Le Riceburners OFFICIAL Build Thread
Old 02-06-2015, 02:32 PM
  #1776
BoostedLemonPie's Avatar
Mike and my best friend might get along, not long ago he catwalked his 1300gsxr in the middle lane during city street night traffic, with no feet on pegs and ass on seat. Effing psycho lol
Old 02-06-2015, 05:12 PM
  #1777
BlackielawlessSS's Avatar
Who cares about this build. Nicks got his car back. So much better of a story
Old 02-06-2015, 05:14 PM
  #1778
Yes defi.ately, good for him!
Old 02-07-2015, 01:43 PM
  #1779
Edit nm i figured it out lol
Old 02-07-2015, 02:17 PM
  #1780
Trans is on.
Old 02-07-2015, 11:02 PM
  #1781
Buttoned a lot of stuff up today.
Still gotta put on the subframe, then bleed the clutch before putting blablabla back on.
Old 02-07-2015, 11:03 PM
  #1782
And heres the new ottp trans mount!
Heres a pic comparing the two, side by side. The stock one is brand new as well. The second and third pics show how much i can bend either with my bare hand. Ott is a big difference...
Old 02-08-2015, 06:42 PM
  #1783
Subframe is on
Clutch is bled
Intercooler system with option b all plumbed up
A few other things bolted up
Got a bit more to do like the fusebox and such,
Think im just gonna wait till i get the gmpp axles and a brand new halfshaft to button up the suspension and jack the car down finally
Oh also still gotta make new headlights lol. Gonna be needing those...
Old 02-08-2015, 06:46 PM
  #1784
Nice! You've been pretty busy
Old 02-08-2015, 06:54 PM
  #1785
Def interested in how the OTTP mount works for you
Old 02-08-2015, 07:17 PM
  #1786
Heck yes been busy since friday night haha. Been breathing through a gas heater and brake cleaner all weekend
Old 02-08-2015, 07:19 PM
  #1787
Ps is anyone familiar with where the ground wire for the starter goes, as well as the other engine/trans ground wires? I think one goes like behind where the ocm mounts and another goes kinda by the drivers headlight but im hardpressed to remember where.
Also got a red 2 prong plug at the top rear of the valve cover that as of now i have no clue where it came from and there isnt much wire to out it anywhere... lol
Old 02-08-2015, 07:28 PM
  #1788
blueLNFftw's Avatar
Those grounds go to the stud bolt that is trans to engine.
That plug goes directly into the back left top corner of the fuse box.
Old 02-08-2015, 07:42 PM
  #1789
Oh so i gotta undo that trans to engine bolt otherwise i think i lost that bolt that goes over the stud
Old 02-08-2015, 07:50 PM
  #1790
Slobodan Milošević
07blackg5's Avatar
When you pull the harnesses under the fusebox, do the fuses stay in the black top cover? Ive seen all the how to's on the fusebox, but no one mentions that. So if I pull the harnesses off the bottom of the fusebox, the fuses stay planted In the black cover?
Old 02-08-2015, 07:54 PM
  #1791
blueLNFftw's Avatar
Yes. They stay.
No. Go buy one.
It's a 18mm outer but I don't know the pitch or inner M
Old 02-08-2015, 08:03 PM
  #1792
Kthx
Old 02-09-2015, 08:40 AM
  #1793
bmxracerchamp12's Avatar
this is why i label every plug i pull. saves me a ton of headache when doing swaps or just pulling things
Old 02-09-2015, 08:52 AM
  #1794
blueLNFftw's Avatar
They can only go so far to reach where they need to be.
Old 02-09-2015, 06:33 PM
  #1795
Slobodan Milošević
07blackg5's Avatar
I managed to pull the f23 upper Trans mount with the engine/Trans in. Haha wasn't fun, but I got it.
Old 02-09-2015, 08:32 PM
  #1796
Damn that takes ***** haha
Old 02-09-2015, 09:50 PM
  #1797
Slobodan Milošević
07blackg5's Avatar
The trans was in the way of it sliding out, so i had to unbolt the upper engine mount and jack that side up to lower the trans. Sketchy haha. but its on the way to josh tomorrow
it was my first time pulling the fusebox, so that was interesting.
I pulled the a/c condenser as well, and all the lines while I was dicking around trying to get the mount out. For those that fully detete the a/c, how do you block off the port at the firewall? I was just going to cut the lines off, cap them, and then bolt them back in. is this pretty standard? I dont plan on reversing obviously haha
Also, I plan on pulling the wires for the compressor clutch and the sensor on the line. Will a code be thrown if the ac sensor doesnt see pressure? Is it a display code like "service airbag", or is it a cel?
Now I just need to drain the coolant so I can get the head pulled and see how bad I blew this turd up haha
Old 02-09-2015, 10:03 PM
  #1798
Well i just pulled my broken condenser out and undid the lines. There's still a hard line running from the firewall towards the drivers headlight i just let it hang there. Never plugged anything; if i ever want ac again i know i have a long journey ahead of me because im sure the lines are all full of dust now. So unless you are sure about never going back to having a.c., plug it up nicely with something.
Oh yeah and working around the fusebox deals fuggin blows. Lol
Old 02-09-2015, 10:09 PM
  #1799
Slobodan Milošević
07blackg5's Avatar
did you throw a code with no pressure in the lines? Im not sure if its to sense that there is pressure (and read a "service a/c" if not), or to shutoff the compressor if there is too much pressure. The latter would be optimal, but i'm not sure
Old 02-09-2015, 10:10 PM
  #1800
Oh yes i kept getting a code. P0422 i think? Or p1142 i forget. I gotta remember to get that deleted when i see al haha. Id keep clearing it with my interceptor but was kind of annoying.
Quick Reply: Le Riceburners OFFICIAL Build Thread
