Le Riceburners OFFICIAL Build Thread
Old 02-23-2015, 03:30 PM
  #1876
andrewcarr1993's Avatar
Doesn't the 2.1 have the LE5 crank or is it the LE5 block?
Old 02-23-2015, 03:31 PM
  #1877
Slobodan Milošević
07blackg5's Avatar
2.1 is lsj crank with le5 block/bore.. Its essentially a big bore lsj
Old 02-23-2015, 04:14 PM
  #1878
Best of luck to you and your crank my friend.
Old 02-23-2015, 04:21 PM
  #1879
Slobodan Milošević
07blackg5's Avatar
You leave my crank out of this!
Old 02-23-2015, 04:38 PM
  #1880
Go hand crank it! Haha
Old 02-23-2015, 04:41 PM
  #1881
Slobodan Milošević
07blackg5's Avatar
what I do in my spare time is none of your business!
Old 02-24-2015, 01:16 PM
  #1882
Well boys, i just pulled the trigger on the 3.0L ecotec. Should be making 800 hp any time now on the panther head
Old 02-24-2015, 01:21 PM
  #1883
Slobodan Milošević
07blackg5's Avatar
Im just going to buy a welder and combine my 2 blocks. 86mm bore, 189mm stroke. I just need to pick up some jb weld to seal the gap between the sleeves.
Old 02-24-2015, 07:20 PM
  #1884
Slobodan Milošević
07blackg5's Avatar
Rice, do you have a video of your idle with the zzps2?
Old 02-24-2015, 07:27 PM
  #1885
blueLNFftw's Avatar
Pulled the trigger in my new clutch set up.
3rd clutch should be the charm.
Old 02-25-2015, 12:13 PM
  #1886
Only before it was tuned. This is youtube channel
Untuned cam idle cobalt ss/sc:
  #1887
What happened to your 2nd one...?
Old 02-25-2015, 12:27 PM
  #1888
Bought some stuff today.
Opt b bracket
80mm halos for my retros, 3157 switchbacks and some 194 leds for my plate lights all from the retrofit source. Its all gonna look siiiick.
New o2 sensor and wire for my uego.
Should be finally buying the axles this weekend.
Old 02-25-2015, 12:32 PM
  #1889
Slobodan Milošević
07blackg5's Avatar
What axles are you going with?
I'm pretty sure I'm going to get hit in the dick with one of my axles when it explodes and finds its way through the firewall
Old 02-25-2015, 12:40 PM
  #1890
Haha. The gmpp upgraded lsj axles from zzp
Old 02-25-2015, 01:13 PM
  #1891
Slobodan Milošević
07blackg5's Avatar
Nice. the only off the shelf axle options I have are the driveshaftshop or whatevers, and those are not cheap.
I dont want crazy strong axles, because I would rather break an axle than a trans, but I want something a bit stronger than base axles.
Old 02-25-2015, 01:18 PM
  #1892
Yep agreed, im tired of going through napa axles
Old 02-25-2015, 01:24 PM
  #1893
Slobodan Milošević
07blackg5's Avatar
that's what will be going on my car. I'm really worried with the 245s, and hopefully 400whp haha
Old 02-25-2015, 01:42 PM
  #1894
Depends on the tires but i have 245 dz101 and my clutch went not the axles. Tires spin over easy tho and i only make 240hp.
Old 02-25-2015, 01:46 PM
  #1895
Slobodan Milošević
07blackg5's Avatar
base model axles here. they are sdrives now, but I will probably be getting r888s next
It is most certainly going to be an issue
Old 02-25-2015, 02:13 PM
  #1896
I have the same car as you. I wouldnt run r888 on the street maybe just for weekends.
Old 02-25-2015, 02:18 PM
  #1897
Got Bewst?
Bluelightning's Avatar
Why not? Infraredline ran Em all last summer and loves them for daily driving other than being a little loud. I plan to do the same when my s drives are shot.
Old 02-25-2015, 02:34 PM
  #1898
Slobodan Milošević
07blackg5's Avatar
this isnt my daily
Old 02-25-2015, 03:33 PM
  #1899
Its not his daily drive to work car though.
Old 02-25-2015, 03:38 PM
  #1900
Slobodan Milošević
07blackg5's Avatar
neither is mine
Quick Reply: Le Riceburners OFFICIAL Build Thread
