that the checkvalve wasnt opening so perhaps we werent getting enough pressure to pull vaccuum. So for now its a simple vc->oil seporator->intake bung
#959
Got Bewst?
#962
Found out the meth pump doesnt work. Luckily i still had my old one so made it happen still. Should be a decent setup, running it from the washer fluid tank. Lets hope it doesnt fail
Change plugs
Ran it almost empty of gas, loaded in the trailer and took it to zee shop
Pulled car out of trailer, took out 60#s, went to put in 80s and guess what. The 60s were ev1 and the 80s are ev6.
So now its at the shop with no injector harness
I swear this has been a battle every single step of the way.
Change plugs
