Let's clear-up that 3" vs 2,5" Catback thing for the LSJ.
Old 11-02-2011, 12:32 PM
  #76
Administrator
Administrator
Staged07SS's Avatar
^ what was the rest of his build? curious as i cant remember
Kevin if you are asking me.... I believe he is running either a ported stock manifold or GMPP manifold, 2.5" Cobalt Addiction catless downpipe, and GMPP catback.
I believe he runs a 2.7 pulley on his TVS as well.
Old 11-02-2011, 01:47 PM
  #77
Jmc007's Avatar
GMPP catback is 2.25" (which I know you already know). So, I can see why he gained some horsepower.
I've found that a good 2.5" catback provides the best of both worlds (excellent exhaust gas velocity & flow).
Although, WSfraiser puts down around 350whp with a TVS & GMPP catback so, it's still debatable which setup is best.
Humm... is this not 100%Meth that dynoed 15 more whp from switching to 2.5 to 3" with the MP90 set-up?
Old 11-02-2011, 01:55 PM
  #78
Administrator
Administrator
Staged07SS's Avatar
I believe he dyno'd 15whp from switching from a noodle header, 2.5" downpipe, and 2.5" catback to a badmab header, 3" downpipe, 3" catback. No doubt in my mind most of the restriction was found in the header.
I'm not saying a 2.5" catback is best for every setup, but it flows more than well enough for prob 90% of the SS/SC owners on here. It also provides excellent exhaust gas velocity which is just as important as flow.
The larger the pipe the slower the velocity, unless you are flowing the amount of air to compensate for the reduction in velocity (this I'm sure you already know).
Old 11-02-2011, 04:44 PM
  #79
ItalianJoe1's Avatar
Exactly. Cat-backs do NOT gain power on these cars, not enough to justify much cost anyway. I could port a stock manifold and gain more power than you will gain from swapping to a larger cat-back.
A good header, a well-made catless downpipe, and some free-flowing mufflers (which is part of the reason I like GMPP, the borla mufflers are very well designed and flow nicely for the size of the system, along with sounding great) is all you need. A 3" exhaust isn't needed on these or really any other car under 400hp. On a turbo car there can be gains due to better pressure differential across the turbine, but that doesn't apply on the LSJ cars.
Old 11-02-2011, 04:56 PM
  #80
Agreed, the only major increase u can get is catless dp and header.
as for me i got injen, badmab header, and corsa touring cat back ,stock dp. i know the dp is very restrictive, but listen to this! not my vid but same setup... sounds sooo sexy
Cobalt SS/SC Corsa Exhaust Pull Away - YouTube
Old 11-02-2011, 09:53 PM
  #81
Jmc007's Avatar
Well at least this guy picked-up 42whp from stock exhaust to open exhaust (cut-out):
https://www.cobaltss.net/forums/2-0l...-tuned-263910/
Old 11-03-2011, 07:11 AM
  #82
Administrator
Administrator
Staged07SS's Avatar
No doubt. Turbos usually result in a decent power increase when modifying the exhaust system. Supercharged cars are not as picky.
From the words of Hennessey, and his HPE700 LS9 Camaro.... "The neat thing about superchargers is they are not real sensitive to exhaust back pressure. They just force the air out (so don't go shoving a banana in your tailpipe, because it will send it to the moon)".
That's my exact setup....
Although, my stock downpipe has been slightly modified to remove the restrictive O2 sensor area.
Old 11-03-2011, 07:27 AM
  #83
that corsa exhaust sounds mint
Old 11-03-2011, 07:42 AM
  #84
distillion's Avatar
corsa sounds great , that car sounds almost like mine but ive got a modified GMPP setup, proper zzp shorty header and a catless custom dp which gets me compliments all day long granted every other catless LSJ ive heard sounds like poop.
Old 11-03-2011, 08:19 AM
  #85
Administrator
Administrator
Staged07SS's Avatar
Yea, when I was catless my Corsa Touring sounded pretty good. I just got sick of the smell.
Old 11-03-2011, 09:21 AM
  #86
mrbelvedere's Avatar
lol what smell
Old 11-03-2011, 09:27 AM
  #87
Administrator
Administrator
Staged07SS's Avatar
Originally Posted by mrbelvedere
lol what smell
The old car smell....
My exhaust smelled just like my fathers 65 GTO's exhaust. While that's fine for a classic car, I got sick of smelling it on a daily basis with my car.
Although, I do miss the sweet smell race gas gives when I filled up with CAM2. Can't really smell anything with a cat re-installed.
Old 11-03-2011, 09:35 AM
  #88
distillion's Avatar
i love the smell lol.
definatley cant be good for me though LOL
Old 11-03-2011, 09:37 AM
  #89
Administrator
Administrator
Staged07SS's Avatar
Old 11-03-2011, 09:40 AM
  #90
they need to make a race gas clogne for men
Old 11-03-2011, 09:44 AM
  #91
Administrator
Administrator
Staged07SS's Avatar
Agreed!!
Old 11-03-2011, 09:49 AM
  #92
haha i've thought of 'burnt rubber' air fresheners would be cool in the car... can't beat that smell
Old 11-03-2011, 10:17 AM
  #93
distillion's Avatar
Agreed!!
x3!!
Old 11-09-2011, 01:44 PM
  #94
troyss's Avatar
So If running noodle header with an 3inch dp be better then an 2.5? On that specific header?
Old 11-09-2011, 01:59 PM
  #95
Administrator
Administrator
Staged07SS's Avatar
It might help, but the main restriction will still be found within the header.
People need to understand that bigger is not always better. You need to find the happy medium of exhaust flow & exhaust gas velocity.
What is your current setup??
Old 11-09-2011, 02:11 PM
  #96
troyss's Avatar
Meth's old header. 2.5 inch catless dp, stco cat-back with magnaflow muffler
Old 11-09-2011, 02:25 PM
  #97
Administrator
Administrator
Staged07SS's Avatar
Are you dead set on keeping the noodle??
What size pulley are you running? Just curious to get an idea of the amount of airflow your car is making.
Old 11-09-2011, 02:29 PM
  #98
troyss's Avatar
Im running 2.8
I had the badmab before I changed it and I can honetly say I feel no difference in performance.
Maybe with a better tune I might of seen a difference
Old 11-09-2011, 02:41 PM
  #99
Administrator
Administrator
Staged07SS's Avatar
Im running 2.8
Hmm.... I would have kept the Badmab to be honest. Although, you can't match the sound the noodle produces IMO.
You will def notice some more power after a tune. I would leave your exhaust as is, and focus on a tune. Your catless 2.5" downpipe should be flowing more than enough for your current setup.
Old 11-09-2011, 06:51 PM
  #100
cavfiredesire's Avatar
Just curious...
Cause im currently on the fence on what to get.
But guys are making gains with a 3" over a 2.25 on a n/a cav eco.
Now im supercharged and plan on eventually going with the tvs...basically shooting for 300whp. Can I get away with a 2.5 and retain a somewhat good sounding exhaust or is the 3" going to make the difference?
The plan is a Bad-mab header, zzp catless 2.5" downpipe, cat, longest resonator I can fit, superturbo muffler.
Quick Reply: Let's clear-up that 3" vs 2,5" Catback thing for the LSJ.
