Le Riceburners OFFICIAL Build Thread
Old 03-02-2015, 11:08 AM
  #1926
InfraRedline's Avatar
I'd follow your grounds and find where that plug goes. And check your fuses.
Old 03-02-2015, 10:31 PM
  #1927
Omiotek's Avatar
one of those big ground leads is suppose to the chassis under the headlight.
process of elimination. that plug has to go somewhere. text me a pic of it. as close as you are and having my number im surprised you done ask more often.
Old 03-02-2015, 10:56 PM
  #1928
Matt i may have to have you over sometime haha. I would pay for your time of course
That ground under the headlight is still there; never touched that one might be a knock or crank sensor plug mike told me.
Old 03-02-2015, 11:06 PM
  #1929
Slobodan Milošević
07blackg5's Avatar
The wink after the "pay you for your time" is too classic
Old 03-02-2015, 11:09 PM
  #1930
Yeah that came out wrong lmao.
I dont swing that way matt promise!
I have a wifey. Haha.
I am cobalsexual though
Old 03-06-2015, 12:21 PM
  #1931
One ground comes from under the driverside headlight
One comes from the starter
One comes off of the wiring harness,
They are all bolted, undertunately to the grounding bolt on the top front of the trans, like right under the oil cooler thing. I found out that bolt was supposed to go behind the oil cooler, like by the clutch bleed fitting deal.
Anyway, any pointers on this?
Old 03-06-2015, 04:34 PM
  #1932
It runs!
Old 03-06-2015, 04:35 PM
  #1933
And its my birthday. Go figure
The plug was the crank sensor plug had to remove the starter to get to it.
Then after putting the axles in i realized my front calipers.were totally siezed to yay just had to go get new ones. Painting them jow
Old 03-06-2015, 05:17 PM
  #1934
Slobodan Milošević
07blackg5's Avatar
bang bang boogie
Old 03-07-2015, 01:47 AM
  #1935
And yes, i owe mike ^ for being awesome and giving me his old radiator and a new i.c. pump! Thanks a ton man!
Nother shoutout to matt/omiotek for like an hour of phone diagnostics getting me squared up today.
Guess my only other concern at the moment is this:
So the car is still up in the air. I can start it and let it run. While in nuetral, if i let off the clutch, it start to bog up and down, up and down, and the speedo climbs. I take it theres gotta be just a bit of clutch grab? It spins the axle. Is this okay? Will it be normal once on the ground?
Old 03-07-2015, 02:19 AM
  #1936
DillySS's Avatar
Subbed, since I missed the last year and a half of this thread.............(lazy)
Old 03-07-2015, 08:43 AM
  #1937
Hey whats up dude! Its matt right?
Old 03-07-2015, 10:09 AM
  #1938
Well gonna be putting the calipers on soon as the paint dries, meanwhile cleaning up the garage lol.
My awesome gf got me a gopro for me bday... so vids may be in order!
Old 03-07-2015, 10:18 AM
  #1939
Nice!!! What color did you paint your calipers?
Old 03-07-2015, 10:29 AM
  #1940
Red like my old ones were and the backs lol
Old 03-07-2015, 11:44 AM
  #1941
sandman's Avatar
Which one did you get?
Old 03-07-2015, 11:48 AM
  #1942
Hero3 looks pretty sweet i dont know much about gopros
Old 03-07-2015, 11:53 AM
  #1943
Omiotek's Avatar
the wheels should spin with no load. i mean not fast but they should spin a little. if the calipers are locked and not allowing them to spin or the clutch is grabbing because of not beig bled then that would cause your bogging issue. if you need help bleeding it let me know. i can possibly drop by tomorow morning or something like that.
your welcome for the diagnostics.
Old 03-07-2015, 04:57 PM
  #1944
It drives!
P0017
P0340
P0341
Crankshaft and camshaft sensor codes. Need a relearn or something?
Drives pretty well as of now. Likes tot ake its time starting and second time i stsrted it today it cranked for 5 seconds, i let off and got a big pop out of the tailpipe.
Old 03-07-2015, 05:38 PM
  #1945
Its a pretty serious bang... also some sort.of bad grinding noise when shutting off.
Old 03-07-2015, 06:35 PM
  #1946
Uploading vids...
Old 03-07-2015, 06:41 PM
  #1947
Got Bewst?
Bluelightning's Avatar
What all did you have apart and change?
Old 03-07-2015, 06:50 PM
  #1948
Everything
Blower, just cleaned it
Manifold, new orings on laminovas and new gaskets
Alternator was off
Ac condensor was off, drained, and attempted to dissassemble. did not refill with any oil so could be this.
Starter
Trans, clutch, flywheel, tob
Replaced ic pump and radiator. They are both working. radiator fan works.
New coolant tanks/option b
Axles
Old 03-07-2015, 06:54 PM
  #1949
Got Bewst?
Just can't leave **** alone can ya?
Did you pull the motor out with the trans or just dropped the trans out?
Old 03-07-2015, 07:17 PM
  #1950
Back on the road:
Quick Reply: Le Riceburners OFFICIAL Build Thread
