Le Riceburners OFFICIAL Build Thread
Old 04-10-2014, 01:24 PM
  #1026
bmxracerchamp12's Avatar
thought it was the kaboom?!?!?!?
hopefully it makes good numbers
Old 04-10-2014, 01:35 PM
  #1027
WVU_SS's Avatar
IB4 boom! Hope you see some good results man.
Old 04-10-2014, 01:44 PM
  #1028
more about this Sound Performance tuning shop...
they have been around since 1988
Sound Performance has set numerous records for street legal, full weight cars. First 300ZX TT into the 10's First MKIV supra to run 9.5 with stock Toyota Automatic transmission.... (A record still held today!!!), Fastest full weight supra in the world 8.45 1/4 mile, most powerful daily driven supra-1520 RWHP and now the fastest daily driven full weight Lexus SC300 in the country 9.59@143mph.
Not a day goes by in which the Sound Performance garage isn't crammed with Surpas, Nissans, Corvettes, Mustangs, Vipers and other cars, along with engines being built, turbo kits being assembled, and electronics being installed and cars being dyno tuned.
Old 04-10-2014, 01:57 PM
  #1029
Got Bewst?
Bluelightning's Avatar
so i'm probably gonna hit the numbers i want but not as honestly
o well.
and remember guys, i was on a james rakes tune before this, so really anything is a step up from that
Actually James made good power with his tunes. He was just hard on motors
Old 04-10-2014, 02:16 PM
  #1030
Piston3's Avatar
Hope it goes well. Sounds like they have a decent resume.
Old 04-10-2014, 02:19 PM
  #1031
sandman's Avatar
I will go to this place for my future non cobalts then
Old 04-10-2014, 02:44 PM
  #1032
armcclure's Avatar
I don't understand how they could has a reputation like that, and say we can't run 80's... Injector scaling is NOT that hard, and is very common across many platforms.
Good luck.
Old 04-10-2014, 03:02 PM
  #1033
Ok now hes having an issue...
Says its pumping 90 lbs of fuel pressure at idle and no boost but once he starts getting to boost it drops atleast 30 lbs. Why is it at 90 at idle and low load? Isnt fuel pressure supposed to go stay at 59ish when boost goes up?
Old 04-10-2014, 03:06 PM
  #1034
jonathan923's Avatar
what type of fuel system are you running besides 80s?
Old 04-10-2014, 03:35 PM
  #1035
Hockeyman's Avatar
Run away!
Old 04-10-2014, 03:41 PM
  #1036
Am scurrr
Old 04-10-2014, 03:42 PM
  #1037
All stock system it should be reading ~58 lbs across the board
Old 04-10-2014, 03:53 PM
  #1038
TStone's Avatar
Oh lord
Old 04-10-2014, 03:58 PM
  #1039
Possible that e85 has gummed up my stock pump maybe?
Old 04-10-2014, 04:04 PM
  #1040
TStone's Avatar
No
Old 04-10-2014, 04:07 PM
  #1041
armcclure's Avatar
What fuel system, and how is it plumbed? And where is he reading 90psi?
Old 04-10-2014, 04:10 PM
  #1042
TStone's Avatar
He said all stock besides 80's
And let's hope at the rail
Old 04-10-2014, 04:16 PM
  #1043
Yes hes reading it off the rail
Old 04-10-2014, 04:21 PM
  #1044
armcclure's Avatar
Change fuel filter. If still high, restriction is between filter and in-tank regulator.
Old 04-10-2014, 04:48 PM
  #1045
BlackielawlessSS's Avatar
Boo! Sucks man, hope you get it all ironed out.
Old 04-10-2014, 05:05 PM
  #1046
^^i agree, i hope they pull it off somehow. ive been lurking this build way too much to see it fail. good luck rice i hope you get some decent numbers dude
Old 04-10-2014, 05:10 PM
  #1047
574
574's Avatar
I remember a build once upon a time that had a lot of work, hype up then fail
Old 04-10-2014, 05:14 PM
  #1048
lol i remember that one as well . but at least the car is making twice the hp now
Old 04-10-2014, 05:27 PM
  #1049
574
574's Avatar
Inb4574'scarisonjackstandsstill
Old 04-10-2014, 05:46 PM
  #1050
Yep im fucked now.
Since whatever is wrong with fuel system, he had all these complications with tuning it but pressed forward. The pcm was doing what it had to do (as it likely did before) to compensate for the fuel pressure loss when in boost. So he tuned it for basic driving and no boost based off of the car that was given to him. The final tune, realistically, is based off of what he has made as of now.
So now that we have discovered this issue lies in the fueling system, i need to fix it before he presses forward. And once he presses forward, that requires a completely new tune. So essentially i will be charged for two tunes!
And that is AFTER i figure out whatever is wrong and fix that.
An observation: as ive mentioned before, i never could get my car under a 13.9 with full boltons and DRs and wotbox. Id get great 60's but low trap speeds. (1.8 60's but ~100 mph traps)
Makes you think that car has been slacking in the top end, doesnt it? And this would make sense, if the fuel pressure is dropping under boost, because now the car is pulling fuel and timing like crazy to compensate!
Could it be the regulator by the fuel rail?
Noted...
Quick Reply: Le Riceburners OFFICIAL Build Thread
