Le Riceburners OFFICIAL Build Thread
Old 05-24-2014, 12:11 PM
  #1401
Ill load up the vids today
Old 05-24-2014, 12:22 PM
  #1402
SSfamilywagon's Avatar
Kinda agree with you there Taylor. I did 13.5@105 in my Cobalt on gas, 2.8, air box mod, header/dp, h/e and stock tires.
His car has more potential even on street tires but drags will make it way easier. Rev the puppy high
Old 05-24-2014, 03:38 PM
  #1403
Yeah i dont get it man pretty good launch pretty quick shifts wrapped up to redline., ughh
Old 05-24-2014, 05:50 PM
  #1404
Got Bewst?
Bluelightning's Avatar
That is strange after looking at your time slip and your runs are pretty solid like you said. For ***** I pulled my best time slip from the 2 times I went to the track with my M62. 2.8", 7gph of meth, air box mod and bone stock exhaust. Our times and mph are almost identical all the way down but I trapped 1 mph slower.
Old 05-25-2014, 05:01 PM
  #1405
Crazy dude. I know everyone has done better than me with much less **** done to their car
Old 05-25-2014, 11:23 PM
  #1406
Got Bewst?
Maybe it's the track
Old 05-26-2014, 08:42 AM
  #1407
mrbelvedere's Avatar
you need more window time rice that's all
Old 05-30-2014, 02:34 PM
  #1408
hot, HOT day over here... but a 2nd gear pull
Old 05-30-2014, 04:00 PM
  #1409
CobaltSS 16's Avatar
sounds real good. Nice pull
How much boost are you seeing at 7k-7.5k with that 2.6" pulley??
Old 06-01-2014, 06:32 PM
  #1410
19-20ish and thanks!
Old 06-05-2014, 03:02 PM
  #1411
Old 06-05-2014, 03:21 PM
  #1412
Hockeyman's Avatar
LeGhey
Old 06-05-2014, 03:58 PM
  #1413
sheddep fegit >.<
keeping it #fresh #yoloswagsauce
Old 06-06-2014, 07:24 AM
  #1414
Administrator
Administrator
Staged07SS's Avatar
cute baby blue emblem inlays....
Old 06-16-2014, 09:31 PM
  #1415
I had to... sorry. Illest was always a word i used growing up
Old 06-17-2014, 07:29 AM
  #1416
Administrator
Administrator
Staged07SS's Avatar
Nooooooooooooo!!
Old 06-17-2014, 08:21 AM
  #1417
sry *leaves forum and never returns*
Old 06-17-2014, 08:47 AM
  #1418
Administrator
Administrator
Staged07SS's Avatar
Good riddance!!!!
Old 07-07-2014, 04:18 PM
  #1419
billbarrage's Avatar
did you ever option b the stealth HE?
Old 07-08-2014, 08:31 AM
  #1420
no just running the stealth and ottp fmhe with a dual pass. temps hover around 120-130 on the average/hot day here, and around 150 if im beating on it. 160+ on a pull. but i'm on teh E so doesn't really matter as much now
Old 07-10-2014, 11:26 AM
  #1421
well i havent been reaching my full 20ish psi lately. thinking i have a bad intake mani gasket or blower gasket. or maybe the rotors on the blower are f'd since they chatter anyway perhaps air isn't being pushed through as well anymore. :/
Old 07-10-2014, 11:34 AM
  #1422
Administrator
Administrator
Staged07SS's Avatar
Rice, it's been hotter out than when you first got your car back together.
You will see a slight drop or increase in boost when air density changes.
Don't get so hung up on boost levels.
Old 07-10-2014, 11:37 AM
  #1423
true, but it was a cool 60 degrees last night and not humid. also i'm hearing leaks. what kind of setup could i make to perform a boost leak test?
Old 07-10-2014, 11:41 AM
  #1424
Administrator
Administrator
Staged07SS's Avatar
First thing I would do is inspect all vacuum lines connected to the intake mani and blower. They tend to crack.
You just installed the head on your car, and I'm assuming you installed a new intake mani gasket. If so, it shouldnt be leaking already if you torqued it to spec and in the proper sequence.
Same goes for the blower gasket.
Old 07-10-2014, 11:57 AM
  #1425
InfraRedline's Avatar
Boost leak test into the TB with the blade cracked open.
Quick Reply: Le Riceburners OFFICIAL Build Thread
