Le Riceburners OFFICIAL Build Thread
Old 11-15-2014, 10:35 PM
  #1526
Pulls nice too
Old 11-16-2014, 05:18 PM
  #1527
Thanks. I love it lol
Only issue is by mid 4th gear my iats were nearing 180 so i gotta be losing some power by then regardless of the e85
Old 11-16-2014, 10:30 PM
  #1528
armcclure's Avatar
You'd be surprised
Old 11-16-2014, 10:35 PM
  #1529
CobaltSS 16's Avatar
love the videos rice. that 7.4k+ redline is sweet... your like a honda guy now
Old 11-16-2014, 11:05 PM
  #1530
You'd be surprised
Well i guess you would know better than me, but i think i feel a power loss when the temps get hot. Like first 2nd gear pull it might break the tires loose, but do it again shortly after before recovery and it doesnt want to.
Thanks ss 16, im hoping to rev it higher when im not maxxed out on my injectors anymore. A tvs would help me reach higher rpms safer too i suppose
Old 11-16-2014, 11:24 PM
  #1531
This makes me want to build my engine and get a better turbo so I can rev it out to 7500
Old 11-17-2014, 01:08 AM
  #1532
If yall wanna hear it really scream... go to 0:36 lol
2 step and launches:
Old 11-17-2014, 08:09 AM
  #1533
armcclure's Avatar
That's because your tune pulls timing at those temps for safety. I have experimented with intake temps on my car, and my highest dyno ever had an ending iat2 of 174*
I ran it up to 212 on the street with no loss in power or kr. E85 is pretty crazy
Old 11-17-2014, 09:00 AM
  #1534
If yall wanna hear it really scream... 2 step and launches: Video Link: http://youtu.be/wR0GVT0hIgQ
Damn! That thing scoots off the line man. Was that on the slicks?
Old 11-17-2014, 11:27 AM
  #1535
InfraRedline's Avatar
When I was on the dyno I did 2 back to back pulls on the TVS at a dyno event and I lost 5whp and 5wtq on the 2nd pull, both 3rd gear. I don't know what the IAT's were, probably in the 170-185* range during the 2nd one, but I didn't have it setup to pull any timing strictly for the dyno. Unless they happened to get over 200* then it would have pulled a bit, but I hadn't ever seen them get that high. Its a minimal drop in power though.
Old 11-18-2014, 07:12 AM
  #1536
Administrator
Administrator
Staged07SS's Avatar
What are 180 degree IAT2 temps???
7.5k+ is even more fun
Old 11-18-2014, 05:36 PM
  #1537
Ok,. Went to take off today and it popped out of 1sst gear... then i couldnt get it to get into any gear... shifter deal seemed to be in tact, axles look good no fluid on the ground.. ideas?
Old 11-18-2014, 05:40 PM
  #1538
Did you check the shifter linkages under the shifter and the ones on top of the trans? That has happened to me before.
Old 11-18-2014, 06:21 PM
  #1539
mrbelvedere's Avatar
roll pin?
Old 11-18-2014, 06:31 PM
  #1540
Ill have to look into it theres a writeup on rollpin right? I only checked the shifter assembly under the cupholder
Edit: found it
Old 11-18-2014, 11:09 PM
  #1541
Rather, the shifter would go into the gears, but when i let off on the clutch there was no movement. So could that mean rollpin?
Old 11-19-2014, 10:12 AM
  #1542
You'll know when you see a popped off linkage or a shattered roll pin. Have someone push it into gear and see if the levers on the trans are moving.
Old 11-19-2014, 11:16 AM
  #1543
And if they arent, rollpin? Can this efect all gears?
Old 11-19-2014, 01:18 PM
  #1544
Yes it can. Have a look down there and youll see whats going on. Do you still have clutch pedal pressure?
Old 11-19-2014, 02:48 PM
  #1545
yes i do!
Old 11-19-2014, 04:11 PM
  #1546
So then shouldn't be the TOB. It should take you about 2-3 minutes to see whats going on down there with the linkage/roll pin.
Old 12-07-2014, 06:58 PM
  #1547
Currently...
Old 12-07-2014, 06:59 PM
  #1548
Roll pin is in tact. I thiiink its the clutch
Old 12-08-2014, 10:31 AM
  #1549
hmm just found this...
http://www.ebay.com/itm/10812-GM-Ecotec-billet-WaterNeck-block-thermostat-2-0L-2-2L-2-4L-L61-LE5-LSJ-LNF-/290619718518?pt=Motors_Car_Truck_Parts_Accessories&hash=item43aa48fb76&vxp=mtr
we were thinking about trying to delete that big heater box on the drivers side of the block above the trans, would this be a means of doing so? any gains to be had here? lol
Old 12-08-2014, 11:45 AM
  #1550
BlackielawlessSS's Avatar
Looks like all the fun Adam...
Quick Reply: Le Riceburners OFFICIAL Build Thread
