Le Riceburners OFFICIAL Build Thread
#2021
Doing a small pull on the highway my car suddenly died.
After a while if cranking it and it sometimes starting for a split second i gave up and called a towtruck
P0230 - fuel pump? I pushed in the fuel rail bleeder. Cranked it. Pushed it again and it had built pressure.
P0340
P0341
Both cam position codes
Also two 02 sensor low circuit codes.
Wtf
P0340
P0341
Wtf
#2022
Just got home. 200 dollars later
And hmm thats a fuel pump relay control circuit code. Guess ill replace the relays and see what happens but its screwy that it happened while driving suddenly, im gonna check my ground straps tomorrow and crap.
#2023
Well before you start changing relays make sure they are getting power to the parts or passing thru the relay, check resistance.
Also maybe the reason the your car isnt starting is because of the cam codes. Car shouldnt start if the ecu doesnt know where the cams are. If it was the crank it should start after a few tries but thats not the case
