Little help with GM Performance..
Im sure you have heard this enought ims, But I was wondering....who has or anyone know of anyone who has GM Stage 2 with GMPP Header and Exhaust....And WHP and WTQ? Possibly dyno??
I am wondering because someone is going to buy my car! YES!!! I can get a new car next weekend...possibly if they find me one,haha. Since I don't really want to upgrade non warrantied parts...but my mother(since I live at home still, we run our business 10 feet away,haha). Anywho...I think the Cobalt SS SC is top dog now....
Thanks
possibly intake also...but with the tune...does it run lean? I know it runs rich with tune alone....but I am hoping with intake and full exhaust it runs just right...
Thanks
Thanks
Thanks
My car is a constant 12.3 (+/-.1)
any real reason not to have a cat? its only a 5-10 hp(on a really high powered car, so for a 200-300whp car, its probably around 5whp) loss to not have to worry about the huge fine for not having one.
I suppose. Im in NJ and never knew anyone who has gotten any fines for having a catless exhaust. But if the cat does make the car sound better then im for it.
this is all with a sensor mounted after the cat...so its readings are biased by that. im going to put in a new bung so i can put it upstream from the cat to get a more accurate reading.
The rear O2 sensor has nothing to do with the fuel ratios. It performs functions, not limited to, checking the cat temp and operating the COT setting.
Not of my car. There should be others on here with a similar setup though. It does sound better after I ported the exhaust manifold though. Made the note deeper for some reason. Idle sounds like it has cams.
cuz the cobalt has two sensors on the exhaust...before and after the cat that measure the O2 ratios to control the fuel mixture... No cat, way rich (9.3 on mine) Put the cat on...right on stoich. and you can feel the difference when driving.
Who installed it like that? Your not supposed to take readings after the cat because they will mess with it. The reason why you have two sensors is the first is for the a/f ratio and the second is to make sure you cat is working. You can't relay on the second sensor. Also, on top of that, your a/f shouldn't go from 9.7 to 14.7 from jsut putting in a cat. You should research and learn before spitting out stuff that doesn't make sense or could damage someone else's car. Imagine if someone actually tuned their car for 14.7:1 at wot.
to clarify...The original set-up was a downpipe without a cat. the bung was put on with that set-up. the ppl who put it on put it next to the #2 sensor toward the end of the pipe. When i put the cat back on the pipe i had to put it in the original position or it wouldnt trigger the sensor. so right now...the wideband sensor is after the cat. im going to put in another sensor bung to move it upstream from the cat so i get correct readings.
that make things a little clearer?
