Le Riceburners OFFICIAL Build Thread
Old 03-20-2015, 08:01 AM
  #2051
armcclure's Avatar
Fwiw gas to the floor while cranking disables injectors
Old 03-22-2015, 09:27 PM
  #2052
Well guys this might turn into bad news...
I got a compression tester today.
And i only had time to check cyl 1 and 2. I spent the rest of the day installing 2" lowering springs on a customers cobalt (looks sick btw lol)
Anywho, cyl 1 was 178 psi and cyl 2 was 151... i know these gotta be right because the car held the start cycle for a bunch of cranks each time and the gauge held the pressure afterward so it wasnt leaking or some ****.
Thats a pretty big difference. I cant find my 5/8" socket for the life of me right now or id have the other 2 cylinders.
Old 03-22-2015, 10:43 PM
  #2053
South Central *********
JapEatr's Avatar
How did u get the first 2 plugs out?
Old 03-22-2015, 10:48 PM
  #2054
5/8" socket? Lol
Old 03-23-2015, 07:55 AM
  #2055
Only you would test two cylinders and then take a break lol
Old 03-23-2015, 02:54 PM
  #2056
Yeah hopefully ill get to the other two tonight
Old 03-23-2015, 05:49 PM
  #2057
BoostedLemonPie's Avatar
That's super depressing news man, hope it's not catastrophic
Old 03-23-2015, 05:59 PM
  #2058
Yep. Lol. Well see.
Old 03-23-2015, 10:48 PM
  #2059
armcclure's Avatar
Try it wet also. Should beat it's ***** off the start
Old 03-23-2015, 10:59 PM
  #2060
With oil in the piston?
Well i did cyl 3 tonight...
5psi.
Jk. 154ish psi.. after the 2nd try, 1st try was 130.
My test results are inconclusive. The battery is really low so ive been doing this of my truck battery and jumper cables. So im gonna charge my battery and do it all over again.
Old 03-23-2015, 11:03 PM
  #2061
Well since your starting again the first reading wasnt accurate i would go more with the second reading. You scared me for a bit there
Old 03-24-2015, 07:15 AM
  #2062
armcclure's Avatar
Lol you need to do all 4 at the same time with a solid battery.
If you end up still having an imbalance, you have 2 options.
1: tear it down for a fresh hone and rings.
2: check it again in 10k. If it hasn't gotten any worse, it's just bad seal from a poor break in. You can either live with it, or revisit option 1.
Old 03-24-2015, 08:24 AM
  #2063
What's your process for checking compression rice? One at a time with the rest of the plugs out and the fuel relay out?
Old 03-24-2015, 09:29 AM
  #2064
All 4 at the same time?? Why, so that theres the same number of cranks?
Old 03-24-2015, 09:30 AM
  #2065
Nope fuel relay was in, good idea to take that out actually
One at a time, rest of the plugs in.
Old 03-24-2015, 09:37 AM
  #2066
blueLNFftw's Avatar
You cant comp test with the fuel pump not disabled....
Old 03-24-2015, 09:53 AM
  #2067
armcclure's Avatar
Smh all you gotta do is put the gas to the floor while cranking. This cuts the injectors and holds the throttle open.
Take all the plugs out before you start.
Old 03-24-2015, 10:13 AM
  #2068
Important part right there.
Old 03-24-2015, 10:37 AM
  #2069
Sorry guys I'm definately learning this as i go lol.
So what, i need 4 compression testers or can i do this with all the plugs out and the tester in one cylinder at a time? Ive never heard of having to do them all at once.
Old 03-24-2015, 10:42 AM
  #2070
armcclure's Avatar
By "all at once" I simply meant not taking a 3 day break in the middle..
Old 03-24-2015, 11:31 AM
  #2071
This^
Old 03-24-2015, 11:47 AM
  #2072
Gotcha. You guys are confusing me haha.
So let me confirm:
Fully charge battery.
Take all plugs out.
Go from cyl 1 to 4, try to crank the same # of cranks each time.
Old 03-24-2015, 12:02 PM
  #2073
blueLNFftw's Avatar
So let me confirm:
Take all plugs out.
Hold the pedal to the floor as well.
Old 03-24-2015, 12:06 PM
  #2074
And realize your engine is cold so the numbers maybe a little low. Normally you want to have a warm engine, so if the numbers across the board are close don't freak out if they seem low. Also do what MrB told you too and make sure your tb is working
Old 03-24-2015, 12:10 PM
  #2075
Yeah im not too concerned about what the numbers are as i am consistancy, with the compression this motor makes anything in the 150-180 range is fine especially for 85000 miles id say
Oh also i did test the TB and it is working.
Also the PCM has gotta be good if im getting spark, fuel and codes
Quick Reply: Le Riceburners OFFICIAL Build Thread
