Le Riceburners OFFICIAL Build Thread
Old 04-10-2014, 05:50 PM
  #1051
What fuel system, and how is it plumbed? And where is he reading 90psi?
Hes reading 90 psi at idle and not in boost. Drops 1/3 right after/as car gets into boost
Old 04-10-2014, 05:52 PM
  #1052
TStone's Avatar
Change the fuel filter. Something is wrong.
If the guy is as big as you say, he should be able to fix it
Old 04-10-2014, 06:04 PM
  #1053
Are you running a wideband? Or just using lambda off the stock narrow band and assuming the injector is performing as listed (TLDR if you mentioned the addition of a wideband)
Old 04-10-2014, 06:07 PM
  #1054
I have a wideband yes. Car was idling at 14.7 when i last ran it still on pump gas. He tunes off lambda which he got to 1 with
Old 04-10-2014, 06:16 PM
  #1055
Any idea what your A/F or lambda was at WOT with your prior tune?
Old 04-10-2014, 06:19 PM
  #1056
noorj's Avatar
the thing on the fuel rail is a fluid damper. If he is really getting 90 psi of fuel pressure (double check with another gauge) then it has to be either fuel pump, fuel filter, or the line from the factory regulator
Old 04-10-2014, 06:20 PM
  #1057
574
574's Avatar
Thats bull your getting charged for two tunes. Sounds like an *******, if there was such an issue he shouldn't have put so much time into it.
Old 04-10-2014, 07:00 PM
  #1058
Dont know for sure my old wideband quit on me months ago
Ok thank you. Now to source one or all of those parts.
Oh this is so much fun ()
Old 04-10-2014, 08:31 PM
  #1059
Hmm i wonder why i never got a code for any of this tho...
Al, i may have to say forget the retune from sound performance and just limp the car your way next weekend lol
Old 04-10-2014, 10:58 PM
  #1060
noorj's Avatar
Start with the fuel filter, but I'm kinda doubting that your seeing 90 psi of fuel pressure.
Someone that knows cobalts (Alan) would be much better off tuning/diagnosing issues than a LSX guy
Old 04-10-2014, 11:16 PM
  #1061
See in retrospect it would have been better for me to replace my pump with a nice ethanol pump then i would have replaced the filter lol
Old 04-11-2014, 01:11 AM
  #1062
SPDDMN36's Avatar
Get a rsfs or brfs. Pick a nice e85 pump and call it a day.
Old 04-11-2014, 01:47 AM
  #1063
IonNinja's Avatar
why would they continue to tune the car knowing there is an issue...I'd be kinda pissed
Old 04-11-2014, 06:57 AM
  #1064
armcclure's Avatar
Yeah... What doesn't make sense is it's dropping to where it should be at all times.
Just let me know Adam. I have a local dyno rented out the 19th
Old 04-11-2014, 07:55 AM
  #1065
TStone's Avatar
Ohhhhhhh shiiiiit. I heard there's gonna be some broken records goin on!? What kind of shenanigans you up to?
Old 04-11-2014, 08:11 AM
  #1066
Well Al, considering there's no gaurantee the shop will properly tune me even after this B.S. is fixed and the price they charge compared to you i think i'm gonna have to bring it your way on the 19th!
Old 04-11-2014, 08:35 AM
  #1067
kdub1492's Avatar
I don't want to say I told you so, but....
Old 04-11-2014, 09:11 AM
  #1068
BlackielawlessSS's Avatar
That sucks adam...
Old 04-11-2014, 09:58 AM
  #1069
armcclure's Avatar
Just let me know
And stone if you want part of it, you'd better hurry.
Old 04-11-2014, 09:59 AM
  #1070
would have been fine had my fueling been right dude, this fail has nothing to do with the tuner besides perhaps the fact that he could have found out sooner instead of tuning it as is, but that's really my responsibility i guess.
Old 04-11-2014, 10:03 AM
  #1071
mrbelvedere's Avatar
rice sounds like the intanke regulator is sticking I would replace the filter and drop the tank and check out the regulator
Old 04-11-2014, 10:24 AM
  #1072
I take it the ss's use the same regulator and filter as a base model? because autozone and napa never carry ss specific parts
Old 04-11-2014, 10:57 AM
  #1073
Administrator
Administrator
Staged07SS's Avatar
I always purchase from Tom at CED when it comes to parts like this.
Give Tom a call.
Old 04-11-2014, 12:40 PM
  #1074
I did hes gotta get back to me
After calling another gn dealer they say gm only sells the pump and sender deal together and its 40p+ bucks and he wasnt sure if that includes the regulator.
Old 04-11-2014, 12:57 PM
  #1075
the regulator is on the outside of the tank? this is quite confusing to me as to be expected
or are there two regulators? i know i've seen something that i think is a regulator on the outside of the tank up on the rail
Quick Reply: Le Riceburners OFFICIAL Build Thread
