Le Riceburners OFFICIAL Build Thread
Old 03-24-2015, 12:10 PM
  #2076
How can i be sure that im timed correctly? With the cps and all.
Old 03-24-2015, 02:10 PM
  #2077
Administrator
Administrator
Staged07SS's Avatar
It's timed right if all your sprokets were lined up correctly with the guides on the chain, while at TDC and installing the CPS housing into the exhaust cam as shown in my thread.
Old 03-24-2015, 02:27 PM
  #2078
Does it matter which cycle of tdc #1 im at? I tried to retime with the v,c. Off but couldnt find the correct colored links at 10.and 2
Old 03-24-2015, 02:34 PM
  #2079
Administrator
Administrator
Staged07SS's Avatar
It would take you many many tries to get the chain marks to line up again w/o removing the chain and timing it from scratch.
Place a screw driver in the #1 spark plug hole and rotate the engine until you are at TDC comp stroke which would have the screw driver rise up.
The easiest way to make sure youre still in time is to line up the factory harmonic balancer timing mark with the timing mark on the front cover. If the harmonic balancer timing mark is lined up, and the intake and exhaust are at 2 and 10 (respectively), you are good to go.
Prob is u have that ati balancer and I dont think it has the same timing marks.
Old 03-24-2015, 02:39 PM
  #2080
So im okay though? I cranked until #1 was high as it would go far as i could tell and reclocked the position sensor thats why im asking. I had to rotate the sensor to do it,
And yeah no timing mark on the ati unfortunately.
Old 03-24-2015, 02:45 PM
  #2081
Administrator
Administrator
Staged07SS's Avatar
There is room for error if you dont have all the timing marks lined up perfectly though. Especially the harmonic pulley and front cover timing marks. Those need to be lined up dead on.
Just rotating the engine wont get that dead on without a comp gauge or lining up the marks.
If timed and lined up correctly, the CPS housing should slide right into the hex of the exhaust cam without issue or rotating.
If it rotates it will through the CPS outta time.
Old 03-24-2015, 02:50 PM
  #2082
Fak! Well i gotta figure that out then
Old 03-24-2015, 02:53 PM
  #2083
Administrator
Administrator
Staged07SS's Avatar
Either use your comp gauge to determine actual TDC at the comp stroke, or press off the ATI and silde on the factory harmonic pulley just to line up the timing marks on the front cover.
I think using a comp gauge to determine TDC is covered in the LSJ build book.
Old 03-24-2015, 02:57 PM
  #2084
So i gotta get a comp gauge then lol
Somehow my buddy and i did it last year haha
Old 03-24-2015, 02:59 PM
  #2085
Administrator
Administrator
Staged07SS's Avatar
How have u been doing your compressions tests??
Or press your ATI off and slide the factory harmonic balancer on just for timing. That isnt hard to do.
Old 03-24-2015, 03:00 PM
  #2086
Somehow my buddy and i timed it last year just with a screwdriver in cyl 1 and resetting the cam sensor
Old 03-24-2015, 03:01 PM
  #2087
Administrator
Administrator
Staged07SS's Avatar
You guys were lucky and precise at the same time haha.
I've always used the screw driver as a guide, but even with the screw driver all the way up it was slightly off on the timing mark on the harmonic balancer and front cover mark.
Old 03-24-2015, 03:12 PM
  #2088
Yuck. Ill need a stock damper if i wanna do this right then
Old 03-24-2015, 03:13 PM
  #2089
Administrator
Administrator
Staged07SS's Avatar
Or comp gauge
Old 03-24-2015, 06:22 PM
  #2090
armcclure's Avatar
Comp gauge hose in cyl4, screwdriver in cyl1. Rotate forward until you start getting air from the hose in cyl4, use the screwdriver in cyl1 to find tdc
Line hash mark up with nub. Install. I recommend taking the sensor out of the housing and stick your finger up there to keep the wheel from rotating.
Old 03-25-2015, 12:18 PM
  #2091
So your saying install compression gauge in cyl 4 and it will start to build air when the pistons near the top? I'll read about it in the book.
Old 03-26-2015, 03:03 PM
  #2092
armcclure's Avatar
Just put the tube in and your thumb over the end. When the screwdriver in cyl1 starts coming up, so is cyl4. If it doesn't start pushing air out, go another rotation.
Old 03-26-2015, 03:08 PM
  #2093
Gotcha!
Old 03-26-2015, 07:17 PM
  #2094
Think im just gonna get it towed to gm guys, too many ideas not enough diagnostic tools and time.
Matt told me it could have to do with my power steering light being on could have to do with a ground issue somewhere, and the fact that it was taking a while to start could be low oil pressure. I did find a small seep around the front cover.
Old 03-26-2015, 07:49 PM
  #2095
Scratch that, its going to performance autowerks so matt can just work on it! lol
Old 03-26-2015, 09:04 PM
  #2096
I was going to tell you to tow it there, they'll actually find the problem for the money vs the dealer not finding it and charging you more
Old 03-26-2015, 09:09 PM
  #2097
Yup. Only thing im losing out on is the tow cause its 30 miles away vs the dealer which is 5 haha. But it will be worth its weight in gold im sure,
Old 03-26-2015, 09:28 PM
  #2098
kdub1492's Avatar
Great choice, Matt and Dave will get you all squared away.
Old 03-26-2015, 09:57 PM
  #2099
You have AAA? That will make the tow cheaper
Old 03-26-2015, 10:02 PM
  #2100
Well its good your getting it checked out man hope its nothing serious
Quick Reply: Le Riceburners OFFICIAL Build Thread
