license plate light not working!
Im not getting any power to my license plate light.
is there a fuse for that light? i dont see anything in the manual. the connections are all good. when i tested the wires, theres no power there.
Duh.
I still cant find where the wire goes. It was working before i had car painted. I took off tail lights n put em back, but ive done this a few times without issues.
1 Post
Are you using LED or a regular bulb. If LED, did you put it in backward?
It could be possible that the bulb socket has corroded contacts, try taking a small screwdriver and scraping them clean.
I bot an led cuz i was gona put it on. But first, theres no power to the factory light. I tested it too, nothing. Even put a new bulb to be safe, nothing. Alredy got pulled over once by cos. I.needa fix it and i dont wanna have to run a fresh wire....
if you have a break in the power wire before the bulb, that will cause the bulb not to work. If you have a break anywhere in ground, the bulb won't work. Seeing is your car is an 05, I would think it could be corrosion.
it was working perfectly fine until i took it to body shop to get painted last week. nothing was messed with. i unplugged it and tucked it inside bumper. then after 5 days i took it back out and screwed it on. this is really weird. and since the wires are all inside the bumper, theres no real way to trace the whole wire. i know how to, just this is bs
thats the thing. they never did the unplugin stuff. i did. they only mask off and shoot. its up to me to take off what I wanted. im just wondering if they got it wet somehow. which is why i was wondering if there was a fuse. not to mention the factory lic light blows *****. its so dim. i really dont wanna run another wire. certainly wont be easy without taking bumper off
