Let's clear-up that 3" vs 2,5" Catback thing for the LSJ.
Old 11-13-2011, 01:32 PM
  #126
Jmc007's Avatar
Everything happening downstream of the turbo should be consider similar to a supercharged application IMO. Both are opened to atmosphere and are trying to get rid of an X amount of burned air fuel mixture (all other factors being equals such as EGT's).
Old 11-13-2011, 02:31 PM
  #127
Administrator
Administrator
Staged07SS's Avatar
Yes, but supercharged cars are not as sensitive to exhaust back pressure as turbocharged cars. Like ItalianJoe said, the main restiction on the SS/SC is in the exhaust ports of the cylinder head, and the exhaust manifold. Which has been known for a long time (and I'm sure u know).
Giving an example of a turbocharged regal gs is not a clear indicator that a 3" exhaust will make more power on the SS/SC (which is what this thread is about). Like I've said before, I agree that a 3" exhaust will make more power on some applications, but a 2.5" exhaust will still provide optimal flow and exhaust gas velocity for most setups on the SS/SC.
Old 11-13-2011, 04:02 PM
  #128
100% METH's Avatar
good example of a 2.5" exhaust is my m62 2.7 pulley dyno up above...
notice the curve...
Old 11-13-2011, 04:20 PM
  #129
Dart_SI's Avatar
You can't really compare turbocharged cars with supercharged cars when it comes to the exhaust system man. I agree that a 3" exhaust will produce more power than a 2.5" exhaust on some applications though.
I wish the lnf guys knew this. They all say a 3" is a waste of $$
Old 11-13-2011, 04:22 PM
  #130
Powell Race Parts's Avatar
it is.
Old 11-13-2011, 04:44 PM
  #131
Dart_SI's Avatar
No offense mr Powell but do u have proof there's no gains? I don't see how a 2.5" could support my power level.
Old 11-13-2011, 04:55 PM
  #132
100% METH's Avatar
One individual recently dyno'd their LNF on a stock LNF muffler and then with a cut out. The gain was around 30-40whp...
Though, his setup was on a larger turbo if I recall... None the less, turbo'd balts would benefit much more from a open dp or opened up exhaust relative to the CFM of their setup.
Old 11-13-2011, 06:27 PM
  #133
gbkglenn's Avatar
i build my 2.2 motor running 8:9.1 wisco piston with a TVS and 2.5 pulley 3'exhaust i feel like i lost power with the 3' set up
Old 11-13-2011, 06:42 PM
  #134
sick_tight's Avatar
throw a 5" from a diesel on there just to be safe... hahaha
Old 11-13-2011, 06:51 PM
  #135
gbkglenn's Avatar
why don't we race for your car
Old 11-13-2011, 07:07 PM
  #136
this is an LSJ thread. i run 320 whp on the lnf cat back. I dont publish my dyno sheets, area47 has done the work with the car and thats all i need.
so yes thats the power level. I took off the 3 inch. I did not make less power. you can look at the flow numbers already published and see unless you are trying to get above 350 with an LSJ the 2.5 is fine. LNF are different, but make over 380 wt all day on stock exhaust. the rear muffler is straight through, so replacing it is just a means of making noise not power.
I guess WS Frazer is the dyno king around here with 348 whp on an LSJ , ask him.
http://www.******************/forums...lsj-parts.html
put in red line forums.com to make the link work.
Old 11-13-2011, 07:08 PM
  #137
gbkglenn's Avatar
thanks that's what i needed to hear , it's guys like you that i like you are a big help !!
Old 11-13-2011, 08:27 PM
  #138
Administrator
Administrator
Staged07SS's Avatar
Thank you for posting this John.
This is what I have been trying to make clear the whole time.
Old 11-13-2011, 08:46 PM
  #139
Dart_SI's Avatar
I understand. Lnf is different platform so the same can't be said. I guess ecotecs are just kinda weird. I know with the k-series honda, you need something close to a 3" when your near 300whp. My friends m62 SI sedan gained 15 whp moving from 2.5"-3"
But that's a diff car completely.
Old 11-14-2011, 07:08 AM
  #140
Administrator
Administrator
Staged07SS's Avatar
and the head its self flows a hell of a lot better than the ecotec head.
Old 11-14-2011, 06:30 PM
  #141
BennyHHR's Avatar
Pretty much the fastest LSJ/SC car here is zrated89.
Whelp, he's only running a "straw" exhaust.... 2-1/4 GMPP.
Does that tell ya'll ******' sumptin??
Old 11-14-2011, 08:26 PM
  #142
yup 117 trap, prettydamnstout I would say. But then with a 1.7 60 ft he can drive it as well.
this 3 inch thing will eventually run its course.
Old 11-14-2011, 11:04 PM
  #143
Omnigear's Avatar
pif 3" new hawtness is 4pipers =p
Old 11-15-2011, 07:04 AM
  #144
Administrator
Administrator
Staged07SS's Avatar
Haha, I sure hope so....
I feel like we are going in circles in this thread.
Old 11-15-2011, 07:11 AM
  #145
06SS ALL DAY's Avatar
i never knew there was a 3inch vs 2.50? this thread fails
Old 11-22-2011, 09:26 PM
  #146
troyss's Avatar
I put an new magnaflow 14326 and at wot sounds horrible. When I installed it, it didn't have an tip and sounded deep, and now I have an tip welded on it sounds raspy. Im using jbp header, 2.5 catless dp, stock CB to the new muffler. What's an good resonator to put on? And should I replace the new res with the stock res? Or keep the stock and weld in new one on the dp?
Old 11-24-2011, 01:19 PM
  #147
KangolRiot's Avatar
Figured I’d post this graph here. Was having trouble getting anymore power than 408 out of my car with the 2.5” exhaust w/resonator and gutted cat due to having too much back pressure which ended up causing my resonator to explode (pictures on twincharged thread) Ended up putting on a 3” exhaust from where the cat was gutted straight back and reduced to 2.5 a foot and a half or so before the turbo to create some velocity. Also we eliminated the resonator. Car is now extremely loud and first run on dyno (not on graph) made about 350hp and lost 4psi or so. So right off the bat with the same tune I lost about 58whp just from switching to a larger exhaust. After some tuning we were able to get a best of 384hp which was AFTER we turned the boost up to 28psi. (which was 1psi more than I had before on the 2.5” exhaust making 408hp) The tune was very rich so he leaned it out a bit and lost more hp bringing us into the 360’s to 370’s as where it stand now. So the car is still at the shop til he can figure out whats going on. The only benefit shown on graph from the 3” exhaust is the power band up to 4500 rpm. After 4500 power is lost and we have no idea why.
Old 11-24-2011, 10:42 PM
  #148
xxxxsh4d0wxxxx's Avatar
About the new 2012 Buick Regal GS Turbo with "only" 270 BHP at 20 PSI of boost:
"A three-inch-diameter exhaust system provides reduced back pressure, resulting in higher engine power"
You're comparing apples to oranges here.. Of course you're resulting higher horsepower with a 3".. On a turbo car. Less backpressure, faster spool.. Power comes on faster. End of story.
As Staged says below it varies from application to application, but, easily, more than half of the M62 LSJ's on this site are not making enough power to warrant a 3", it's just not realistic, and not needed. I still have friends who drive LSJ Cobalts that will argue to the death that they need a 3".. I just let it go and carry on usually..
Old 11-24-2011, 10:52 PM
  #149
Troof. kill the thread.
Old 11-25-2011, 02:26 PM
  #150
newt's Avatar
Your AFR on the 408whp run is much leaner than the rest of the runs.
There is no way you are losing that much HP at your level with a 3" exhaust over a 2.5" exhaust. Something else is wrong there...its not the exhaust.
Hell my car runs 20" of 3" pipe (3" collector) and then it dumps to atmosphere, my car is all-motor and makes 193whp. TQ was nearly 160wtq at 3000rpm as well, peak 179wtq at 4800rpm.
No loss in low end TQ or power for me.
Everyone should just run 3" cutouts and then this won't be an issue, they make more power than any exhaust combo.
05-28-2022 03:47 AM
bigdeertz
11-17-2016 09:41 AM
ineedacobaltss
11-07-2015 02:25 PM
09-28-2015 12:51 PM
Coballin13
09-25-2015 08:43 AM
Quick Reply: Let's clear-up that 3" vs 2,5" Catback thing for the LSJ.
