Lean Code
Old 04-02-2009, 06:07 PM
  #76
Darkmanx's Avatar
Originally Posted by Brenticus
can you explain this in a little more depth? are you saying that it is strictly a problem with the maf and not anything else? like not injectors, fuel filter, too much air in general?
i dont think your gonna get the answer you want from area, he is not going to list steps
1-10 for you to do. blazin did the steps you should do and like they stated its not a code for you actaully running lean , its not gonna blow your car up! so dont worry and use the search bar this code pops up atleast twice a month.
Old 04-02-2009, 06:10 PM
  #77
Brenticus's Avatar
Thank you Area47. I've decided that K&N are a bunch of over cautious nut jobs that don't know all of what they say because the techie Italked to said that the oiling thing is a myth, but so many people have had this happen and I used what Area47 said to look this up.
Technical DescriptionSystem Too Lean (Bank 1)
What does that mean? Basically this means that an oxygen sensor in bank 1 detected a lean condition (too much oxygen in the exhaust). On V6/V8/V10 engines, Bank 1 is the side of the engine that has cylinder #1.
Note: This DTC is very similar to P0174, and in fact your vehicle may show both codes at the same time.
Symptoms: You will more than likely not notice any drivability problems, although there may be symptoms such as a lack of power, detonation (spark knock), and/or a hesitation/surge on acceleration.
Causes: A code P0171 may mean that one or more of the following has happened:
The MAF (Mass Air Flow) Sensor is dirty or faulty. Note: The use of "oiled" air filters may cause the MAF to become dirty if the filter is over-oiled. There is also an issue with some vehicles where the MAF sensors leak the silicone potting material used to protect the circuitry.
There could be a vacuum leak downstream of the MAF sensor.
Possible SolutionsPossible solutions include:
In the vast majority of cases, simply cleaning the MAF sensor does the trick. Consult your service manual for it's location if you need help. I find it's best to take it off and spray it with electronics cleaner or brake cleaner. Make sure you are careful not to damage the MAF sensor, and make sure it's dry before reinstalling
Inspect all vacuum and PCV hoses, replace if necessary
Check for a dirty fuel filter and proper fuel pressure
This came from www.obd-codes.com
Old 04-02-2009, 06:16 PM
  #78
Darkmanx's Avatar
what about my thanks huh i told you that 5 hours ago wtf
Old 04-02-2009, 06:22 PM
  #79
Brenticus's Avatar
thanks darkmanx, i'm basically thanking anyone who said what this said as long as it worked. i didn't mean to leave you out.
Old 04-02-2009, 08:44 PM
  #80
Rent me! per hour
Area47's Avatar
it's a fuel trim error. +25 is adding fuel. will trigger a lean code
-25 is taking fuel out, this will trigger a rich code. simple maf scaling tweaks will cure this.
Old 04-03-2009, 07:04 PM
  #81
94firebird's Avatar
ive been dealing with the P0171 for over 6mnths know and the only solution the dealer has to fix it is to rebuy the stage 2 kit and they dont even know if that will work or even fix the problem
turbochargedss2012
09-20-2023 12:17 PM
tomj77
10-04-2015 11:39 AM
ernnyyes
10-02-2015 05:16 PM
Extremespeed
09-29-2015 04:34 AM
DocSvensk
09-27-2015 02:24 PM
Quick Reply: Lean Code
