Le Riceburners OFFICIAL Build Thread
Old 01-27-2015, 11:53 AM
  #1676
okay so i defiantely retract my '400 mile break in' statement, Al is ~190 miles away from me lmao, BUT it was a 4 hour drive
Old 01-27-2015, 03:17 PM
  #1677
Slobodan Milošević
07blackg5's Avatar
are you planning on running an ls4, or a stock tb on the tvs?
I normally wouldn't have an issue with the driveability aspect, since it isnt my DD, but I have a fidanza im debating putting on from when I was planning on n/a. I feel the combination of the two will make it nearly impossible to drive. I'm trying to decide if I should run the ls4 and sell the flywheel, vice versa. Plus I've heard that the lightweight flywheel can cause a lot of false knock readings. I've bought and re-bought so many things it's not even funny
Old 01-27-2015, 03:52 PM
  #1678
ive seen no compelling arguments FOR keeping a nonstock flywheel, unless you are planning to use it as a track-only car.
i'm planning on running an LS4 TB. I already have a 3" intake so having it neck down to the stock TB then opening back up into the tvs just sounds counter-productive.
i too have bought and sold and rebought a million things lmao.
Old 01-27-2015, 04:13 PM
  #1679
Slobodan Milošević
07blackg5's Avatar
Time for a new F/S thread or two... burning cash is fun
Old 01-27-2015, 05:40 PM
  #1680
Im getting sick of it but at the same time if i found ten grand tomorrow i could spend it in an hour on this car lmao
Old 01-27-2015, 06:08 PM
  #1681
Slobodan Milošević
07blackg5's Avatar
and only gain 50whp haha
this f23 clutch thing is killing me. zzp sells a custom drilled flywheel to use the .5" bigger lsj disk on a 6 bolt crank, but you have to buy their clutch (850-950 bucks total). and the custom flywheel is a fidanza, which I already have, but for the smaller f23 disk. but the f23 clutch ratings are terribly low
Probably lmao
10k...
Bulletproof engine, tvs and built trans. Probly at 12k already hahaa
Anyway that sucks. Im sure you can sell the FW and lose some more money haha but really anyone will tell you to just stick with an oem one.
Old 01-27-2015, 08:53 PM
  #1682
Slobodan Milošević
07blackg5's Avatar
I think I just got moderated!! ^^^^
and speaking of losing money, I just disassembled my intake manifold to drill/tap for a bleeder nipple and flip cores for dual pass. Well the cores were full of some sort of metal shavings, and rust "welded" in. I got 2 out after a struggle, and the rust wiped off no problem. Good sign! the other 2 came out easier, but still put up a fight.
yeah, well I had to tighten up the hose clamp pretty tight (because the cores were so mashed in and the clamp kept wanting to come off. Didn't want to scar them up with the clamp sliding around), and ended up flattening the ends of the cores. the rigid part of the hose clamp squared them off. didn't realize until I was done. Story of my life. I was being so careful haha
Old 01-27-2015, 08:56 PM
  #1683
oh gosh, sorry about that dude, i must have hit edit instead of reply! still getting used to this... lol
Old 01-27-2015, 09:18 PM
  #1684
armcclure's Avatar
I have spare cores They ain't cheap....
Yours are PROBABLY fine though.. Especially if you use zzp's o-ring kit. It's more flexible than the stock ones.
Old 01-27-2015, 10:01 PM
  #1685
Slobodan Milošević
07blackg5's Avatar
I know they arent cheap haha. I have the zzp orings already, but the one core looks way worse than the other. I think it might even be split on the side. What a dummy, but the bastards would not wiggle out.
Im really curious to know what the hell happened to the car this came off. not sure where this much metal would come from pre manifold. Overall they looked better than I expected, minus the metal shavings and rust:
This was the one that was really stuck:
I really feel like a jackass, even though I was being extremely careful haha
Old 01-27-2015, 10:48 PM
  #1686
holy **** those are rusty! like they are made of copper lmao!
dude they are super sensitive. i did the trick where you put a clamp around them and pull on the clamp and two of mine got kinda crushed on the ends like that as well not quite as bad, though..
i also got the zzp o-ring kit. hoping for 0 leaks this year; also be sure to have them 'clocked' in the right position where the end pieces 'blank' spots are rotated the right way!
Old 01-27-2015, 10:49 PM
  #1687
Omiotek's Avatar
if your going gmpp run a stock flywheel. the fidanzas are junk imho. spec makes the only decent flywheel for these cars.
Old 01-27-2015, 10:57 PM
  #1688
Slobodan Milošević
07blackg5's Avatar
So much bad news for me today haha.
Old 01-27-2015, 11:14 PM
  #1689
Omiotek's Avatar
ive seen one to many problems with them to ever put them in another car. 2 lsjs where they rubbed the oil pan and another that the bolt circle was completely off.
Old 01-27-2015, 11:19 PM
  #1690
Slobodan Milošević
07blackg5's Avatar
I need to hop onto a few cavalier forums (l61 car), and see what people think, but I will most likely have it up for sale this week. Good thing a new oem is only ~90 bucks
Old 01-28-2015, 07:24 AM
  #1691
Administrator
Administrator
Staged07SS's Avatar
This is how to remove the laminovas w/o damage
Old 01-28-2015, 08:30 AM
  #1692
And this! I never knew this until recently and am mad about that lol
Old 01-28-2015, 08:45 AM
  #1693
bmxracerchamp12's Avatar
reading through this makes me want to spend money i dont have.
Old 01-28-2015, 08:52 AM
  #1694
armcclure's Avatar
If you want a core lmk and we can work something out.
Old 01-28-2015, 09:02 AM
  #1695
speaking of that, just ordered everything i need except the half shaft and axles. i'm hurting bad.
Old 01-28-2015, 09:42 AM
  #1696
Slobodan Milošević
07blackg5's Avatar
*Picture*
That's what I did, but the cores were mash clobbered in there, and i had to keep tightening the clamp. The flat "screw housing" on the clamp is what flattened the laminova however the hell you spell it
I'll re-assess the damage tonight, and I'll let you know. Thanks
Old 01-28-2015, 09:55 AM
  #1697
Im hoping they wouldnt leak if theres just a tad bit of damage on the ends :x mine arent as bad as yours but still
Old 01-28-2015, 11:24 AM
  #1698
InfraRedline's Avatar
Never knew that about lining up the laminovas, but its been like 5 years since I did that stupid dual pass. Oh well haha.
Old 01-28-2015, 11:41 AM
  #1699
i know right? lol idk how important it is but if it was holding me back on airflow or cooling abilities which i can definately see happening, i'm kinda pissed haha
Old 01-28-2015, 11:44 AM
  #1700
I don't think its the biggest deal in the world but every bit helps. As for temps, my car had reversed IC pump wires for years, so my temps were always hot anyways E85 so I didn't care. They really didn't even drop that much when I got them wired correctly honestly.
Quick Reply: Le Riceburners OFFICIAL Build Thread
